Question about Refrigerators
Refrigerator wirpool. Ispracontrols 08032407R5 T55. Often for some seconds it a click click click hears itself that it comes from the elettronoc controls Ispracontrols, the same noise hears when is pressed the button for the water. The lamp of the low temperature is always in function and the part dosen't help!!
Hello I have the same problem can you help me fix it
Posted on May 21, 2013
2 Suggested Answers
SOURCE: Need Front Control Board, Kenmore Refrigerator Model 106.4410230
Solved it through parts isolation and identification.
Posted on Apr 06, 2009
Refrigerator is not getting cold
Well I would like to say that this fridge is fixable but.
I was told by three different repair men.
Because it is a sealed system there is no fixing it. It can not be recharged. If the thermostat is bad you are luckier then I was.
I have sent to wirpool that I will never buy another of their products again. I really hated getting ripped off $2200 and they had no solution for me but. Sorry, can't be fixed.
Apr 06, 2014 | Whirlpool GX5FHTXV (248 cu ft) Bottom...
My refrigerator is a Kitchenaid KSRG25FKSS05 and still runs but not cooling. I hear some kind of relay click and then click again after about 10 seconds. Then I don't hear it click again for a few minutes....
refergerant is not causing this problem. when the comp starts up and the bottom fan also starts up and the fan in the freezer comes on / this alll happens whe the cold control said we need more cold . so it sounds like the one that won't come on is the comp . and the clicking noise is the thermal control shutting down. then when cooling tryes to restart. . the kit you need is 8201786 this is called a start device and comes with instructions .. cost about $70.00 . easy to install . mm hope this helped and thanks for the model # .. and for ysing fix ya ..mm feed back pls
Nov 17, 2010 | KitchenAid KSRG25FKSS Side by Side...
Freezer not working
Good day,
Remove the back cover on the bottom and locate the compressor. See if the clicking sound is coming from it.
If so, there are usually 3 components pressed onto the pins of the body of the compressor. You have to remove the protective cover first.
The components are the protective overload disk, start relay and on some models a start/run capacitor.
You can take the components after prying them off the pins of the compressor and take them to an appliance parts house. They will usually check them for you. Replace any that check bad.
If they all test good then you will need the services of a professional to check the compressor itself.
If the noise is coming from another area, please post back.
May 20, 2010 | Amana ARB2217C Bottom Freezer Refrigerator
Whirlpool refrigerator model ED25PQ. Interior warm
possibly the relay on compressor is bad. the relay will need to be removed. shake it, if it rattles and or particles fall out of it, it is bad.
Jan 08, 2010 | Refrigerators
Compressor only stays on for 30 seconds which is not long enough to completely cool refrigerator all fans work and coils are dust free
if unit is coming on for a few seconds and then u hear a click, you may have a bad compressor relay. pull it off the compressor and shake. most times u will hear a rattle of junk. if so its bad.
Jul 25, 2009 | Kenmore Refrigerators
Apr 05, 2009 | Kenmore Refrigerators
KitchenAid Side by Side
if you hear a clicking like the compressor is trying to start, like a clicking on and off this sounds like it could be your start run relay trying to kick your compressor on. if this is bad it will continue to click, and your compressor won't start. unless your mechanically inclined this might be the time to call a service tech. the start run relay switch sits on the compressor behind the fridge.
Mar 12, 2009 | KitchenAid (KSRD22FKST) Side by Side...
Refrigerator has gone warm
First you need to evacuate the system by tapping it with a valve, then you cut out the compressor tubes and disconnect the wires. Braise the connections on the new one, run the vacuum pump and put new refrigerant, check for proper operation and temperature. Without proper tools might be difficult !!
Nov 30, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
Maytag refrigerator clicking noise and stopped working
How long a period of time have you noticed this noise? If it just started and the refrigerator just stopped it could have entered its defrost cycle. When the defrost heaters come on you may hear the heat causing some expansion. After a few minutes(18-22) the defrost cycle ends and the refrigerator will restart.
May 30, 2008 | Jenn-Air JCD2389G Side by Side...
Refrigerators Logo
1,287 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
