Question about AEG Washing Machines
Whilst wash on, water leaks from the underneath of washing machine. but cant see where it is coming from
  • 561 Answers
If the water is leaking during the fill cycle when the detergent is being added from the drawer
ensure the draw is clear, if too much deturget rests has blocked the vent then water maybe running out on the inside.
if the problem is happening during the wash cycle this indicates a leak on your drum, ensure your door seal is intact and not leaking.
if the problem is during pumping, ensure that the pump is not causing a problem
maybe open the bottom vent and ensure the cover is seated properly and pump is clear.
also check the outlet pipe is not blocked or leaking and water is running back on the outside of the outlet pipe and under the machine
I hope this was useful.
Posted on May 23, 2011
Water Leaks Underneath
You really need too look underneath and see where water is coming from that means raising the machine off floor washing machine quite heavy so need to know what your doing
Nov 09, 2015 | Whirlpool WFW9050XW Washer Front Load...
Washing Machine leak underneath the machine - Zanussi FLS-579C
have checked the door seal
send the 91------------- no this is on a label in the door
Feb 05, 2014 | Zanussi Washing Machines
Water leaks from underneath my top load washer
Could be pump with motor.I replace on mine,had water under.
Apr 12, 2013 | Washing Machines
Waste water leaking from underneath my zanussi jetsystem ZWF16381
Could be slight hole in door boot seal / or circon pump suspect door boot seal
Jul 01, 2012 | Washing Machines
Water leaking from underneath machine
Open the top table. Check water inlet hose for damage or tear at the connecting places.
Pour water in the wash drum externally from from front side and see whether leak is present. If leaks, drum is having problem or the drain hose damaged before the drain valve end.
Mar 30, 2010 | Tricity Bendix AW1000W Front Load Washer
Leaking from machine - not door or outlet / inlet pipes
  • Hi,
  • Try these
  • Inspect the water supply connections
  • Inspect the drain hose
  • Inspect the water pump
  • Inspect outer tub for cracks or corrosion
  • Inspect the tub seal
  • Inspect the tub bearing
please rate my suggestion
Apr 14, 2009 | Washing Machines
When filling up my washing machine is leaking bad.I cant tell exactly where the water is coming from.I tilted the washer up so I could look underneath and couldn't tell anything was wet,so i turned it on...
Dear Customer,
i'll provide you with some checks,which when performed would stop the leakage from your Washing Machine..
Water is leaking onto the ground
mam i hope this would work out.i request you to please rate this solution if it meets your needs.Thank You
Dec 18, 2008 | LG WM-2277HW Front Load Washer
Washer leaking water from underneath
Your leak could be coming from the rubber door seal. Inspect all the way around the rubber seal paying particular attention to the areas behind the rubber seal where it meets the wash tub. They wear with age and can develop small holes. When they start leaking it appears like water coming from under the machine. I hopes this helps.
May 11, 2007 | Kenmore 44042 Front Load Washer
Washing Machines Logo
632 people viewed this question
Top AEG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Einar Axel...
Einar Axel...
Level 1 Expert
Are you an AEG Washing Machine Expert? Answer questions, earn points and help others
