Question about Kenmore Elite 45986 Front Load Washer
Kenmore tumble action washing machine
When the water empties out of the washer after the wash cycle a blue/grey sluggish grity material comes out also, this happened twice
    President:
  • 1,952 Answers
Dust in washing powder do,nt worry
Posted on Aug 24, 2008
Need to replace water pump in Frigidaire tumble action front loading washing machine. Parts are hard to reach/get to. Is there a step by step for the process available?
After unplugging the machine, turn it around and remove the rear cover, After that all the parts are relatively easy to access and it will be obvious how to replace the water pump.
Feb 13, 2011 | Frigidaire 14 Cycle Tumble Action Washer
Was wondering if the washer is supposed to fill to certain level at wash cycle?
Yes. On top loading machines, it is very easy to see. On front loading machines, not so easy to tell. Front load machines fill to a very low level, (which is why you should only use 1 to 2 tablespoons of HE soap with them) then when they begin to tumble (wash motion) the clothes absorb water, causing the water level to drop, resulting in the fill of additional water until the original water level is acheived again. This process generally takes several times to get all the clothes saturated and the water level to stabilize. Additionally, water valves may cycle on and off several times as the machine adjusts the water temperature, even if you were running an empty washer through a cycle. Gentle cycles will use more water, as more water = less abrasive scrubbing action. Normally, using front loading machines, you will not see much if any water through the door window.
Jan 02, 2011 | Washing Machines
I have a kenmore washer that does not drain and spin at the end of the wash cycle....Kenmore Super Capacity 3.5...Quiet Tumble Action...Easy Access
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 02, 2010 | Frigidaire ATF6000ES Front Load Washer
We have a Kenmore 3.5 Super Capacity Quiet Tumble Action Wash Easy Access. The spin cycle works however the water won't drain and our laundry is soaked. Help...
It could be either the pump or a clog in the discharge hose. Take a shop vac and attach it to the discharge hose to remove the water from the machine. Remove the pump housing and run a wire down the discharge hose to check for a clog. If there is no obstructions, reattach the pump housing and remove the pump motor. Run a spin cycle and see if the pump motor turns.
Aug 27, 2010 | Kenmore 3.5 cu. ft. Front Load Electric...
Water level adjustment
You don't. Front load washers use only a very small amount of water. They fill a small amount, tumble a bit, resulting in water being absorbed into the clothes, which drops the water level in the tub. The washer senses this and adds more water, which repeats until water level stabilizes. The only way to get more water on wash cycles is to use delicate cycles, which use more water, resulting in a more gentle wash action. Remember that due to the low water consumption of front load washers, you should only use one tablespoon of HE detergent per cycle. (even less if you use 2x or 3x concentrate.) This is a FixYa solution. Your washer is working as designed.
Oct 23, 2008 | Whirlpool GHW9100L Front Load Washer
Drum doesn't move or spin
kenmore tumble action washer model#417.44152400,
Washer is approximately 3 years old. Will not drain or spin. When it tries to spin, clicking noise heard inside of unit. Would a clog insie the lines disable the spin cycle ?
Oct 18, 2008 | Kenmore 43142 Front Load Washer
Frigidaire Tumble Action Washer
I called in an electrician/plumber - thanks !
Jul 01, 2008 | Frigidaire 14 Cycle Tumble Action Washer
Frigidaire Tumble Action Washer won't move to the next cycle
your pump is blocked or faulty a way to check is pull your washer out put your outlet hose to the ground placed either in a bucket or out the door if water comes out pump is faulty if it doesnt than its blocked were your outlet pipe goes into back panel is were your pump is make sure washer is switched off undo tip up undo clamp water will come floding out better of doing this outside if it comes out of pump than your pipe is blocked
Aug 13, 2007 | Frigidaire 14 Cycle Tumble Action Washer
Kenmore 2 Way Tumble Action Front Load Washer
no thats two different problems. The rubber piece (boot) forms a seal to prevent the water from leaking out, that should be replaced. Water might have leaked and ruined the pump. At the end of all cycles is there still water in the tub? If so your pump is either clogged or has gone bad, and thats why the washer wont go into extract.
Jul 09, 2007 | Kenmore 44102 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
127 people viewed this question
Sal De
fordexpert
Robert Rankin
