Question about Seagate Barracuda 7200.7 200 GB Hard Drive
I have the seagate barracuda 7200.7 200 gbytes whats the part on the outside that the master belt cable hooks in to a circuit board can i change that my kid took it apart not the insides of the harddrive just the part or circuit board thing thanks ED
  • 1,179 Answers
You will need to get another circuit board from another Seagate Barracuda 7200.7 200GB Hard drive. Either ask your local computer shop or check local ads for sale. Like Gumtree or Ebay or the like.
A hard drive recovery centre may have this particular circuit board as they will use it to transfer your information from your current hard drive to a new hard drive. This may be another option available to you.
Take care!
damnor01
Posted on May 23, 2011
Barracuda (ST380215A) 80 GB IDE (ULTRA ATA) 7200.10 Hard Drive Problem While installing Windows Xp sp3 hard drive not detect @ partition screen System configuration is as: Processor:- AMD Athlon XP...
Seems like your hard drive is malfunctioning, try another HD. That 80gb is already obsolete and the circuit board might have some defect.
If you could pull out the underside circuit and clean the gold contact points and try it again, if still not working...... buy a new one!
Check also the jumper and cable it must be in the "master" configuration.
Hope that helps you out!
Thanks for asking FixYa!
Aug 09, 2011 | Seagate Barracuda (ST380215A) 80 GB IDE...
Hi guys, my seagate barracuda 7200.8 300 gb hard disk notworking. power is not coming to external harddisk, so i open the case connect it to lap by using some wires(dont know given by my friend), stil...
I have the same problem like yours right now. The on-board circuit of my Seagate Barracuda burned and I'm planning to buy new Seagate Barracuda with the same specifications, same model.. I will try to disassemble the circuit of the new one and connect it to the old hard drive to take a chance if it will work and retrieve my files. If it doesnt work, at least I try and I still have a new hard dist to store my new files.. If you want to do the same, you must be careful in handling the circuit board. It is very sensitive and can be damaged with just touching the components.. I recommend you to discharge static electricity of your hands by touching anything that is made of steel.. The steel will discharge static electricity, but still, to make sure you wont damage the circuit, just touch the circuit board on its sides.. Never touch any components, it will damage your circuit board.
Jun 22, 2011 | Seagate Barracuda 7200.10 250GB (7200rpm)...
Is Seagate Barracuda 7200.7 80 Gbytes a Sata Hard Drive or not?
Hello and Welcome to FixYa!
Yes this series of Seagate is SATA.
Concerned, Nooh.
Feb 17, 2011 | Seagate Barracuda 72007 SATA 80 GB SATA...
I need the driver of my Seagate Barracuda 7200.7 80 Gbytes Ultra ATA Model: ST380011A Thanks
you might have to physically unplug the disk drive then plug it back in this should activate the found new hardware wizard or
control panel administrive tools computer management device manger scroll to disk drives + to expand if you see your drive right click you will have options update driver ,uninstall,scan for hardware changes,properties in the properties tab you will have more options in the general tab you can troubleshoot, in the driver tab you can update driver,rollback driver,uninstall driver
hope this helps
Nov 24, 2010 | Seagate Barracuda 7200.7 ST380011A 80 GB...
Need to know where to set slave pin
The pin settings are nest to the power connector.
If the location is not shown on the label then it will be marked on the circuit board.
MA = Master
SL = Slave
CS = Cable select
Sep 28, 2010 | Seagate Barracuda 7200.7 ST380011A 80 GB...
Windows xp will not recognize my seagate barracuda 7200.10 although it is recognized in the BIOS. I pressed f6 during setup and it is asking about the Manufacturer-suplied hardware support disk. Where...
If you have one HDD set it to master with your jumper settings. Try again. If No go than change the cable connector. If SATA HDD than change the connector on the MOBO try another connector. Restart. If still no go than write back
Jul 30, 2009 | Seagate Barracuda 7200.10 320 GB SATA Hard...
Hard disk Not Detecting (Media Problem)
may be comming steps you solve your problem
check your bios settings on first bootable devices
check your ide or sata cable interfacing mother board correctly
check the power connections
also you want check this one is your os faulty,now you make master &sleve and boot anther hard drive
Jun 12, 2009 | Kanguru - 500GB Disk (Black)...
Seagate barracuda 722.10 light flashing but hard drive not runing,lots of data on it to retrieve,can i take it apart and run disk in cd/dvd drive or can i get new boards for it.and will it work if i change...
actually im fixing hardisk drive if you change the board it will work and spin. but the problem there is a serial protection of your disk and you cannot retrieve your files. now you have to troubleshoot the board. check fuse protect, rectifier diodes for 12v&5volts, and regulator.
Jun 10, 2009 | Seagate Barracuda 7200.10 500 GB SATA Hard...
My seagate barracuda 7200 b will not boot up. It has been operating fine for the last 8 months
i suggested you use NORTON DISK DIAGNOSTICS to repair the MBR(master boot record)the master boot record is bad and you can use winXP bootable nto repair the drive by pressing R after booting is completed.but you need to be able to use DOS prompt before you can do this
Jan 14, 2008 | Computers & Internet
Seagate Barracuda 7200.7 200 GB Hard Drive Logo
142 people viewed this question
Top Seagate Computers & Internet Experts
Computer Links
Steve
terminalcon
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
