I have no sound from my 3210 speaker. All electricity supply is ok, but I recently had to wipe my harddrive and wonder if I'm missing something in the computer. i have a dell 5150 and run windows XP. i'd be really grateful if you can help.
    Sniper:
  • 79 Answers
You must not have all of your drivers installed. I have found the drivers for you, however, on the Dell.com website.
Here is the link: Drivers
I hope that works!
Posted on May 23, 2011
Testimonial: "many thanks - the link is v helpful and I shall try and download - this has saved me alot a time - great response!"
Bought online...doesnt boot all the way up say insert bootable disc...what does that mean and or what kind of disc do I need??? Aspire 5250-0639
sounds like the Hard drive doesnt have a operating system installed (seller may have wiped or replaced the harddrive), or the hard drive is damaged or missing(removed), - you would need a install dvd for windows or a bootable or installer dvd for linux . and replace the harddrive if it is damaged or missing
the Bootable disk its talking about
is its next attempt at starting a operating system from a cd,dvd or usb source after trying for a harddrive startup- but failing to find an operating system
Dec 13, 2014 | Computers & Internet
Laser printer makes light clicking noise when idle
When idle is potentially the fuser unit, after heating and cooling. However the print quality issue associated with the clicking sound could indicate an electrical issue. The HVPS maybe faulty causing the print quality issue (due to dependant parts) and the electrical click. In any case I would recommend calling Brother and finding the nearest authorised service agent.
Oct 20, 2012 | Brother Mfc-9840cdw All-in-one Laser...
No sound on my tv
check the connector on the speaker might get loose, if ok re soldered cold soldered component parts in the amplifier section of the main board.
Aug 15, 2012 | Sharp Televison & Video
Where's the Memory gone?
Follow these steps::
  • Apply De-fragmentation on your system
  • Delete all temporary files
  • Run disc clean up
  • Fix registry errors.
Also use a system utility tool like Reginout to fix registry errors and remove unwanted, junk files from PC.
Apr 21, 2012 | Microsoft Windows 7 Ultimate 32 bit Full...
Where is the inverter board located on the element flx-3210? Is it somehow combined with the powersupply? I've taken the TV apart and have found everything except a part that resembles an inverter...
Yes, inverter circuitry is combined in one board together with the power supply circuitry. It is beside the connectors of the power supply board to the mainboard. You can see two high voltage transformers, these are the one producing high voltage feeding the bulbs...
Nov 01, 2011 | Element Electronics FLX3210 32 in. LCD TV
My subwoofer is making a strange kind of noise n frequently it goes off by itself..this happened since the left front speaker started making some crakling noise every time n later the situation aggravated...
Hi
Good day. In regards to your issue your speaker connector might be grounded and there's no way to fix that i''m sorry. But try to do this step first to be sure
1.Make sure your speakers are plugged in, turned on, and properly connected to the
computer
. You've probably checked this, but it's amazing how little problems like this (or the
computer's sound being muted) manage to confound people.
2. Plug the speakers in to another computer, if possible. If the speakers work with the other
computer, proceed to the next step. If they don't, you've probably got a problem within the
speakers themselves.
3. Check sound card driver
> Open your start menu (right-click on the "Start" button and choose "Explore"), and find the "My
Computer" icon. Right-click on it and choose "Properties" from the submenu. Click on the
"Hardware" tab and then the "Device Manager" button.
> Expand the "Sounds, video, and game controllers" heading to find your sound card. The name
will depend on what sound card is installed on your PC. It will most likely have a name
containing "audio." It should look something similar to the example above. You'll know
immediately if there is a major driver error because an exclamation point (!) will show over the
card's icon.
> Double-click on the name of the sound card to open a new window. In the new properties window
click on the "Drivers" tab. If there is no "Drivers" tab then you chose the wrong sound device. Go
back and try again. On the "Drivers" tab, click the "Driver Update" button. Follow the Wizard's
onscreen instructions to update your driver. You can also contact the manufacturer of your PC
for the most recent audio drivers. They can usually be found online.
> If you already have the most recent driver, click the "Uninstall Driver" button. Then restart your
computer. When you restart your computer, the driver should reinstall automatically. If it does
not, install it manually with software (or a download) from the manufacturer.
4. Check the "Windows Troubleshooter". On the "Drivers" tab mentioned in the step above,
there is a button for troubleshooting the device. Click on that button, and follow the instructions
on screen.
5. Check the sound card itself. Properly shut down your PC and then disconnect all cables on
the back of your PC, including the power cable. Open up the CPU, making sure to touch a
grounded metal object (a doorknob or metal desk will work, for example) before opening up the
case. This will discharge any static electricity you have built up, which could damage your
computer.
> Locate the audio plug on the back of your PC. The sound card should be in the corresponding
location on the inside of the PC. Remove the sound card and put it back in. The Microsoft site
has detailed directions for installing a sound card; to remove one, simply do the reverse. Once
you have the sound card back in, reattach the cables you unplugged earlier and boot your PC
It this steps didn't work you might consider getting a new one. Hope this help you in someway and thanks for visiting Fixya. Have a wonderful day.
May 22, 2011 | Altec Lansing ACS 251 Computer Speakers
I recently wiped my hard drives and reloaded XP Pro and did all the windows updates including service padk 3. The computer has a motherboard sound device and not an expansion sound card and the motherboard...
I hope the problem isn't with your speaker. Have you tried the speaker on another computer or on a DVD player etc..? If it works, well can you adjust the sound from the sound settings or from the "Sound" icon on the Taskbar on your Desktop? If you can't adjust sound from Sound Settings (under control panel) or from the Taskbar's sound icon, then you might have missed to install the sound driver. Try reinstalling the sound driver and make sure the installation is successful. I also hope that you didn't do anything on your motherboard. You can also try plugging in the speaker jack to the front audio port or to the rear or vice versa. These are the things you may try at the moment. Let me know if you need further help.
Good Luck.
Thanks for using FixYa.
Apr 29, 2011 | Audio Players & Recorders
My Orange amp recently stopped working, as in no sound
Likely the power amp section has had a failure. There are likely several bad components and it will take an experienced electronics person to weed out all the bad parts.
The light has little to do with the condition of the unit. It MAY only indicate that power switch is on or that one of several voltages from a power supply is present.
Mar 24, 2010 | Orange Rockerverb Rk100htc 100watt...
Acer Aspire 5720 sound not working
that means the guy or someone who replace the new harddrive didn't to a good job on restiall a new window vista for you, just simply go acer.com and search your model, redownload the sound card driver.
that's it.................
must be sound card driver problem.
Dec 29, 2009 | Acer Aspire 5720 Notebook
Replaced harddrive and dvdroom wont recognize in bios
Goto bios menu. And change the setting on hard drive and cdrom. It could be it still set in the old configuration. Try to set it in auto detect. Then save the setting. Then goto bios once again to check if the settings doesn't change. Restart again and wait if something you didn't expect still happens.
Leave a comment if this solve cd rom detection.
May 12, 2009 | Gateway M-6750 Notebook
691 people viewed this question
 Grubhead
Grubhead
