I have problem with my washing machine when i switch on the machine it display shows PE.
    Sniper:
  • 59 Answers
PE error relates to the fill level of the washing machine. The fill level sensor is a pressure operated device. There is a sealed air line that goes from the bottom of the tub to an air pressure sensor. As the tub fills, it compresses the air in this air pressure sensor. When the tub is filled to the level selected on the dial, the sensor stops the fill cycle.
This air line can be plugged or the sensor itself can be faulty. This air pressure sensor is usually located near the top of the tub just under the top cover. If you can locate it, disconnect the air line from the pressure sensor and blow through it - it may be blocked by lint and soap from several washing cycles. There may be a filter in this line to help prevent this blockage. But the filter may have become blocked itself.
Posted on May 23, 2011
Fault PE....How do I replace the pressure sensor on an LG fuzzy logic 5kg wf-t502 top loader and where can I purchase this part?
PE Means pressure sensor error this spares is very rare to defect 1st check full pressure sensor the wiring harness any damage or wire cut means the error will show in display
Mar 26, 2015 | LG Washing Machines
ERROR CODE PE
The error code PE indicates that the half load motor is defective.
Jan 02, 2015 | Washing Machines
Washing machine whirlpool topload showing pe
This question has been answered before here in Fixya. Check the link below if it answers your question. When the washing machine is started it shows PE on the panel and nothing...
Dec 08, 2014 | Washing Machines
Getting pe error
Whirlpool Washing Machine Displaying Fault Code PE The part(s) or condition(s) listed below for the symptom PE - PRESSURE SENSOR ERROR // Water level pressure switch error are ordered from most likely to least likely to occur. Check or test each item, starting with the items at the top of the page.
per https://www.repairclinic.com/RepairHelp/How-To-Fix-A-Washing-Machine/408-5--/Whirlpool-PE-PRESSURE-SENSOR-ERROR-Water-level-pressure-switch-error
b2kjqj
Dec 09, 2017 | Whirlpool Washing Machines
P.c.b. not working
Washing machine is showing error "PE" it's not a big problem you are washing machine is just fine.PE means error signal due to low voltage .Machine resumes functioning after the voltage comes back to normal.
Oct 21, 2012 | Whirlpool Washing Machines
PE error where E is blinking in whirlpool whitemagic
pe error on the machine is normally the pause in action. try pressing the start /pause button again to activate the wash program
Jun 23, 2012 | Whirlpool Washing Machines
I get a "PE" error
As you said in the question you are washing machine is showing error "PE" it's not a big problem you are washing machine is just fine.PE means error signal due to low voltage .Machine resumes functioning after the voltage comes back to normal.Thanks for your question.
Jun 19, 2011 | Washing Machines
Immediately after switching on my washing machine F65, its showing a display PE and is not working.please say me the procedure if any to rectify my problem.do the needful
hello,
what this f 65 code mean is an indication of loose of wire from the sensor reader from the connection
And the PE means that power error that is the loose wire will not allow the washer to carry out is function properly
what you need to do to fix up the problem is to unscrew (OPEN)the WASHER then trace the wire down to the power supply and also the panel connected to the screen clean all form of dirty and water on it fix up the wire that are disconnected from there position .
thank you and thank for using fixay.
Jun 10, 2010 | Whirlpool LSN1000LW Top Load Washer
Washing Machines Logo
125 people viewed this question
Top Washing Machines Experts
