Question about Garden
Spark plug unbelievably oiled up. Cleaned it, restarted, but blue smoke pouring out and no real power for chipping. New gasket needed? (Allen Mighty mac 6.5 hp)
    President:
  • 3,074 Answers
Either too much oil or the rings on the pistons need changed. Tim
Posted on May 23, 2011
Van is smoking blue from the tailpipe no oil on the plugs no oil either real bad miss do that sound like heads gaster is gone
Well blue smoke is almost always oil burning.
It could be rings allowing pressure into the crankcase or valve guides allowing oil to leak into the cylinders. Most of the time a leaking head gasket causes problems with the cooling system.
The engine can burn oil and not show oily spark plugs for a long time.
Jan 22, 2013 | 1995 GMC Safari
2005 3.5l some times smokes oil then stops
Smoke oil? For what your thinking that is oil? Smoke coming from the tailpipe is not good news, but does not necessarily mean the engine needs rebuilding. First, you need to determine what color of smoke is coming from the tailpipe
* White smoke is caused by water and or antifreeze entering the cylinder, and the engine trying to burn it with the fuel. The white smoke is steam. There are special gaskets (head gaskets are the primary gaskets) that keep the antifreeze from entering the cylinder area.
* Blue smoke is caused by engine oil entering the cylinder area and being burned along with the fuel air mixture. As with the white smoke, just a small drop of oil leaking into the cylinder can produce blue smoke out the tailpipe.
* Black smoke is caused by excess fuel that has entered the cylinder area and cannot be burned completely. Another term for excess fuel is "running rich." Poor fuel mileage is also a common complaint when black smoke comes out of the tailpipe. Black smoke out the tailpipe is the least cause for alarm.
If you confirm us that is oil smoke, check and keep in mind that the car has many seals, gaskets, and O-rings that are designed to keep the engine oil from entering the cylinder, and one of them has failed. If too much oil leaks into the cylinder and fouls the spark plug, it will cause a misfire (engine miss) in that cylinder, and the spark plug will have to be replaced or cleaned of the oil. Using thicker weight engine oil or an oil additive designed to reduce oil leaks might help reduce the amount of oil leaking into the cylinder.
Keep us updated.
Apr 15, 2011 | 2005 Mitsubishi Diamante
CHUCKS OUT CLOUDS OF BLUE SMOKE.
Blue Smoke: Blue smoke is caused by engine oil entering the cylinder area and being burned along with the fuel air mixture. As with the white smoke, just a small drop of oil leaking into the cylinder can produce blue smoke out the tailpipe. Blue smoke is more likely in older or higher mileage vehicles than newer cars with fewer miles.
How did the engine oil get inside the cylinder in the first place? The car has many seals, gaskets, and O-rings that are designed to keep the engine oil from entering the cylinder, and one of them has failed. If too much oil leaks into the cylinder and fouls the spark plug, it will cause a misfire (engine miss) in that cylinder, and the spark plug will have to be replaced or cleaned of the oil. Using thicker weight engine oil or an oil additive designed to reduce oil leaks might help reduce the amount of oil leaking into the cylinder.
Jun 07, 2010 | Fiat X1/9 Cars & Trucks
Misfire blue smoke
SOUND LIKE TOO MUCH OIL GETTING IN COMBUSTION CHAMBER. POSSIBLE CAUSES.TOO MUCH OIL IN CRANK CASE.STUCK CLOSED PVC VALVE.WORN VALVE GUIDES AND VALVE SEALS ALSO BAD OIL CONTROL RINGS.
May 12, 2010 | 2002 Land Rover Freelander
Blown head gasket or not?
check oil dip stick for water/antifreeze and radiator for oil in antifreeze but usually alot of white smoke-steam from tailpipe usually indicates head gasket blue smoke means oil black smoke carbon
Sep 29, 2009 | 1993 Acura Integra Hatchback
Small block chevy 327 - water in oil. Car hadn't run in 15 years, started it, found oil discolored and foamy. Changed oil, added coolant, restarted. Hard to start didnt want to crank over, smoked blue,...
take out all the spark plugs and put a radiator pressre tester on the radiator and pressurize the system, then inspect each spark plug hole for coolant. you will find out what cylinder or head will need service. How did this car run before sitting? Blue smoke is not good, although it doesnt sound like you have run it long enough to verify any real cyl problems. if its smoking it may be overhaul time. and the complete engin ewill need disassembly.
Sep 21, 2009 | Chevrolet Camaro Cars & Trucks
Floods out 5 times out of 10 when trying to start car. Have to wait an hr. before trying to start again..Also a lose of power when going up a hill. Blue smoke comes out the exhaust. Also It won't change...
Blue smoke is caused by engine oil entering the cylinder area and being burned along with the fuel air mixture. As with the white smoke, just a small drop of oil leaking into the cylinder can produce blue smoke out the tailpipe. Blue smoke is more likely in older or higher mileage vehicles than newer cars with fewer miles. How did the engine oil get inside the cylinder in the first place? The car has many seals, gaskets, and O-rings that are designed to keep the engine oil from entering the cylinder, and one of them has failed. If too much oil leaks into the cylinder and fouls the spark plug, it will cause a misfire (engine miss) in that cylinder, and the spark plug will have to be replaced or cleaned of the oil. Using thicker weight engine oil or an oil additive designed to reduce oil leaks might help reduce the amount of oil leaking into the cylinder.
Jul 06, 2009 | 1991 Eagle Summit
I have a 96 eclipse 2.0 with 150 thousand miles there is blue smoke coming out of the tail pipe smells like chemicals.
How did the engine oil get inside the cylinder in the first place? The car has many seals, gaskets, and O-rings that are designed to keep the engine oil from entering the cylinder, and one of them has failed. If too much oil leaks into the cylinder and fouls the spark plug, it will cause a misfire (engine miss) in that cylinder, and the spark plug will have to be replaced or cleaned of the oil. Using thicker weight engine oil or an oil additive designed to reduce oil leaks might help reduce the amount of oil leaking into the cylinder. I that doesn't work then i would get with a mechanic and have it leak tested for possible piston ring replacement.
Mar 07, 2009 | Mitsubishi Eclipse Cars & Trucks
Sputtering during idle blue smoke
You are burning oil, causing the blue smoke. It is mainly cause by worn piston rings. Also will coat your spark plugs with oily residue. Try an oil additive such as "stop smoke" or another such brand to reduce burning your oil and it may recondition your seal sand stop it all together.
Nov 20, 2008 | 1989 Mitsubishi Mighty Max
Garden Logo
65 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
