Question about Whirlpool AWM5145/2 Front Load Washer
AWM 5145/5 starting program then stops, to water going in. Changed both inlet vales and still no water going in. Pump is working etc.
  • 4 more comments
  • dave82452 May 23, 2011
    Many thanks, is this a difficult item to replace, is it part of the main control panel behind the selector dial?
    Dave
  • dave82452 May 24, 2011
    Hi, I have swapped out the pressure switch from another almost new machine I had in the garage and it is still not filling with water after initial selection of program. The pump activates to ensure the drum is empty and then nothing. Any ideas?
    Hi Daniel, there is no blockage in the hose. I can hear the solenoid clicking at the back of the control unit but nothing else is happening. Perhaps the ECU has an issue?
    Hi, the other machine I have in the garage has a 599/03 ECU and this one is a 599/04. Would it be worth swappping them out to see if it makes anty difference?
  • dave82452 May 25, 2011
    Daniel, thanks for all your help. I have rep[laced the ecu and it still behaves the same, it starts as if it is going to fill with water with a slight surge from the water valve then nothing. I will p[robably have to call out an engineer.
    Dave
    Daniel, I regress. I decided to do a final check on the physical and electrical connections on the bottom end of the pressure hose. The middle connector was not properly seated into the clip. Must have been this way from factory. I have repalced the original ecu and all is well. All I need to do is re-build the machine in the garage. ;-o
  • 4,323 Answers
Hi
As the water inlet valve is already replaced and everything else works fine the issue seems to be with the pressure switch located inside the control panel that is bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Posted on May 23, 2011
  • 2 more comments
  • Daniel Scott
    Daniel Scott May 23, 2011
    You are right...it is part of the control panel however, you can buy it separately
  • Daniel Scott
    Daniel Scott May 24, 2011
    Did you check the hose connected to the pressure switch? You need to check the pressure hose connected to pressure switch for blockage or water in it. Hope this helps...
    Daniel
  • Daniel Scott
    Yeap that will work
  • Daniel Scott
    Daniel Scott May 25, 2011
    Alright great
My Whirlpool AWM 8120 front loader washing machine stops after working 6 minute in lcd panel show FH what the problem please ans? tanks tian from indonesia
F/H:
Condition
No water detected entering machine or Pressure switch trip not detected.
If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed.
Or
If the control has turned the water valves on and after 8 minutes the flow meter has detected 10.5 gallons of water passing through it, but has not detected the pressure switch trip, the valves will be turned off and the error code will flash.
Check/Repair:
Press PAUSE/CANCEL twice to clear the display.
If there is no water in the unit:
1. Make sure that both valves at the water source(s) are turned on all the way.
2. Check for plugged or kinked inlet hoses or plugged screens in the inlet valves
3. Verify inlet valve operation
If there is water in the unit:
1. Verify Drain pump operation
2. Pressure Switch Hose is in good condition and properly connected to Tub and Pressure switch
Verify there is not a siphon problem
Verify wire harness connections to:Inlet Valves, Pressure Switch, Drain Pump, Flow Meter, and Central Control Unit (CCU)
Check all hoses for possible leaks
Verify pressure switch operation
Verify flow meter operation
Verify CCU operation
If this is intermittent, it would be very hard to determine the cause.
I myself have rarely run into this issue, and when I did, it was mainly caused by low water pressure into the water from the customers water supply, or clogged inlet water valve screens.
Make sure you don't have any duct tape or something around your drain pipe, it needs that air gap to prevent siphoning.
Jun 14, 2015 | Whirlpool Washing Machines
Why can't i do a cold wash on this bloody machine?
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
If the water flows though the inlet then the flow pressure should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Check this link to replace the inlet valve:
http://www.espares.co.uk/advice/washing-machines/a/7/1408/how-to-replace-the-inlet-valve-on-a-washer-dr.html
Check the flow on the inlet. reverse if the hot line is used, clean both the filters, change the program selection to another cycle.
Jan 21, 2013 | Whirlpool Washing Machines
Whirlpool AWM 336 won't spin
Jan 14, 2013 | Washing Machines
Inlet valve non operational on whirlpool awm 258 nordic
Please check on the voltage on the inlet valve , check on the controller if there is no voltage if not the inlet valve is faulty.
click this link: inlet valve
Jul 27, 2012 | Whirlpool Washing Machines
Whirlpool awm 329 not starting
Finally after the wash the drain valve will be activated, the water is allowed to come in to rinse and then finally the dry spin with the drain valve/pump activated so as to drain off all the water from the clothes during the spin.
Make sure that a fault in any of the cycle will relate to the specified action, so check the command from the program module and then the executing device be it the valve or motor or pump.
Please check the link below:
http://www.repairclinic.com/Washing-Machine-Troubleshooting?red=Washing-Machine-Repair-Help
Jul 25, 2012 | Washing Machines
Whirlpool awm 5100 stops in random parts of multiple cycles. The unit fills rinses spins and drains however it will not run a complete cycle without stopping. I have checked the door switch bit it seems...
Problem seems more linked with the program controller unit. Also it is possible that the machine does not start off the cycle because there are errors or back feedback from the inputs. For the program to start up the main program controller must initiate the INLET valve to open up and allow water to flow into. If this does not happen then the voltage at the inlet valve must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
If the water flows then the flow should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Jul 06, 2011 | Whirlpool Washing Machines
Whirlpool washer AWM 5145/5 water wont drain/stops on B
I had same problem twice, the first time there was a sock in the filter at the front adjoining the pump, the second time a sock had got in the pipe under the drum which is more awkward to get to but is possible if you have the tools to remove the back plate and are ok at diy, there is a spring tension clip on the pipe which comes off quite easily with a pair of pliers.
Jan 14, 2009 | Whirlpool AWM5145/2 Front Load Washer
Whirlpool awm 5145/4
FILTER MAY BE BLOCKED IRE CLOSE BYE
Nov 27, 2007 | Whirlpool AWM5145/2 Front Load Washer
Whirlpool awm 5145-2
The filter area permanantly holds water, this is correct,suggest that you have a faulty inlet valve. Regards Engineer
Jul 26, 2007 | Whirlpool AWM5145/2 Front Load Washer
Whirlpool AWM5145/2 Front Load Washer Logo
111 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
