Question about Dishwashers
All the dishes come out very wet - Dishwashers
  • 561 Answers
Possible, heating element is defective or other electrical problem and is washing with cold water.
the drying process is casued by the heat generated, this causes the water on the plates to evaporate and collect at the bottom.
if the water is not being heated this can not happen.
try setting your next wash to the hotest setting and see if the problem is the same
this will indicate so.
I hope this was useful.
Posted on May 23, 2011
The cause is one of 3 possibles.
1. The heating element is faulty.
2. The water sensor on the heating circuit is clogged with debris
3. The switching relay on control board is faulty
Fixes:
Lay dishwasher on its side and remove bottom panel. Will need care to remove water spill connections from inside cover and put to one side.
1. Heater element can be identified as a sausage-shaped assembly with the characteristic ceramic insulators on the ends of the element. remove cable connections and test with an ohm meter.Resistance of around 48 ohms says it is probably OK
2. Follow the heater cable connections a few cms and one is connected to the water sensor. disconnect and remove it. By blowing gently down where the hose normally fits on the sensor you should here the switch click on and off. If not, clean out all the debris, wash in hot water and try again. Test with ohm meter which should show the switch open and closing
If all seems OK then replace bottom cover making sure water spill connectors are replaced first.
3. To replace the switching relay requires basic soldering skills. From the front of the machine, pull down lid and undo all the screws (6) holding the control panel in place. to the right is the control board.
To the right of the board is a large black component some 30mm x 20mm x 10mm. This needs to be replaced by a similar component. In my case, I could not find a unit which would fit on the control board so I bought an alternative and soldered wire tails and tucked it in alongside the control board. Remember to use heavy cables on the mains switching side as these take the heater current.
Posted on Dec 02, 2015
I have a haus slimline dishwasher and the water is not heating up when its washing. Is there a way to cure this please
Posted on Jun 16, 2011
Why are dishes wet when cycle completed?
The appliance repair man attempted to solve all problems by replacing the control board. He may have overlooked a defective heater for drying the dishes.
Sep 03, 2015 | Dishwashers
Ld 14aw3
Most dishes in any dishwasher are still wet when cycle is finished. The heat built up in the dishes during the washing cycle is what causes the water to evaporate when the machine stops.
If you want to accelerate the evaporation, simply open the door very slightly so that as the hot air escapes it causes the dishes to dry quicker.
Aug 04, 2014 | LG Dishwashers
Dishes still wet upon end of cycle
Check if the heater is working. This can be done by checking if the dishwasher has steam and dishes are warm when cycle is complete. Also check if the Rinse aid has not finished. Make sure the Rinse aid dosage is not at too low.
Jul 31, 2014 | Electrolux Dishwashers
Why do i need a trivet instead of a wet towel?
Trivets are made of temperature regulating materials which prevent the burning or ruining of the surface where the dish/pan/pot is placed. A wet towel, instead, will easily transfer heat thru the water in it and heat up very quickly at contact with a hot surface or object, consequently burning anything it touches. Never grab a hot pot or dish from the oven with a wet towel!
Jul 16, 2013 | Home
I'm looking for a dishrack that has room for all my dishes and will drain well (not just make the other dishes all wet).
i like the first one from this top ten list the best. http://www.realsimple.com/home-organizing/organizing/kitchen/dish-rack-00100000076215/index.html
Jan 14, 2013 | Home
Clean dishes are wet
1)please check the rinse chemical passing correctly.
2)check the boiler heater working.
Jan 08, 2010 | Bosch 24 in. SHU5305UC Built-in Dishwasher
Dishes come out wet
possibly a blocked drain hose or washer pump is going bad
Jun 22, 2009 | Ariston Technologies L63 Free-Standing...
KITCHENAID DISHWASHER WONT REPEATEDLY WONT RINSE DETERGENT OFF
Fist what detergent are you useing is it dishwasher detergent and second the dishes wet and stemy how long do you wait after the machine has completed the cycle before opening it
Jan 21, 2009 | KitchenAid 24 in. KUDP02CR Built-in...
Dishes are ALWAYS WET!!!
If the dishes are made of plastic they will be wet , they don't retain heat when in the drying cycle!
Aug 10, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
Dishwashers Logo
670 people viewed this question
Top Dishwashers Experts
Owen Barnes
