Question about Tally Dot Matrix T2265C Printer
Lipi tally t2265 printer showing hardware alarm with code:+0692 113----- 114032+0375+0687.. please do the needful in getting rid of this issue..
5 Suggested Answers
SOURCE: please help
I am already faced this problem, This Problem is due to Bad Head cable. Repaced that cable, your Problem will be resolved
Posted on Nov 24, 2008
  • 114 Answers
SOURCE: Tally t2155 - Showing "Hardware alarm wrong board"
change the logic board. your problem will solve.
Posted on Jan 31, 2009
gooditguy
  • 6 Answers
SOURCE: hardware alarm
One likely cause is a blocked optical sensor . Try these three things, in order, and check the printer after each:
- Pick up the printer, turn it upside down, and shake it. If 40 pounds is too much for you to lift, get a friend to help. Or, better yet, get a friend to do it without your help.
- Using an air compressor with a blow gun attachment, direct air to the paper path entry and exit, and to the sides of the platen. Then look for torn-off tractor feed bits of paper in the crevices. You may need tweezers or needle-nose pliers.
- Take the cover off and repeat the previous step with the air compressor. This is tricky. Use this as a last resort, as the printer may not be usable after a troublesome disassembly. Do this only if you're going to have to replace it otherwise.
Posted on Nov 16, 2009
  • 29 Answers
SOURCE: sir my tally 2250 printer
try to change the aga gears, or clean hp sensor,
Posted on Nov 18, 2010
Problem for lipi 6312 tally genicom line printer my printer shows an error (hammer voltage 1)
problem for lipi 6312 tally genicom line printer my printer shows an error (hammer voltage 1)
Apr 20, 2010 | Tally T6218 Matrix Printer
Our tally 2280 Dot matrix has an alarm code 025609413032 What causes this to be displayed on the 2280 screen.?
check out this FAQ page for the hardware alarm codes:
http://support.dascomeurope.com/index.php?option=com_content&view=article&id=295%3Ahardware-alarms&catid=234%3Afaqs-t2265-t2280&Itemid=57&lang=en
Mar 19, 2010 | TallyGenicom 2280 Matrix Printer
LIPI T-6090 IS SHOWING "SELF TESTING" DISPLAY ON MENU.WHAT IS PROBLEM?
LIPI T-6050 IS SHOWING "SELF TESTING" DISPLAY ON MENU.WHAT IS PROBLEM?
Nov 10, 2009 | Tally Line Matrix T6100 Printer
Tally t2265 'check ribbon' hardware alarm... carriage moves ok, 2 new ribbons ...that came from other machines,,,, ribbon drive seems fine, could it be encoder strip??? please help!
The check ribbon message on the 2265 indicates the printer is detecting problems with moving the print head. You have ruled out the ribbon as being the cause of the problem by using ribbons from another printer.
Befor suspecting other components check the pritner model, if the printer is a 2265+ check to ensure the correct ribbon is used. Note the ribbon for the 2265+ is different to the 2265 ribbon. The 2265+ has a ribbon sensor to detect the ribbon moving. If the printer is a 2265+ the part number for the ribon should be 062471.
If the correct ribbon is used the problem could be the timming strip which could be dirty or warn. Try cleaning this and check for damage.
The problem can also be caused by a dirty or lubricated carriage shaft, the carriage shaft should be clean and dry running - Keep clean of any type of lubricant.
The problem can also be cused by the timing station on the carraige, the carriage motor.
Jul 03, 2009 | TallyGenicom 2280 Matrix Printer
Please help
Aug 20, 2008 | Tally Dot Matrix T2265C Printer
Jul 29, 2008 | Tally Serial Matrix T2155 Printer
Tally 2250 Matrix printer
tally printer give hardware alarm on every problem gear aliment is very important in tally cheak for function sensor
Jul 21, 2008 | Tally T2250 Matrix Printer
Tally Dot Matrix T2265C Printer Logo
504 people viewed this question
Top Tally Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Tony
Are you a Tally Office Equipment and Supply Expert? Answer questions, earn points and help others
