Question about Sony CCD-TRV338 Hi-8 Analog Camcorder
MOISTURE? It began by saying I had to clean the tape. That lasted about 2 days then today it will not take in the tape and I get a picture of a water drop on the screen. Is that moisture in the camera? How can I fix that? What about with a blow dryer?
  • 10,594 Answers
For Moisture problem, dryer is an option and can be used. For head cleaning purpose, use any good quality or Sony Video Head Cleaning Cassette V-8
Posted on Aug 15, 2008
SOURCE:
HOW DO YOU REMOVE HEADLIGHTS FOR CLEANING THE LENS ?
Just tape the headlights off with tape and rub some crest toothpaste do it in a circular motion then wipe them off with a towel and water it will clean your headlights
Jun 04, 2014 | 1998 Chrysler Sebring
Kitchenaid superba oven
It is very possible that moisture from the cleaning has caused the ignition switches to make enough resistance to cause the burners to spark. It usually goes away after the stove has dried out. If it continues after a day or so one or more of the ignitor switches may need replacing.
Nov 20, 2013 | Ovens
My 5 month old LG dishwasher is making a high
Good day-
I am the proud owner of a LG LDF6920WW. I bought it 10-2008 and it developed a high pitched sqeel (HPS) exactly 2 years and 3 months later. It first occurred on a monday and repeated on the following Wednesday. After the water filled the machine and the swirling, pumping, cleaning cyale began, the HPS began and lasted until the drying cycle. I searched the internet and determined that this HPS was occurring anywhere from 5 days of being purchased, up until the 2 year mark. I was weary of believing that a motor would fail in a five day period as well as last for up to 2 years, so I "Googled" parts for my model and looked at the scematic or parts break down chart. Refering to the chart, I began to disasemble my dishwasher after removing it from the cabinet and taking it to the garage.
I focused on the sump assembly. I removed all parts, motors, baffles, bladders, check valves, etc. I thougroughly cleaned all pieces and parts with windex and a scotch/sponge. I removed all food and debris from all surfaces and gaskets. I cleaned the main body cover by using a low pressure hose and alternating cleaning the top and bottow. I made sure not to rip the micro screening. Upon re-assembly I used high heat, automotive bearing grease to lubricate the seals where motor shafts protruded through them. ****Important**** I set the clutch setting at 3 on my electric drill to screw the assembly back together. I also disassembled the water inlet valve and the float assembly on the left side, exterior of the dishwasher and cleaned that completely out. I flushed all hoses as well.
I put it back in, connected all water, electricity and back-flow devices. The dishwasher is once again silent. All motors and bearings seemed fine. During tear down, the only problems I found were: 1) A lot of debris in several places. 2) dry gasket to shaft surfaces.
Jan 19, 2010 | LG Dishwashers
My keyboard is glitchy.
If you don't want to buy a new keyboard, you can open your keyboard and leave it to dry for a couple of days. There's still some moisture in the keyboard that's why this is happening. As soon as all moisture has been removed from the keyboard, it should work fine. But there's no guarantee since the board might have short circuited already.
Jun 17, 2009 | Computers & Internet
Canoe full of water
you can take the battery and the back off the device and place in completely submerged in a bag of white rice and leave it in there for 1 to 2 days this will help absorb the moisture, this should fix it if the water did not damage the circut boards if the water damaged the circut boards then the device is fried
May 30, 2009 | LG VX5300 Cellular Phone
1999 Town Car began running very rough - suddenly.
When cleaning your engine, water/degreaser went down the spark plug ports. Try using a air compressor blow gun to remove the moisture from around the spark plugs and boots. The water was causing the engine to misfire on 3 cylinders at first and as the ports started to evaporate the moisture, the less misfiring was occuring. Dry thouroughly and hopefully coils do not have damage to them. Also check to make sure the boot is making good contact with the spark plug.
Mar 23, 2009 | 1999 Lincoln Town Car
No picture on the screen in my 2001 Olds Silhouette
You need to clean the heads on this machine. You can use the cleaning tape and it will be good to go as long as the tapes you put in there are clean from dust. I hope this helps. Don't forget to rate my answer.
Feb 18, 2009 | 1999 Oldsmobile Silhouette
Flashing tape!
this is because there is lot of condensation taken place inside.. so keep the eject tray open and most important in a clean dry place say atleast 3 to 4 days...
Aug 02, 2008 | Hitachi VME545 Camcorder
Pictures have lines
some people say that winter storage does this.it is ,apparently,to do with moisture and the residue it causes when it dries.to all of you i recommend putting your cameras in a sun-lit window for 20 minutes a day for 3 to 5 days.if it does not work,try a tape head cleaner.
Dec 18, 2007 | Canon ZR800 Mini DV Digital Camcorder
Blurriness!
Water is a possible cayse Take batteries and memory card out of camera Take a cup of rice or salt put into a cotton bag or knot into a cotton handkerchief. Put the knotted handkerchief and camera into a zip shut poly bag or an ordinary poly bag and tie it shut. Then put bag into a warm dry place for a couple of days The Salt/rice will draw the moisture out of the system gently. Come back in a week tell if it worked
Jul 14, 2007 | DXG Technology DXG-305V Digital Camera
Sony CCD-TRV338 Hi-8 Analog Camcorder Logo
56 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Al Rush
Ekse
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
