Question about GE Refrigerators
I have a GE Model GSS22SGRF refrigerator. The freezer is cold but the freezer isn't staying cold. Any suggestions?
  • GE Master
  • 43,501 Answers
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Posted on May 24, 2011
Where is the evaporator fan located in a ge gss22sgrf
In front of the evaporator coil in the freezer compartment, behind the fan guard. you must remove the rear freezer panel to access it.
Mar 30, 2014 | GE (PSS26MSRSS) Side by Side Refrigerator
GE refrigerator isn't cold at all
you need to have the frig defrost the passage is in the back going from the frig to the freezer so if it is frosted in the back than the air is not moving correctly
Sep 18, 2012 | GE Refrigerators
GE fridge not cooling. freezer working ok. compressor fan not working
This is an odd thing to hear. Normally when the condensor fan (}compressor fan) Isn't running the freezer is the one who's temperature rises and the fridge stays about the same. I would strongly suggest looking at the main control board, just for the simple fact that 9 out of 10 times thats the root of the problem
Jun 06, 2012 | GE 18.2 Cu. Ft. Frost-Free Top-Mount...
I have a ge side by side refrigerator/freezer and i'm hearing a sizzling sound from the freezer side. Sounds like water is hitting the heating element causing a sizzling noise. Should I empty th
If you are sure the sound is coming from the freezer side, then yes you should empty the frrezer and take off the rear shield. While the heating element is normally encased in glass or plastic. Water droplets hitting an electrical connection could also cause a sizzling sound.
Feb 03, 2012 | GE Refrigerators
Only half of the freezer and half of the fridge are working
heat rises and cold stays down on the lower shelves,if the evap fan motor isn't blowing this will happen,next time send the brand name and model number off of the machine,open the freezer door,if you don't hear the fan blowing you have a bad evap fan motor,all it does is the freezer gets cold,the fan blows the cold air from the freezer to the fridge section,also if the fan isn't working when you remove the back inside wall of the freezer if there's any ice melt it out with a hair dryer,unplug the machine before you start working on it,call your parts store,give them the model number and they will sell you the parts you need.
Oct 10, 2011 | Refrigerators
It seems that the wiring diagram show the hot/black side going to the defrost timer AFTER the cold control/thermostat. how does the timer keep running when the cold control isn't...
If your model is the PSS26MSRSS the defrost timer is built into the motherboard and will be completely electronic. Click here for the=> Service Manual And then click here for=> GE Profile/Artica Technical Information Now it is possible that the model listed here requesting a solution may have been listed incorrectly by auto generated model numbers and not by your fault, it just happens here at times. So if this is what happened then try again to provide a different model number. Here is how GE locates their model numbers, Click Here=>
GE APPLIANCE MODEL NUMBER LOCATOR'S
Refrigerators
Freezers
  • Chest Freezer
  • Upright Freezer
  • Either way I am here to help and if your model is the model listed you most likely are having problems with either the compressor start components or the motherboard itself. If you would like me to assist you more just let me know HERE or here on Fixya. Seems lately customers are having a little trouble navigating the site due to so many new changes. Hope this helps, so let me know, Thanks, Sea Breeze
Sep 02, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
I have a GE Profile counter depth French door refrigerator bottom freezer and I keep getting frost in the freezer. The seal on the door isn't as tight as the seal on the refrigerator but no cold air...
Where are you getting frost at? Is it on the back wall in the freezer? if so - your problem may be a defrost issue and in that case you would need to hire a professional appliance repair technician to service your refrigerator.
Please rate us 4 thumbs up!!!! Tips Provided by: GOFAR Services, LLC - We repair refrigerators and all other appliances in the Houston, Katy, Spring and Woodlands, TX areas!
Aug 29, 2011 | GE Profile PDS20SFSR Bottom Freezer...
Top shelf of both regrigerator and freezer not working
i have a side by side refrigerator is all ice bihind the cover evaporator
Apr 03, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
GE gss22sgrf sidebyside water dispenser does not work, ice does
these unit have a problem with the water line freezing inside the freezer door. ge makes a tape style heater that goes inside the dispenser area to give just enough heat to keep it from freezing the water line.
you can try to change the freezer settings, warmer, clean the coils at the back of the unit and leave the freezer door open for 20-30 minute to allow the door to warm up and that will be a temporary fix to allow water to flow until you can get the heater kit.
Jan 09, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
195 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
