Question about LG Computers & Internet
Dvd reed but CD NOT REED - LG Computers & Internet
    Problem Solver:
  • 16 Answers
The Problem Is in Laser Beam
Posted on May 23, 2011
ASUS N82Jq dvd rom cant reed disc
Re-boot your laptop, check the DVD drive with another CD/DVD. If if doesn't work, check the device manager for valid drivers. If there are no driver issues, clean the laser with a clean soft lint free cloth. Failing that look for a new DVD unit.
Oct 14, 2013 | Lifetime ASUS N82Jq Replacement Laptop...
Console getting erratic numbers and motor will not run. i have checked the reed. my father does not remember how tech support had told him to reset console. Was working intermittenly before we checked...
If the console takes batteries, replace them. If this does not work or your console does not require batteries, check the reed switch or optic sensor. Reed Switch: Unplug the treadmill and remove the motor hood cover. The reed switch is mounted on the frame next to the front roller pulley. There is a magnet glued into the front roller pulley. When adjusting the reed switch, make sure it is pointing directly at the magnet. Move the tip of the reed switch within 1/8" of the magnet. Also, check to see that the wire is not damaged, and is connected to the console
fINALLY: Test the Optical Sensor if have it
http://www.youtube.com/watch?v=E-q-uS4t6so
Aug 21, 2011 | Nordic Track NordicTrack Treadmill, A2550
I have a dewalt air compressor model d55155 will not bulte up any presure changed the cold start valve and the reed valves but not the reed valve plates it seemes like like now i have air coming out the...
If you have oil coming out of the oil fill and dip stick you most likely installed the reed plate upside down. Usually it says this side up or there is an arrow pointing up on the reed plate.
This is a good sketch of compressor and reed valve assy.
http://www.about-air-compressors.com/images/1055.gif
Usually the reeds are on top of the plate facing downward. If you have just a reed disc.. then the disc will need to be inverted.
Thanks for Choosing FixYa.
Kelly
Aug 18, 2010 | Dewalt 2 Hp 4 GAL Air Compressor
LS code - manual says reed adjustment but no indication what the reed is?
A reed switch or in some cases a speed sensor is locate by the front roller/pulley it could cylindrical or square looking.First you need to unplug the unit, then remove motor shroud inspect the reed switch to pulley distance ( no more than 3 credit card thickness) also inspect the pulley to see if the magnet is still attached to it. make the necessary adjustment. plug in the unit start it up. If it give you the same code then replace reed switch!
Mar 12, 2010 | Exercise & Fitness
How do u put on the mouth piece and make a sound?
If you are talking about a single reed instrument such as a saxophone this is how you proceed. First you have to moisten the reed using water or your own saliva. You can do this by placing it in your mouth and rubbing both sides of it with your tongue. Take particular care not to damage the tip of the reed. Take the mouthpiece in one hand and lay the reed on the flat part of the mouthpiece with the thinnest part of the reed towards the tip of the mouthpiece flatside down. The tip of the mouthpiece is the opposite end of the mouthpiece from the one that you put on the instrument. You can't mistake the two. The end that goes on the instrument is like the opening of a tube. With the reed laying flat on the mouthpiece gently slide the ligature ( clamp with one or two screws ) over the end of the mouthpiece and the reed. Take care once more not to damage the end of the reed. Line the very tip of the reed up with the very tip of the mouthpiece leaving a sliver of the mouthpiece showing. Holding the reed in position move the ligature along the reed and mouthpiece so that it is covering the bark part of the cane reed about 1/8 to 1/4 inches from where the bare part of the reed starts. Some mouthpieces have a guide line marked on them. Once the ligature is positioned you can tighten the screws. Do not overtighten them. They just need to be snug enough to secure the reed in position. The reed should be in the position I described in order to speak or vibrate easily. Now you can slightly fold your bottom lip over your bottom teeth and insert the mouthpiece and reed into your mouth. Your top lip should not be folded over your top teeth. Your top teeth should rest on the top of the mouthpiece and your bottom lip should provide a cushion between your bottom teeth and the reed. You should have as much pressure applied between your top and bottom teeth so that someone cannot easily pull the mouthpiece out of your mouth. You will learn how much pressure to apply to affect intonation and produce a good sound with practice. Now with the mouthpiece in your mouth you can blow through it to produce a sound. Your mouth should provide an airtight seal around the mouthpiece if you followed my directions. You can steady the mouthpiece with your hand while try to get a sound. If all you produce is a sqwawk that shouldn't discourage you. What you are trying to do is make a piece of wood vibrate in a controlled manner using breath pressure and your jaw muscles to control the vibration. Do not use too much pressure or the reed will be clamped shut at the tip and not be able to vibrate. You should have at least an inch between your bottom lip and the ligature as to how much mouthpiece should be in your mouth. Once you can consistently make a sound then you can proceed to putting the mouthpiece on the gooseneck with the gooseneck properly installed in the saxophone. You should rub a little cork grease on the cork of the gooseneck before putting the mouthpiece on it. The distance that the mouthpiece goes on determines the tuning. Your lip pressure also affects the tuning but a lot less in comparison. You can vary your lip pressure rhythmically to produce vibrato. Most sax players now hardly use vibrato or use a slow shallow controlled vibrato on notes at the end of phrases. Another thing to note is that to start with you should use about a number 2 reed unless your mouth is particularly sensitive and then I wouldn't go anything less than a 1 1/2 for a little while until you get used to the vibrating sensation and the feeling of your bottom lip between the reed and your bottom teeth. Hope this helps. By the way I have been playing since 1963 and I hope you enjoy it as much as I have.
Aug 24, 2009 | Rico Tenor Sax Reeds Box of 10
I have a craftsman 1hp 4 gal compresor. It's not building pressure and air is pumping out of the air filter not in???
sounds like reed valves are bad,sometimes you can take the reed valves and flip them over for short fix,best to put new one in unit.
Jun 27, 2009 | Craftsman 1 Hp, 4 Gal. Air Compressor
Won't reed CD
thanx
XD
if it is a audio cd itunes must act like that
but u can get to my computer then u will find the contenets of the cd inside it!!
plz tell me if i helped u so i can help u further
and rate me as good as u can
Nov 18, 2008 | Apple Genuine Pioneer "SuperDrive"...
Problem with my dvd burner
did you try using a lens cleaner cd. that might help sometimes
Apr 14, 2008 | Pioneer DVR-111D (DVR111DBK) DVD RW Dual...
Computers & Internet Logo
19 people viewed this question
Top LG Computers & Internet Experts
Michael Vincent Cruz
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
