Question about GPS
Dear FixYa, I have a Garmin Nuvi 1370 which I purchased in August 2010. When I powered it up this morning, being the first time since I used it extensively in September 2010, everything worked well (good satellite reception, good vehicle tracking, it knows the destination coordinates and can pin them down on the map, local roads have not changed for years so updated maps are not required), EXCEPT that the "Calculating" mode is on forever and I never get a route or an ETA. Do I have a hardware problem, a software problem, or has my navigation subscription expired (if I have one, don't think so)? Please help. Thanks :-) Best regards Lasse Kaiser
  • mr_lasse_kai May 23, 2011
    That did the trick - Thanks :-)
    The solution was perfect! - You saved my day (finding my way around Copenhagen, Denmark)
    President:
  • 1,514 Answers
There may be 2 problems with your satnav. First try clearing the trip log. This builds up and can really slow down the satnav calculating the route. To clear it;
Press TOOLS
Press MY DATA
Press CLEAR TRIP LOG.
Secondly you need to keep the operating software up to date. It shouldn't be very out of date since September 2010 but it's free and it's a good idea to update it regularly. To update your operating software;
  • Go to http://www8.garmin.com/support/collection.jsp?product=999-99999-27 and download and install webupdater to your computer.
  • Connect your satnav to your computer with the mini USB lead and run the webupdater program.
    It will search for updates to your software. Install any updates. It will also give you the option of downloading new voices. They don't have to be downloaded unless you want them. Don't download too many as they only take up space.
This should solve your problem.
Also don't let your battery die by leaving it away too long unused as garmin's satnav batteries are notorious for going completely flat and refusing to take a charge again when left unused for long periods. Finally don't start your car with the satnav plugged in as this causes a surge which has ruined many garmin satnavs.
Posted on May 23, 2011
Tip
Garmin Nuvi 1370 Hard Reset Models: Nuvi 1200, Nuvi 1210, Nuvi 1240, Nuvi...
Models: Nuvi 1200, Nuvi 1210, Nuvi 1240, Nuvi 1245 , Nuvi 1250, Nuvi 1255, Nuvi 1260
Models: Nuvi 1300, Nuvi 1300, Nuvi 1310, Nuvi 1340, Nuvi 1350, Nuvi 1370, Nuvi 1390
Models: Nuvi 1410, Nuvi 1440, Nuvi 1450, Nuvi 1490
Does your Garmin Nuvi 1370 Freeze at Loading Maps?
Does it lock up or stop working?
This tip will describe how to perform a hard reset of the device, and how to backup your 'Favorites' in case the hard reset erases them. The next step in fixing your Nuvi when it doesn't start properly is to update its system software using Garmin WebUpdater.
A hard reset (or Clear All User Data) has been known to resolve unit quirks and strange behavior. It's generally recommended to perform it after a firmware update but is not required by any means. However, if you're seeing quirks and strange behavior with your unit after the firmware update, it is a good idea to do a hard reset of the unit.
Backup and Restoration Procedure for Favorites:
The Hard Reset procedure has been known to delete your Favorites, so back them up beforehand.
  1. From the Nuvi drive, copy '/Garmin/GPX/current.gpx' to a backup location on your computer.
  2. After the hard reset, copy your backed up 'current.gpx' from your computer back to the '/Garmin/GPX/' folder on the Nuvi, but be sure to rename it 'temp.gpx'.
  3. On the next power cycle, the Favorites will be read from 'temp.gpx' into the non-user accessible memory area on the Nuvi where they are actually stored.
Perform the Hard Reset:
*Note that this will clear all user selected settings on the unit
  1. Power the unit off.
  2. Remove the battery and wait several minutes.
  3. Install the battery.
  4. Press and hold (and continue to hold) the bottom-right corner of the screen while powering the unit on.
  5. Continue to hold the screen until the "Do you want to erase all user data?" prompt appears.
  6. Press "yes" and the unit will reboot. This resets all your location settings and user preferences.
If possible after the hard reset, let the unit sit outdoors in the open for about 30 minutes or so to let the unit re-acquire the satellite almanac data.
You have now performed a hard reset of your Garmin Nuvi 1370 series GPS unit.
I hope that helps.
__________________________________________
Garmin Nuvi 1370 Manual Download
Garmin Nuvi 1370 QuickStart Download
Garmin Nuvi 1370 Webupdate
Garmin Nuvi 1370 Favorites Backup
on May 15, 2010 | GPS
Tip
Garmin Nuvi 1370 Favorites Backup and Restoration Procedure Models: Nuvi...
Would you like to back up a copy of your Garmin Nuvi 1370 Favorites and Waypoints?
  2. After a hard reset or loss of data, copy your backed up 'current.gpx' from your computer back to the '/Garmin/GPX/' folder on the Nuvi, but be sure to rename it 'temp.gpx'.
I hope that helps.
Tip
Garmin Nuvi 1370 Webupdate Models: Nuvi 1200, Nuvi 1210, Nuvi 1240, Nuvi...
Does your Garmin Nuvi 1370 GPS get stuck or freeze at startup, or when loading maps?
Looking to reflash the firmware / system software for your Garmin GPS device?
Replacing the brains of your Garmin GPS is the surest way to resolve freezing, hanging, and erratic behavior. Keeping the system software and firmware in your Garmin GPS current and up-to-date is also the best way to keep it performing well.
Your GPS may not start properly at all, and display a 'System Software Missing" message. This tip will describe how to restore your Garmin Nuvi GPS system software using Garmin Webupdater.
  1. The first step is to download the WebUpdater software.
  2. Plug in your Nuvi GPS into your PC with the USB cord.
  3. Run the WebUpdater program to install it to your computer and update the system software of your GPS.
Your Garmin Nuvi should now be running as good as new.
I hope that helps.
Tip
Download Garmin Nuvi 1370 Quickstart Manual
Have you lost your Owner's Quickstart Manual for your Garmin Nuvi 1370 GPS?
Would you like a digital copy of the Garmin Nuvi 1370 Quickstart Users Guide for easy searching of terms and quick reference?
The Nuvi 1370 Quickstart manual is available free in pdf format, just follow the photo link below:
I hope that helps.
________________________________________________
Tip
Download Garmin Nuvi 1370 Manual
Have you lost your Owner's Manual for your Garmin Nuvi 1370 GPS?
Would you like a digital copy of the Garmin Nuvi 1370 Users Guide for easy searching of terms and quick reference?
The Nuvi 1370 manual is available free in pdf format, just follow the photo link below:
I hope that helps.
Tip
Garmin Nuvi 1370 Hard Reset Models: Nuvi 1200, Nuvi 1210, Nuvi 1240, Nuvi 1245...
I hope that helps.
on May 15, 2010 | Garmin nuvi 1370T Car GPS Receiver
Tip
Garmin Nuvi 1370 Favorites Backup and Restoration Procedure Models: Nuvi 1200,...
I hope that helps.
Tip
Garmin Nuvi 1370 Webupdate Models: Nuvi 1200, Nuvi 1210, Nuvi 1240, Nuvi 1245...
I hope that helps.
Tip
I hope that helps.
Tip
I hope that helps.
GPS Logo
300 people viewed this question
Top GPS Experts
Are you a GPS Expert? Answer questions, earn points and help others
