Error code E10 stops the washing cycle - Washing Machines
    Sniper:
  • 59 Answers
Check the filter or the screen on your washing machine if it's clogged. If it is clean then you will need to replace the water valve on your machine --- this is the piece that the hoses directly connect to.
you may check for replacements here:
http://www.partmaster.co.uk/cgi-bin/product.pl?PID=280442
Posted on May 23, 2011
  • 641 Answers
SOURCE: e10 error code
The E10 error code means - not filling water. The problem could be because of clogged filters on the water inlet line or a malfunction inlet valve.
Posted on Aug 04, 2007
SOURCE: error messages EFO and E10
could mean two things not getting enough water or the drain hose is too low I had the same problem and my drain hos was down to low if you have it on pedalestals like mine is you drain hose needs to be two inches high than the wash machine
Posted on Oct 08, 2007
SOURCE: F1 error code on Kenmore Oasis He
My problem: My washer shows the F1 code at the beginning within a minute of hitting start. If I hit stop twice (turn the washer off) and restart it, it will usually work. I worry that eventually this resetting process will not restart the washer, though, and found this website.
My non-solution: In response to the solutions which post the number to call, I just called 800-659-7026 and the representative said that my model will be included in the recall. The only Oasis washer not included is model 110.27082600. He said that corporate is tied up in litigation. He has no estimated date for legal issues being resolved. Contrary to the other solution where a technician is coming out to fix the problem free of charge, my service rep said he could arrange service but that it would cost $60-70 for the visit, not including parts.
I aired my disbelief at this, but all I got was touchy-feely "I know how you feel, and if I had a washer I would feel the same way, if only they could hurry up with this litigation and we can get it going!".
This is unbelievable. I will try calling again, and in the meantime, I am glad that my washer still works.
Posted on Jun 30, 2008
zanussi1600
  • 9 Answers
SOURCE: e10 code on a zanussi jet system washer
check to see if the water inlet is blocked.
the link below takes you to the manual, go to page 22
http://www.serviceforce.co.uk/pdfs/U21039.pdf
hope this helps
Posted on Apr 16, 2009
SOURCE: I have a Frigidaire Gallery front load washer with E10 error code
When ours does that it is because of the hard water build up. We have to un-hook the hot water clean out the minerals and it stops doing it.
Posted on Dec 03, 2009
Why does it stop in mid-cycle and display error E10?
Error codes are model specific water is your model number?
Feb 05, 2016 | Washing Machines
My washing machine keeps stopping during its washing cycle and says fault E10
Thank you for your inquiry, Barbara Constable!
I see that your Electrolux washer is displaying an "E10" error code. "E10" stands for fill time too long you may want to check the hoses to make sure they are not restricted or kinked this could cause slow fill within your washer. If the hoses look to be in good shape then I would suggest it could be a faulty sensor or control panel. You could additionally reset your washer by disconnecting power from it for ten minutes. If you restore power and it continues to flash "E10" I would recommend having a professional out to properly diagnosis your washer. Hopefully this information is helpful. -Matt
Dec 21, 2014 | Electrolux Washing Machines
Error E10 keeps popping up and washer stops 2 or 3 times during cycle and have to reset it
E10 means that your cold water is coming in too slow, disconnect the cold water hose and check to see if the screen on your washing machine is clogged. If the screen is clean and the hose has good pressure then you will need to replace the water valve on your machine--- this is the piece that the hoses directly connect to.
Here could find additioan sample guide details: fixed-frigidaire-affinity-washer-gives-e10-error
Hope helps.
May 03, 2011 | Frigidaire ATF6000ES Front Load Washer
My Zanussi ZWF14581 washing machine shows an error
The error code E10 is in relation to low water pressure.Have you checked that the hose at rear is not kinked or check the filters in the ends of the hose.Also make sure when you have hose off check the pressure in the supply.If all that is ok then it could be a faulty solenoid valve.
Hope this helps.
May 09, 2010 | Washing Machines
Kenmore front load washer error code E 10 - washer stops and beeps periodically and needs to have start button pushed again to complete cycle. Seems to happen one minute into cycle and then a coupleof...
1 Beep/E10--Error: Water doesn't enter Cause: Water supply problem, Check kinks and faucets
1 Beep/E10--Error: Water leaks Cause: Water connections loose,household drain clog,oversudsing. Correct problems.
1 Beep/E10--Error: Dispenser drawer is open Cause: Washer will not operate if drawer is open.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 11, 2010 | Kenmore HE2 Plus Front Load Washer
E10 code on a zanussi jet system washer
Is it a washer-dryer? E10 relates to a fault with the inlet valve.....usually the valve itself going open circuit.
Feb 26, 2009 | Zanussi WJS1265W Front Load Washer/Dryer
E10 error on Frigidaire GLTF2940ES
I searched the internet for a list of error codes for the washing machine. The E10 error code indicates an interuption in water supply among other things. We checked the supply lines and found that the screen on the cold water line had been blocked by sediment ( we have well water,and just replaced the pump).
Nov 29, 2008 | Frigidaire GLTF2940ES Front Load Washer
E10 error code
I had this problem, the washer/dryer stopped working while in the drying cycle and displayed e10 message. It was caused by a faulty three-way inlet valve. The solenoid controlling flow to dryer condenser proved to be open circuit. Pulled washer out from under counter top, unplugged, removed top cover, tested solenoid circuits with ohm meter and found one solenoid was faulty. The filter going into the unit was clear. Replaced whole three way component with one ordered on Internet and all now works fine. Noticed that during drying cycle, water to condenser is constantly being switched on and off, explaining why the green condenser solenoid is the one that wears out first.
Mar 03, 2007 | Zanussi WJS1265W Front Load Washer/Dryer
Washing Machines Logo
19 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
