Question about Vacuums
I have a littermaid elite automatic litter disposal system. It stopped cycling and both lights are flashing. Nothing is stuck, it just made several passes at some point overnight without successfully getting to the receptacle due to heavy litter. The box was clear and moving before we went to bed. This morning the lights were flashing. I unplugged, emptied, etc and it will not work. what now? It does not have the reset button at the receptacle button that the old models did. Is there one? help
5 Suggested Answers
  • 44 Answers
SOURCE: electrolux Centralux Vacuum
If the light came on when you plugged it in, then you have power to the unit. You can take a coin and short across the two pins where the small, low voltage wires connect to the unit. Just remove the two wires, they should just pull off, and touch the two pins together with the coin. The unit should come on. If it doesn't, and the light is on, you may have a bad motor or a bad relay on the board inside the unit. Another thing to check is the filter. It has to be installed properly or the unit will not run. The top of the filter depresses a switch so that the unit cannot be operated without a filter in place. Good Luck!
Posted on Dec 31, 2008
galati2k
  • 281 Answers
SOURCE: I have a kenmore progressive direct drive handi
its probably clogged up with cat litter.might have gotten into the motor.your motor has a motor guard inside if it. when it overheats it will shut down till it cools off.you need to clean all th cat liter out of it.and clean the filters.with a direct drive you might want to take it in to a repairman to sevice. its not a shop vac i advise you not to pick up things like cat liter
Posted on Apr 29, 2009
SOURCE: vaccum cleaner not picking up (116.36933/Aspiradora)
Joan,
I had a similar problem with my upright and just resolved it today. Mine was also picking up with the beater bar, but not as good as it should and it had very little suction at the hose.
I did everything it said to do in my owners manual...
I looked into every entry to the dirt cup.
I checked for blockages into the bottom of the vacuum.
I cleaned the HEPA and regular filters and dirt cup - still no success.
I made sure the belt was working properly.
I finally sat and looked at how things should get into the clear dirt cup (bagless model).
I finally realized it had to be a blockage in the hose.
I completely detached the hose from the vacuum - this took some muscle.
Took the hose outside and used my high pressure nozzle on my garden hose to spray out the hose. It took a few seconds before a pretty large & stiff piece of paper (2"x2") and much more very dirty stuff finally blew out...
No wonder the vacuum had no suction!!!
The paper that was blocking the hose reminds me of a piece found under a Reese's Peanut Butter Cup! YIKES, it was probably candy causing yet more problems besides the extra pounds!!!
Hope this helps - I'm not an expert, just a frustrated cleaning fanatic who hates it when mechanical things don't work right!
Good LUCK!
rtwospeed in Henderson, NV
Posted on May 27, 2009
  • 58 Answers
SOURCE: vacuum working perfectly and everything stopped.
sounds like a bad relay in the tank just a simple repair but should be done by a vacuum tech or electrician. Could be a motor is nothing is starting at all, but not as likely.
Posted on Jul 26, 2009
Dyson v6: It looks like it stopped charging.
If it's only 2 weeks old, you could have a defective either charging system or just a bad battery. Most places offer free replacement within 30 days of purchase. I would take it back to your place of original purchase. I hope that helps!
Mar 21, 2016 | Dyson V6 Absolute Bagless Cordless Hand...
What does a flashing light on the dc28 vaccuum mean
There are a few things a flashing light could mean. One is that the beater bar has something stuck on it. Or, it could be that the bag or canister is full. Then again, maybe something is stuck in one of the intakes. Be careful when checking the beater bars. Unplug the vacuum before touching them, you wouldn't want your hands getting injured or fingers broken:( Clear anything that is wrapped around the beater bars, hair, string, etc., and then check the hoses to make sure nothing is stuck in them. If you have suction, the interior is clear. If not, then check in there to make sure nothing is clogging it. Good luck and be careful:)
Jul 23, 2014 | Dyson DC28 Animal Bagless Upright Vacuum
Polaris p93 shuts off after a few minutes
Best bet would be return as defective and get a new one
May 27, 2014 | Polaris New P93 Premium Robotic Automatic...
Error 1
hey mike im an expert do the following >>
Check the side wheels for obstructions.
First Try:
• With the robot on its back, push the wheels up and down several times to make sure nothing is stuck. Turn the wheels by hand to see if they both have the same amount of resistance.
• Clean the wheel assemblies
if this doesn't help please replace the wheel assembly
Apr 15, 2014 | iRobot Roomba 550 Vacuum
Light keeps blinking
http://www.searspartsdirect.com/partsdirect/user-manuals/uh30010com-hoover-parts-vacuum-manual
WARNING: TO REDUCE RISK OF PERSONAL INJURY - UNPLUG CLEANER BEFORE SERVICING
PROBLEM POSSIBLE REASON POSSIBLE SOLUTION
2. Blown fuse or tripped breaker.
4. Thermal protector activated. (power
light is flashing)
1. Disposable bag is full. ("Check Bag"
indicator illumJnated red)
1. Disposable bag not installed correctly.
3. Brushroll is worn out.
2. Check fuse or breaker in home. Replace fuse/reset breaker.
4. Turn the cleaner off and disconnect it from the electrical
outlet. Then allow cleaner to cool for 30 minutes. If the
thermal protector continues to activate see Needs Service
solution #5.
1. Replace disposable bag - Pg. 9.
1. Review disposable bag removal and replacement - Pg. 9.
3. Replace brushroll - Pg. 10.
Mar 11, 2014 | Hoover UH30010COM Bagged Vacuum
When i try to use it on manual the green light will flash then turn off, but works on automatic
The hose button will only work if the hose is unplugged from the side. Sounds like it thinks the hose is still in it. There is a small magnet in the end of the hose. Over time they rust and come apart. Bits may be stuck to sensor where hose clicks in on the side.
May 22, 2012 | Bissell SpotBot Robotic Wet/Dry Vacuum
Plug/wire is stuck partially out (4-5 inches)pressing on rewind button nothing happens....just stuck!
This usually means the cord got twisted over itself. Pull it completely out and give slight resistance on cord and rewind it again.
Sep 17, 2010 | Hoover Elite Rewind Bagless Upright...
I have a Eureka Boss Power Plus and the beater bar is rolling, the belt is turning, but after vacuuming up around the litter box (not a lot of litter), when I turn the vacuum off, the litter, or even...
Even though the brush is spinning, you probably need to replace the belt2_bing.gif because it is stretched. It is probably slipping on the beater bar. This is normal and you shouldn't be alarmed. There is nothing wrong with your vacuum. :-)
Jim
Nov 29, 2009 | Eureka Vacuums
NO SUCTION COMING FROM BOTTOM OF VACUUM
even though the belt isnt broken you should replace it also make sure the height is raised up on the nozzle. try dropping a marble through the hose to double check there is nothing stuck ( the attachment hose and the small hose that runs to the floor )
Sep 07, 2008 | Hoover U5507900 Elite Rewind Bagless...
Vacuums Logo
234 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
