Question about Hotpoint Aquarius WD640 Front Load Washer/Dryer
How do I replace the door seal on my Aquarius WML 520?
  • 1462 Answers
SOURCE: Hotpoint Aquarius WF440 Repalce Door Seal
no need to remove front panel
remove clamp that holds boot to cabinet and peel away boot
take top off
undo clamp that holds boot to tub and pull boot off
lubricate slot in new boot that goes on to lip of tub
starting at top, insert slot onto lip of tub and work your way round in both directions pushing slot onto lip
refit clamp
push door boot onto lip of cabinet and refit outer clamp
test on rinse cycle for leaks (water level is higher
water will be a bit foamy till fluid is washed away
Posted on Sep 07, 2008
  • 13 Answers
SOURCE: leaking door seal on hotpoint aquarius
Where in the world are you?
If you are in the UK, I can recommend a supplier of spare parts for all manner of household appliances, white goods etc.
http://www.espares.co.uk/
If you are not in the UK, maybe they deliver elsewhere but I am certain there are many, many similar websites worldwide.
I have used these people for a Servis washing machine door seal, Electrolux vacuum cleaner bags, flame sensor device for my old Creda gas cooker and other things and found them very reasonable.
They provide a rating for the level of competence requried to do the job, 'one spanner' is very easy and 'four spanners' requires someone with much more practical ability. My own washing machine door seal was 'three spanners'.
I hope this helps - good luck!
Chris.
Posted on Sep 14, 2009
SOURCE: How do I change the door boot seal on a Hotpoint Aquarius WMA31N?
Ok - I will answer my own problem seeing as though I have now fitted it!
1. remove door (2 screws)
2. There is a tensioned wire loop holding the front part of the boot seal in position. - prize off the plastic cap at the 11 o'clock position, all will become clear and you will be able to remove the wire loop.
3. Remove top of washing machine (2 allen screws behind caps at the front.
4. Remove soap dispenser draw and any screws holding the front control panel and top of the door.
5. Remove bottom front plinth (just pull it off) underneath are a couple of screws holding the front panel part of the machine, remove these.
6. Remove front of machine giving you access to the steel band which locks the other end of the boot seal in position. Slacken this band right back using a nut-spinner screwdriver. Pull off the old boot and clean the lip ready for fitting of the new boot.
7. Fit new boot seal using a squirt of washing up liquid as lubricant if needed (mine didn't) to reseat the seal.
8. Refit and tension steel band.
9. Re-assemble front panel, ease boot back into front lip position then refit wire loop using a suitable pair of pliers/molegrips to crimp the retaining plastic cap back in situ.
Posted on Nov 02, 2009
  • 57 Answers
SOURCE: how do i remove and replace rubber seal on door of
Remove the lid and loosen the band internally holding gasket to tub, from the top. The front come off easily once the retaining band is removed. Just reversed the process to put on the new rubber.
Posted on Dec 09, 2009
apart4u
  • 213 Answers
SOURCE: need to fit door seal hotpoint aquarius wf220p
Follow these steps to replace your door seal:
For all Free appliance repair videos visit our VIDEO TUTORIALS
Disconnect all power to the machine first!!
1 Locate the outer clamp band securing the seal to the door rim on the washing machine and examine it carefully for holes or tears. Many can be prised off with a flat-bladed screwdriver they have a spring system holding them, but some have a tensioning arrangement that has to be loosened.
2 After removing the outer clamp band, locate the inner one securing the seal to the drum and establish how this is secured. It may be necessary to loosen a clip, or you may be able to prise the band off with a flat-bladed screwdriver. Some are like very large Jubilee clips that you have to undo usually from the top.
3 Once the clamp bands have been removed, use both hands to pull the seal away from the inner drum rim. Some machines have a water spout holes that will have to be lined up. Others have a drain holes.
4 Rubbing a drop of washing up liquid into the groove on the door seal/gasket that locates on the drum makes fitting the new seal easier.
5 the new washing machine door seal should be fitted by locating the drain holes at the bottom of the seal first then push it on with both hands working opposite directions towards the top. This is quite hard if you have never done it before.
6 refit the inner band remembering this must be tensioned correctly for it to be water tight.
7 now fit the outer band and the test the machine for any leaks,
All washing machine spares featured in this article are available at apart4u with more video help in our tutorial section.
Information provided is a guide only. aPart4u accepts no liability for any problems occurring whilst attempting any advice shown. If in any doubt about fixing your appliance, always contact a qualified repairer.
Posted on Jan 19, 2010
How do i remove the drum from a Hotpoint Aquarius WML 560 P
There is not much you can do to remove the drum of your WML 560 P Washing Machine...you can remove the bearings and door but you can't remove the drum personally. You'll have to take it in for service but here is a manual for you which you can read through to see if there is anything about removing the drum. Click on the link below to be directed to your Hotpoint Aquarius WML 560 P User Manual homepage...
Hotpoint WML 560 Instructions For Use Manual
Aug 26, 2014 | Washing Machines
How to remove the detergent dispenser drawer aquarius WML 520
Instructions for the machine, and specifically the detergent dispenser drawer, are here:
http://www.manualslib.com/manual/70853/Hotpoint-Wml-520.html?page=10#manual
It does NOT show how to remove the drawer. It is likely that the top of the machine must be "popped off" to do so. The best advise is to search for a Repair Manual if you simply must get the drawer out. I believe one of the manuals shown on this webpage may be the repair manual:
http://www.index-of-pdfs.com/hotpoint-aquarius-wml-520-user-guide-pdf.html
Most washing machine tops are simply a pressure fit that snaps on to the body. A firm grasp on the front sides of the top and a brisk pull may well pop it off.
Be sure to unplug the machine before you attempt any service!
Washing machines can be full of water AND electricity. That is most certainly a recipe for one, big, hydro-electric
Aug 04, 2014 | Washing Machines
Why does my hotpoint aquarius WML 720 will fill up but will not wash where would the filter be
you may have a bad door switch should check with a multi meter. can also check ur water pressure switch and motor coupler or belt if applicable
Jul 13, 2014 | Hotpoint Washing Machines
I have no power to a Hotpoint Aquarius washer, Model WML 730. Is there a line fuse and if so where is it?
Chance is its the two pole off/on switch or door interlock , check switch first.....
Mar 03, 2011 | Washing Machines
Hotpoint wml 540g the fault is the machine starts then the door light goes of and on ,it restarts then door light goes out and it flashes 4 extra function lights on the front panel ,and i have to switch it...
In a word 'yes'!
Either the interlock requires adjustment if that is physically possible on your machine or the sensor requires checking and possibly replaced.
For me this is a rare quick answer- I normally rant on............................... :-0)
John C
Feb 28, 2011 | Hotpoint Aquarius WD640 Front Load...
Cant download manual for wml 504 could you please email the link my email is rdp.51@hotmail.com thank you
cant find cleaning filter for my washing machine number wml504 make aquarius can you help thanks
Feb 19, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
Replacing door seal
Try washing the seal with jiff and a scouring pad in warm water.Depends on how well it is ground in.
You may have to replace with new seal.
slimjim1
Nov 25, 2007 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint Aquarius WD640 Front Load Washer/Dryer Logo
225 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
