Question about Philips Televison & Video
I clearlly wrote my DVD player is locked and i need the code to unlock a PHILLIPS HTS3051BV / F7 C DVD PLATER NOT A FLAT SCREEN TV SET
  • 1 more comment
  • peter marshall May 23, 2011
    SOMEHOW I DONT SEEM TO BE GETTING ANY INFO THAT IS WORTHWHILE
  • peter marshall May 26, 2011
    i have the remote supplied with the unit. how do i get to settings from the home menu, and then to advanced setup?
    regards
    peter.
  • peter marshall Jul 03, 2011
    i need to unlock the region code my player is locked on region 1 and i need to be able to play DVD`s from all regions. i was living in the US and have now moved to Ausraalia
  • 373 Answers
If you have forgotton your pin then go to Advanced Setup to Ratings Lock and enter 4737 to clear original pin. Follow prompts and enter new pin.
Posted on May 26, 2011
  • 8,197 Answers
Ok by looking in my paper work for this unit the factory override code is 4737. Here is how to enter the code.
Yo uwill go to the Home menu then go to Settings then go to Advanced setup then to ratings lock to enter the code. Once the code is entered you unit should be unlocked.
If you have any questions please ask.
Dynex Flat Screen 22" w/DVD
When the picture goes out, try to open and access the TVs menu using the Dynex remote. if the menu fails to open up you can bet there is a problem with the backlight on the TV. Letting the TV rest and then it working again indicates heat as the source of the problem. Check to see if your still in your 1yr warranty or if you have a protection plan at best buy, the TV needs help.
If the Menu were to still open, you can blame your cable/satellite set top box.
Jun 05, 2011 | Dynex DX-L42-10A 42 in. LCD TV
Unlock area code for LG DV450 Dvd Player
Make sure the TV is set to the DVD player.
Press OPEN on the DVD player.
Press PAUSE on the remote.
Enter the code 314159 on the remote.
The TV screen will show a prompt for region code - press 0 for multiregion.
Switch the DVD player off and wait for 30 seconds.
Switch player back on and it should now play DVDs from any region.
Mar 07, 2011 | LG Televison & Video
I bought some DVDs at amazon.com, but I live outside the region code area witch the DVDs are supposed to work. I live in code area 4. I need someone to find a code to region 1. I have a Phillips home...
This player is relatively easy to change to region free. Please complete all of the steps below to unlock your DVD player.
Please note: Unlocking any DVD player may invalidate the warranty. Unlock sequences may not work with some firmware updates and some DVD players have been damaged through failed attempts to unlock them. Unlocking your DVD player is done at your own risk.
Unlock sequence for the Philips DVP 3020:
1. Switch on your TV and DVD player;
2. Make sure the TV is set to the correct input for the DVD player;
3. Remove any disc from the DVD player and close the disc tray;
4. Press the "SETUP" button on the DVD player remote control;
5. Use the LEFT/RIGHT arrow keys to highlight "PREFERENCE";
6. Enter 1 3 8 9 3 1 using the numerical keys on the Philips DVD remote control;
A pop-up menu will appear on the TV screen.
7. Use the UP/DOWN arrow key and choose "0" for all regions;
That's it. You should now be able to watch DVDs from all regions on your player. It is also a good idea to switch the player to standby and then switch it back on before trying any discs.
This is a verified unlock sequence for the Philips DVP 3020. If it doesn't work the first time, switch the power off and start again at step 1. If it still doesn't work, it is likely that you have updated your Firmware to a new version and this unlock sequence does not work with your firmware version
If you need further assistance, please reply to me from within this page and let me know which firmware version you have installed in your DVD player.
Regards,
BElectric.
Jan 28, 2011 | Philips Televison & Video
Flat screen to dvd connection help!
It depends on the TV.
On my Phillips TV this is switchable via the TV setup menu, and you get no sound with HDMI unless you change that setting.
The reason it's switchable is that the HDMI input is usually common with one of the component-video inputs (AV3 on mine). (cost saving move)
Thus if the menu is set to hdmi, then the audio goes thru hdmi. If it's set to 'component' then it goes thru the RCA patch cable.
Oct 07, 2009 | Televison & Video
Check regional code
the easiest solution is to unlock your dvd just goole the name ask for unlock codes it happened to me now its unlocked plays all dvds hope this helped ken
Aug 30, 2009 | Televison & Video
Connect TV to dvd player
hdmi, S-video or jack are the most common cables delivered with the dvd, you can plug an amplifier between tv and dvd for a dolby system.
Turn on the DVD player, the TV and Set your TV on "AUX" or "Ext" with the remote.
Dec 23, 2008 | Philips TV Tuner Video Capture PCI Card -...
Unlocking Phillips PET722
I found this on a website devoted to unlocking DVD players.
You need an OneForAll6 remote (URC 7560)
  1. Press DVD device button (set remote to DVD)
  2. Press and hold MAGIC until it flashes 2x
  3. Enter Setup Code (0539)
  4. Press MAGIC again
  5. Enter 085
  6. Enter 222 222 005 255
  7. (should be displayed)
  8. Press PLAY
for the remote "SBC RU880":
  1. Press and hold 1 and 6 until SYNTH is displayed.
I hope you find this helpful
Dave
Nov 12, 2008 | Philips TV Tuner Video Capture PCI Card -...
Dvd problems
Could Try all DVD codes on internet?
Try this example for Bush DVD Model 2039
switch on tv & DVD player.
open dvd tray/ no dvd in.
press PROG on dvd remote.once only
press ENTER 3 times
region codes should be displayed.
use up/ down buttons on remote to select-
region 1 for USA / region 0 for all regions/ 2 for uk.
press STOP to confirm.
Open/close to exit.
Is that the right one for your set?
If not , go to ALL DVD codes.
M carter/ RESTORATION.
Jan 17, 2008 | Bush DVD2038 DVD Player
Samsung Remote Issues
if the tv is a new tv along with remote take it back to the supplier it should still be on warrant.good luck
Apr 18, 2007 | Samsung (BN5900218A) Remote Control
Televison & Video Logo
114 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
