Question about Dualit 31213 3Slice Toaster
My toaster has suddenly stopped working - none of the heating elements come on - I have changed the plug fuse but it is still not working at all - it just suddenly stopped.
  • 561 Answers
I can only imagine one of the elements has broke and so the current can no longer flow.
check all the elements while unplugged to find a break.
not sure if this can be repaired.
the only other thing would be the thermostat is defective.
I hope this was useful.
Posted on May 23, 2011
Why did it suddenly stop working?
The Auto Head Quartz Control or the quartz heating element failed.
Nov 29, 2015 | Bosch Styline Collection Toaster...
My black & decker tro964 is not heating
That may sound like a stupid question, but is it plugged in?
Have you tried to plug in the toaster on a different power outlet?
If there is a ground fault switch where the toaster is plugged in (that's those outlets which have 2 buttons on the front, one labeld "Test" the other usually labeled "Reset") unplug the toaster and push the "Reset" button and try the toaster again. To test, if the power outlet, were the toaster is usually plugged in, is working, try a hair dryer or any other device on that outlet.
Its most likely cheaper to replace the whole toaster than to replace the heating elements, for about 40 $ since that's the price of your toaster on some websites.
Jan 06, 2014 | Black & Decker TRO964 Toaster Oven
As soon as I pushed the slider down with the bread there was a loud bang/flash and which resulted in the fuse blowing.Havent tried it again
The siptoms you describe is logical and it happent when the wire of the heating element have been brake and since this have live electric power when it touched the metal body of the toaster then you have spaking and automaticaly burning the fuse. So fir you can use this link to find out which element is broken , the you can buy a new one from ebay which they are in good price and replace it as per istructions they will send with element and also using the above link.
Nov 08, 2011 | Dualit 20247 2-Slice Toaster
Out Dualit toaster keeps blowing the fuse. It's
Probably one wire Loosen up or a wire from one heating element have cut off and is contacting the metal body of the toaster. You need a good visual insect of your toaster, you may use a flush light to see inside the electriacl elents and also open the bottom base to insect the wire conections to the heating element.
I beleive one or more heating elements is the problem and you need to replace them.
Good Luck
Feb 01, 2010 | Dualit CTS4E 4-Slice Toaster
Russell Hobbs Toaster has just stopped working
get your volt ohm meter out unplug it and disassemble it check your heating elements if there is no resistance the elements are bad. ONLY if you are comfortable with ac voltage!!! turn your meter to check ac voltage VERY CAREFULLY make sure nothing is shorted plug toaster in press toast button down. this should send voltage through thermostat to the coils . if you measure voltage across toaster switch when it is depressed the switch is bad. check your thermostat same for it if there is voltage across it it is open (bad).
Jan 12, 2010 | Toaster Ovens
Heating element no longer works. is there a fuse or is it the coil that's the problem?
I had the same problem and discovered it was the plug on the heating element was loose. I'd check continuity with a ohm meter across the coil. If it shows a closed circuit there isn't anything wrong with the element itself and could be as simple and cheap as tightening up the connector.
Dec 28, 2009 | T-Fal Avant Elite OT8085002 Toaster Oven...
Krups Toaster Oven elements stopped heating up
this is all to common . what thought happend did happen . the control board went bad and the elements where stuck on . inside there is a thermal fuse ,it blew out and saved you from haveing a fire but now the oven is dead . if you replaced the fuse it would just do it again and the board cannot be bought so your out of luck . on your next oven stay away from electronic controls . i am shocked you got 3 years out if it ,most go bad mutch sooner
Feb 26, 2009 | Krups FBC1 1600 Watts Toaster Oven with...
Russell Hobbs 9376 Classic 2-Slice Toaster
Possibly a GFI on an outlet of the same circuit as the toaster needs to be reset?
We had the same problem and so came here. When I read "replaced the fuse in the plug" my husband asked about the outlet GFI switches (he replaced the outlets last year, so he remembered they had GFI switches). One GFI on the toaster's circuit had "blown" and so needed to be reset. Before relegating the toaster to the recycling bin, check the it by plugging it into an outlet you know is working.
Dec 27, 2008 | Russell Hobbs 9376 Classic 2-Slice Toaster
Dualit 31213 3Slice Toaster Logo
315 people viewed this question
Top Dualit Kitchen Appliances - Others Experts
Ross Keen
Piyal Perera
Piyal Perera
Joseph Hoffmann
Are you a Dualit Kitchen Appliances - Other Expert? Answer questions, earn points and help others
