Question about Car Audio & Video
AMP GRD, WHAT DO I DO ALL MY SPEAKERS ARE DISCONNECTED
  • 2,098 Answers
Hi p3rty8,
"Amp Grd" protect in other brand is an error code for short and overload. Once the power applied to the unit and shorts sensed by the processor the unit will automatically turned to "Amp Grd" to avoid further damaged to other parts. Most shorts is in the supply voltage (B+, Vcc) line and most common caused is the sound output IC (mounted in heat sink). This part is responsible for amplifying the audio from the pre-amplifier stage and will feed to your speakers.
If you have a knowledge in disoldering and soldering technique, I would advice you to pull-out this part and then try the unit. If the "Amp Grd" error code is gone then you must replaced this IC with a new one to back your unit in normal operation again.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Posted on May 23, 2011
Hi. I was just looking over the amp i have. Its a Boschmann 2500FX,300watt I was just woundering what the: GRD, B+ and REM stands for. If you could help me it would be good Thank you
GRD is ground, or negative, B+ is battery+ or positive, REM is remoter turn on and is used to turn the amp on. Most aftermarket radios use the blue/white wire to turn an amplifier on. On rare occaisions where there is just a blue wire, that would be the wire to turn your amp on.
Jun 14, 2011 | Car Audio & Video
Mitsubishi magna car stereo wiring diagram
I want to clear the letters amp grd from my stereo so as for sound to come from the speakers please help?
Aug 29, 2010 | Car Audio & Video
LCD display AMP GRD whenerver i insert cd or turn on either AM or FM
It looks like if you have an amplifier hooked up,the ground is not properly connected.
Aug 05, 2010 | Car Audio & Video
Why does my radio say amp grd when there is no amp hooked up and it was playing just fine tell now
sounds like you need to check your speakers and/speaker wires to make sure you don't have a short to ground or bad speaker. if those check out, you may have a bad output ic inside of the deck.
May 30, 2010 | Clarion DXZ438R CD Player
My clarion cd player in my boat was working fine now it says amp grd. I have looked but i see nothing unhooked what can i do to get sound out of my speakers?
Remove all the speaker wires.
Power the radio back on and verify it is not the radio at fault.
If it powers up, check the speakers with a Digital Multimeter set to OHMS 20x.
Each speaker should have a resistance of 4 ohms. (or 8 in some cases)
Any variance (+/- .5ohms) means the voicecoil is blown, and replace that speaker.
Thanks for using FixYa - a Very Helpful rating is appreciated for answering your FREE question.
Jul 14, 2009 | JVC AM FM CD DET FACE CAR STEREO
I got a stock ford JBL amp with no wiring diagram i need to know what wires are what i have tryed to test for the power wirer but no luck.
ok on most amps there are two sets of wire ports one for speakers & one for +12v,grd & 12v remote start if you look over each port it will say what port is for what wire if it is in a connector it gets slightly more complecated what you do is with a vm check from wire to chassis ground [like seat bolts] 12v with key off when you cet power isolate wire then turn key on till radio comes on then do the same test for 12v isolate that will be remote start then turn key off &check from the first wire to other wire for ground to find speaker wires connect a regular peace of wire to chassis grd & touch the wires you will here the speaker pop be sure not to hold the wire on long cause it will blow the speaker
Jun 04, 2009 | JBL BP1200.1 Car Audio Amplifier
Loss of sound to passangers side speakers
?s amp ?cap r using?brigd 2ch 4ch hook w/ fused sep. mainly chk grd! amp on carpet over heats. vent it!
Mar 22, 2009 | Car Audio & Video
Car Audio & Video Logo
417 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
