Male 32 how can i get my ek model willke to run on minimal contact? so far i have troubleshot the initial problem, reinstalled his hard drive once, & i am just waiting for some response from the model...i have gotten nothing.
Lik ur mum
Posted on Aug 19, 2008
Liewe juses se kerkie oos rand gauteng soek hulle telefoon nommer
Ek is dringend opsoek na julle tel nr of email. Liwe juses Oos Rand. Ek het gister gaan kyk en dit is Stunning. Ek wil graag indien moontlik vra of ek 'n troue daar kan hou op die 7 Maart 5h00 die aand en sommer die onthaal ook. Kan julle dring vir my terugvoer gee asb. Ek en my man is 32 jaar getroud en wil trou. my email: irene.oosthuizen@yahoo.com. Tel: 0828224304
Feb 18, 2014 | Computers & Internet
1000-0143 Dell error
This error code is related to " Drive Smart read command failed."
POSSIBLE LINK to fix: -
http://support.dell.com/support/topics/global.aspx/support/kcs/document?c=us&l=en&s=dhs&docid=266787#HDD
Remove and reinstall the Hard Drive for the error codes:
  • 1000-0141
  • 2000-0141
  • 1000-0142
  • 2000-0142
  • 1000-0143
  • 2000-0143
  • 1000-0144
  • 2000-0144
  • 1000-0145
  • 2000-0145
  • 1000-0146
  • 2000-0146
  • 2000-0151
Please see the Service manual for instructions on how to remove and replace the Hard Drive. Be sure to remove and reinstall the cables for the hard drive if you are on a Desktop Computer.
After reinstalling the hard drive re-run the diagnostics if you receive the same error code Contact Us.
Run the Drive Self Test (DST) from the Utility Partition also known as the 32 bit diagnostics to determine if the previous error has been corrected. If the DST from the Utility Partition does not indicate a failure of the drive, we consider the error to have been corrected and the drive does not need to be replaced.
  • 1000-0146
  • 2000-0146
Mar 04, 2012 | Dell Latitude D810 PC Notebook
I want to know how can i start my computer over like when i first bought it
Hi
To set you computer back to factory fresh settings you will need to format the hard drive and reinstall the operatins system and the drivers.
You will need to have the CD's that either you made when you got your computer or if your lucky you got the CD's that the factory furnished with the computer at the time you bought it.
1...Format the hard drive:
You do this by double left clicking on "My Computer",then double left click the main drive (normally C drive).
When the window pops open, you will choose "Format"
Keep in mind that once you format your hard drive you will loose all your files,programs,pictures,etc that you installed since the computer was new. So make your back up on a portable hard drive,thumb drive,etc.
2. Once the formatting of the hard drive is complete you will need to reinstall the operating system along with the drivers.
Insert Disk one into the CD/DVD and start reinstalling your operating system
That will bring your computer back to factory new condition as far as operating is concerned.
Please take time to rate me
Sep 06, 2011 | Computers & Internet
Error message 2000-0151 on dell inspirion 1545
Hi.
  • 1000-0141
  • 2000-0141
  • 1000-0142
  • 2000-0142
  • 1000-0143
  • 2000-0143
  • 1000-0144
  • 2000-0144
  • 1000-0145
  • 2000-0145
  • 1000-0146
  • 2000-0146
  • 2000-0151
  • 1000-0146
  • 2000-0146
For instructions on how to run the Dell 32 bit diagnostics click here.
Regards.
Sep 05, 2011 | Computers & Internet
How do i reboot my xbox 360 system
Before trying this, it's highly recommend that you remove all hard drive and memory cards. Once you've removed all hard drives and memory cards, navigate to the systems tab in the main menu and select the "Initial Setup" option. Once you select the option, it will ask you if want to run the initial setup that occurred when you first started your console. Say yes and it will do its thing. When it asks for a memory card/hard drive, just decline and it should be done. You should see the default dashboard screen as confirmation that it did, in fact, rerun initial setup. hope this helps
Nov 30, 2010 | Microsoft Xbox 360 Console
I have a Dell Latitude C610, some programs run dead slow!
Wow! 24 hours to run a virus check -- that's a long time. Let's see if we can find out what is causing your laptop to run so slow.
I understand you've doubled the ram ... It is now at least 2gb?
Please look at the following at the event viewer logs to see if anything looks out of the ordinary. (Control Panel, Administrative Tools, Event Viewer ... look at the Application and System Log in particular).
Is there any process in particular sucking up the processor? Press Ctrl-Alt-Del then open up the the task manager. Choose the processes tab, then click on the CPU tab until it is sorted with the highest process on top. What process/processes are taking up the utilization - ideally, system idle process will be in the 90s.
Please report back so we can resolve your issue. Thank you.
Sep 16, 2009 | Dell Latitude C610 Notebook
Primary hard disk drive 0 not found no bootable
Your hard disk is disconnected, or not configured correctly in the CMOS. Go to the BIOS and be sure that the computer recognizes the hard disk. If doesnt happens, check the connectors, and if it doesnt fix your problem, you need a new hard drive.
Jul 18, 2009 | Dell Latitude C640 Notebook
I am using a quadcore processor which runs on windows7. pen drives when used with the computer sometimes becomes unrecognizable. once it happens the pen drive becomes useless. do not know why? Can somebody...
solns:-
(probab=10%) 1.go to bios setting (by pressing DEL while starting comp.) there enable the USB options
(probab=10%) 2.Reinstall the operating systm
(probab=80%) 3.MANNUAL problem: the male pin of pen drive may not get properly fit into the female pin of ur comp.'s female USB pin- the same i have encountered 1ce.
May 14, 2009 | Samsung 250GB HD250HJ SATA II 300 7200rpm...
Computers & Internet Logo
David Payne
David Payne
