Question about Philips SBCMD110 Consumer Microphone
I have designed and constructed a microphone amplifier circuit using LM301 with a line driver SSM2142 and a line receiver SSM2141.The circuit is supposed to pick up any voice/audio by the mic and send it via 100m Twisted Pair Cable to a PC for recording and analysis.I am using an omnidirectional Yodata Laptop Microphone,but i get nothing on the output.The circuit(amplification etc.) on its own is perfectly working but the audio/voice part is not,cracking my head.I have tried a ready-made Phillips microphone on my circuit and i works perfectly but the mic described for the job turns me down..Please help
2 Suggested Answers
SOURCE: No Sound Coming out my Microphone
This same thing happened to me. All I did was plug the mic into my keyboard, turned the mic volume to max, and turned the mic on. Then, I grabbed the part of the mic where the cord goes in, and started turning it. I turned it left and started hearing noise come out of the mic. I kept on doing this, until sound came out of the mic. I did this, and now the mic works again. Hope this helps!
Posted on Dec 22, 2008
No sound, flashing standby light
Hi
check it out if you are familiar in electronics
speakers cables
short circuit protection
overload
power output damaged
power supply outputs
if you have more info about i will be glad to help.
hope this helps a bit.
Jan 31, 2014 | Pioneer Elite A20 Direct Energy Design...
I have a Sony STR-DH810 7.1 channel receiver. Everytime I turned it on, it shows the channel for a while then turn to PROTECTOR the turn off by itself. How to fix this problem, thank you...
You must be having a power Amp output problem. There must be a short circuit in one of the amplifiers and that is triggering the protection mode to prevent speaker damage. You will need professional help for this since the circuit is complicated and so is the construction. Getting access to the under side of the circuit board for removal and replacement of the components is very difficult on all modern AV receivers.
Sep 26, 2011 | Sony STR-DH810 Receiver
I am thinking of replacing my now very old JVC AX 330 amplifier with a Marantz PM7003 amplifier and want to know if this is a suitable replacement in terms of power output etc.
You, sir, are a rare adherent to stereo-only electronics. Are you replacing it for cause (showing its age)? The PM7003 is only 2 x 70 watts like the JVC but it also has separable preamp/amps so you COULD upgrade or augment the power output with external amps and still control it all locally.
Of course, any current AVR's do that too and bring digital sources and multichannel audio to the mix for as little as the PM7703 may cost.
Jun 23, 2011 | Audio Players & Recorders
What is full meaning of the following codes in design and constructing an inverter-NE55,CD4013,JRC455,A733,IRFP150,1N4007,C945.
These numbers are the identification of some electronic devices that probably are being used in the inverter's circuit:
CD4013 - Dual D Flip-Flop integrated circuit
1N4007 - 1 A rectifier diode
IRFP150 - power MOSFET
A733 (2SA722) - PNP silicon transistor (low frequency amplifier)
C945 (2SC945) - NPN silicon transistor (low speed switching)
I could not find the devices marked JRC455 and NE55 - maybe they were not correctly marked, but there are some devices which have similar designations: JRC4559 is a dual operational amplifier integrated circuit and the NE555 is a time/oscillator integrated circuit.
You can download their datasheets from
http://www.alldatasheets.com
Hope this information can be useful!
Mar 09, 2011 | Electronics - Others
Mic receives a lot of static and then cuts out. After a few seconds it seems to repeat.
This could be due to interference from other devices.
You could try changing to a different frequency (there are 20 to choose from).
Also move the receiver away from any strong electro magnetic fields (hearing loop amplifiers, CD/DVD players, TVs) or large pieces of metal and in clear line of sight of the transmitter pack.
Set up the aerials so that they are at a similar angle as the aerial on the transmitter.
Only use xlr balanced cables with good quality screening to connect the receiver to the mixer / amplifier. Keep signal cables well away form mains electricity cables as far as possible.
Wherever possible use balanced xlr cables on all other equipment.
Feb 13, 2011 | Audio Technica ATW-R11 Microphone
Have a Shure SLX Wireless System. The only way the microphone SLX1 or SLX2 is if they are right up to your mouth. If you put the lapel mic on a persons tie you can't hear them. The transmitter is set to...
The Shure SLX2 hand-held microphone has similar performance characteristics to the much-loved (cabled) Shure SM58 vocal microphone. It has a 'cardoid pick-up pattern' intended for close work - being spoken / sung straight into the top of the capsule at no more than about 8 inches from the mouth of the user- to minimise feedback and extraneous noise. If you double the distance between the mouth and microphone the sound level will drop four-fold so distance really matters.
The SLX1 lapel/ lavalier is a semi 'omni-directiona'l pick up pattern microphone, which should work satisfactorily up to 12 inches from the speakers mouth, but closer is better. Always try to get your users to hang it about 6 inches below their chin, at most, and preferably with the top of the microphone capsule pointed upwards towards the mouth.
Here are a few other things for you to try:
  1. There is a volume (gain) knob on the back panel of the SLX receiver unit. Try turning this up to maximum (needs a small screwdriver)
  2. Make sure that both aerials on the receiver are fully extended at different angles to each other and in a clear 'line-of'sight' with the transmitter pack, with no large bits of metal in between which could block the signal. Ideally the receiver should not be more than 25metres from the transmitter. If distance is a problem locate the receiver near to the transmitter and run a balanced (xlr) cable to your mixer/ amplifier.
  3. The angle that the receiver aerials are at should be broadly similar to the angle that the transmitter antenna is at to optimise signal reception.
  4. Make sure the receiver is not located too close to other electrical equipment which may be interfering with the signal (especially voltage transformers, CD or DVD players and hearing loop induction amplifiers which have a strong magnetic field)
  5. Always use good quality batteries - Duracell Ultra or equivalent ( do not use rechargeable batteries as they seldom achieve optimum voltage)
  6. Check that the antenna is tightly screwed into the SLX1 transmitter pack and not damaged.
  7. The SLX2 hand-held microphone has an adjustable level switch inside the body - unscrew the top of the microphone to access it - switch to maximum.
  8. Another possible cause could be an impedance mis-match between the SLX receiver and your amplifier or mixer. There are two outputs on the rear panel of the receiver. One is an XLR (large 3 pin socket) this is LOW impedance and needs connecting to a low impedance input on your mixer/amplifier. You should normally be using this output even if your amplifier has a jack-socket input (use a proper balanced XLR to 6mm trs jack cable rather than a adapter plug). The other output on the receiver unit is a 6mm HIGH impedance, unbalanced, standard jack socket (labelled 'line in'). This would normally be to connect to a guitar amplifier which has a high impedance 'line level' input socket. If you are using this output you may need to use a pre-amplifier to get a big enough signal for a microphone.
You can find the Shure SLX user manual here http://www.shure.com/idc/groups/public/documents/webcontent/us_pro_slx_en_ug.pdf
Jan 27, 2011 | Shure SLX1 Body-Pack Transmitter for...
Can I use the SR701 as a public address amp? Does not seem to be a labelled microphone input.
You would need a microphone preamp/mixer to connect a mic; or a pre-amplified microphone that has a Line Level output.
http://en.wikipedia.org/wiki/Line_level
http://www.google.com/#hl=en&rlz=1R2ADFA_enUS360&q=pre-amplified+microphone&aq=f&aqi=&aql=&oq=&fp=baa94940edcea411
Whatever you do, be very careful to not have a feedback loop between the microphone and your speakers or you can kiss your tweeters goodbye.
Feb 24, 2010 | Onkyo TX-SR701 Receiver
How do I wire vacume tubes and resestors together and what other parts are necessary?
Hi. It all depends on what you are constructing, and the type of vacuum tube you have.Most tubes are used as amplifiers so if you were making an audio amp an input device like a microphone will be needed, a power source to drive the tube (sometimes a very high voltage! ) and an output device like a loudspeaker.
I'd suggest checking out some basic electronics tuition websites to find out what else you might need, and maybe experiment with small transistor circuits first - they are a lot safer.
Jun 29, 2008 | Vacuums
4inch display driver
hi dear
here
http://web.jfet.org/inGrid/
http://www.mcamafia.de/nixie/ncp_en/ncp.htm
oke
Mar 22, 2008 | Computers & Internet
Can I use a microphone with this receiver?
There would have to be a jack in the back labeled "Microphone" for this to be possible. I found a picture on the web showing the rear and am not seeing this at first glance. Do you have your owner's manual? The only way to do what you want is to amplify the mic with a mic driver and then plug it into one of the line inputs. A trip to Radio Shack could help here. Hope this helps.
Nov 11, 2006 | Kenwood VR-407 Receiver
Philips SBCMD110 Consumer Microphone Logo
51 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
