Question about Refrigerators
Whirlpool ref #GS5SHAXNB00 makes a buzzing noise and the light in the ref section blinks. The noise seems to be coming from a white box on the left hand side on the back at the bottom of the ref. If I remove the light bulb, everything seems normal. I've tried different bulbs but it does the same thing. Thanks for your help.
  • vahlkamp Jan 07, 2009
    I have the same problem but now the light quite working but the bulb is good. I already had to replace the ice maker.
I had the same problem and repaired it. the noise you hear is the relay on a circuit board, the soilder teaces are burned making the relay only getting part of the voltage it needs to close completly and allow the voltage to flow you woll have change out the circuit board you wan't have any troubel finding this board just follow the noise check with local appliane parts store for this board. it's easy
Posted on May 11, 2009
I have a whirlpool side by side fridge. This
On some models you have a mother board located on the back outer section of the refrigerator that can be faulty. There is a tech sheet located behind the kick plate or under the front of the ref bottom to refer to. If someone olays with the digital controls you may have to reprogram the mother board, which is explained in the tech sheet.
Jul 21, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Making loud humming noise
it is a relay chattering/buzzing on the control board located inside the lower left wall of the unit,it is inside a white plastic box,you need to unplug unit,then remove 2 screws holding the box,remove cover from box unplug the 3 wire harnesses and replace the board and reverse the disassembly procedure to put back together
Jan 08, 2010 | Whirlpool GS5SHAXN Side by Side...
Ref light bulbs and noise no cooling wh-pool GS5SHA
I had the same problem. There is a main controller board at the bottm of the refrigerator near the back by the compressor motor. One of the components on the board shorted out and the board had to be replaced. Total cost about $150.
May 30, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ref light bulbs wh-pool GS5SHA
Your refrigerator has two sets of electronic control boards. One is inside and works to adjust temperature and to communicate with the other below and behind the refrigerator. They both have relays that if bad could cause the sounds you hear. It would be ok to pull it away from the wall and open bottom cover and listen to see if the sound is coming from the lower control board. If yes we need to examine the board after unplugging the power to refrigerator. let me know if the board is the reason or if while there you find something different, Thanks, Sea Breeze
May 21, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
FREEZER OK / FRIDGE SIDE NO INTERNAL LIGHT & NOISE
your refrig has a bad electronic control heres the part #W10135090 the noise your hearing is an internal relay on the board buzzing trying to turn the lights on. i found the part at sears.com and it was ony about 80 bucks it is a plug and play part so you should be able to replace it yourself. the board is located in the white box next to the compressor in the back of your refrig. thanks peyton
Jan 13, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Light in ref off / no power to main box with cooling level.
I replaced a circuit board that is in the white box at the lower left rear of the fridge. You will need to remove the cardboard cover, then there is two screws to loosen the box. The circuit board is inside. There is a white tab that sticks up push it sideways and it will pop right out. Put the plugs in the new board and pop it back in and put everything back together. Be sure the wires are routed so they do not contact the compressor.
If you want to test it first get a voltmeter one probe to CN1, the white wire, and the other to CN2, yellow wire with red stripe, there should be 120 volts. If not, or when the door is open it drops replace the board.
I did not have a voltmeter but it seems everybody that had a problem the fridge was 4 to 5 years old. So I bit the bullet, around $90.00, and replaced it and it works!
Dec 28, 2008 | Whirlpool GS6NBEXR Side by Side...
No light and buzzing noise
Jun 04, 2008 | Whirlpool ED5FHEXMQ Side by Side...
Knocking noise
I got the Same Exact problem with my S2OD RBB32-A/G Whirlpool Ref.
its has a Fast and Random Clicking on the Back in its Motherboard (White Box), i Open the main Board and it seems that its a Relay Who is Going Crazy!
it started to happen for 5 min then last couple of month then its now lasting for 2 and 3 hours!! after this it t works normal, then when the Electricity goes off than On again the Hole cycle accrue over and over.
Also When i Open the Door of the Fridge the clicking stops then comes again when i close the door!
Any Help?
Sep 09, 2007 | Whirlpool S20DRSS33 Side by Side...
Refrigerators Logo
319 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
