Rosemount rs3 dcs,
I want to add one 16 channel analog input card (fim) in system,how to do it i.e jumpper setting &control file &communiation with sysem
A CTP Panel allows up to 8 comm lines (01-08) for an RS3 controller (A-H). Each controller then allows you to address jumper four FIMS per comm line (A-D) in a daisychain. Depending on which comm line you use and which address you have jumpered, will automatically define your FIM address and the addresses of the 16 points to be configured on your FIM.
I agree with Don, you need to know what you already have hanging from the controller. Type FS (FIC Status) to show what you have configured in all of the theoretical 32 FIM positions. Drop me an email if you need specific help, we are RS3 experts!
Optomation Systems is an independent software house, with over 20 years experience of the RS3 Distributed Control System. In addition to RS3 application software, Optomation also supports compatible products and solutions that provide independent migratory paths and life extension for the RS3 control system. This activity is not endorsed in any way by Emerson Process.
Posted on Nov 12, 2008
You need to know how many FIMs are already on the controller card and which comm lines are used. If you get this information I can then advise you.
Regards
Don Short
Posted on Oct 17, 2008
How do I switch from catv to antenna on model mwc13d6
First make sure that the TV/DVD player is on TV by pressing the Channel Up. (The channel up/down will rotate through AUX and any programmed channels.) You'll need the original remote or an universal remote that matches the Set-up function. Then press Set-up on the remote; it's to the left of Mute above Play.
Use the Up/Down arrows to navigate to Channel Setup. Press Enter to access the Channel Setup menu. Use the Up and Down arrows to select Auto Ch Programming and press Enter. Wait for the TV to scan all available channels. Afterwards, you can go back to the Channel Setup menu and choose Add/Delete channels. Press Set-Up again to exit the On-screen menu system.
Unless you have a set-top Digital-to-Analog converter attached to the TV, you will only get one of the few remaining low power analog stations, if you are close to the transmitter. This set only has an NTSC tuner. Most set-top boxes can be attached to the Antenna input and be set to Channel 3 or 4 or connected to the Aux input.
The Magnavox MWC13D6 was manufactured by Funai and the manual is available here: http://www.funai-corp.com/support/manuals.aspx . The direct link to the manual is MWC13D6 is http://www.funai-corp.com/support/om/MWC13D6.pdf .
I hope this helps.
Mar 24, 2015 | Televison & Video
Power drain
There is a lack of communication between the monitor and video card. Try reseating if add-on video card. Make sure monitor is set to correct input, like VGA (analog), DVI, HDMI, or Display Port. Try testing with another monitor.
May 09, 2013 | Dell Computers & Internet
Panasonic DMR-ES25 Trouble setting up to record TV shows
The DMR-ES25 does not have an ATSC tuner; it has an NTSC tuner. See page 54 (Specifications) of the manual at the bottom of the left column (television system). You need to add digital to analog (ATSC to NTSC) OTA converter box between the antenna and the DVD recorder. Next, you will set the converter box to the channel you wish to record and set the DVD recorder to record on a composite input (Line in) or channel 3/4 depending on how you set up the converter box.
The only remaining analog broadcasts are a few low-power stations. Unless you live close to one of these transmitters, your DMR-ES25 will not be able to tune in any channels. Make sure that you find a converter box with composite and/or RF out if you wish to use the DVD recorder. There are some currently available ATSC tuners that have built-in DVR capabilities. These might also work for you. However, many of the cheap units fail quickly.
I hope this helps.
Mar 06, 2017 | Televison & Video
Panasonic SC-HT07 unable to get 6 channel input working
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Panasonic-SC-HT07-Home-Theater-Systems-manual/id/354dj098/t/2/
Plug a device that actually has a 6 channel analog output into the DVD/DVD 6Ch inputs. Configure THAT device to put out 6-channel analog.Select ANALOG 6CH on the remote (page 16).
Apr 12, 2011 | Panasonic SC-HT07 System
I would like to connect my computer to my panasonic sa-ht800v unit and hear the sound thru the surround sound speakers
In general, your PC's sound card (and its controlling software) will determine what it can connect to.
Even the most basic PC would have stereo analog output via the typical green 1/8" connector or a headphone jack that easily adapts to RCA pair for analog audio connection. Any Line Level input EXCEPT PHONO would accept the PC's output. The output level would be controlled by the sound card software and settings.
The SA-HT800's single LINE Input would accept the Green stereo audio or speaker output from a standard PC, once adapted. Select VCR.
Find your PC's Sound Controls and enable the applicable input. make sure the volumes of both Inputs and Outputs are turned up.
Though not applicable to theGemini, more-advanced sound cards and audio hardware would have similar adaptable 5.1 or 7.1 (paired) analog outputs and / or digital audio outputs that conform to the s/pdif or Dolby Digital standards.
Mar 26, 2011 | Panasonic sa-ht800V Home Theater Audio...
What are the classification of simple machune
Specifications Display Image Aspect Ratio: 16:9 Widescreen Modes: Conventional 4:3 Comb Filter: 3D digital Additional Features: V-Chip, parental control Diagonal Size: 42" - widescreen Display Format: 1080p (FullHD) Resolution: 1920 x 1080 V-Chip Control: Yes Image Contrast Ratio: 2500:1 Brightness: 500 cd/m2 TV Tuner Stereo Reception System: MTS Secondary Audio Program (SAP): Yes Analog TV Tuner: NTSC Video Features HDTV Ready: Yes Analog Video Input Signals: NTSC Input Video Formats: 1080p Remote Control Type: Remote control Audio System Sound Output Mode: Stereo Sound Effects: Virtual Dolby Digital Speakers Included: 2 speakers Additional Features: Mute button Speaker(s): 2 x right/left channel speaker - built-in Connections Connector Type: 1 x composite video input ( RCA phono ) ¦ 1 x S-Video input ( 4 pin mini-DIN ) ¦ 3 x audio line-in ( RCA phono x 2 ) ¦ 2 x component video input ( RCA phono x 3 ) ¦ 3 x HDMI input ( 19 pin HDMI Type A ) ¦ 1 x digital audio output (coaxial) ( RCA phono ) ¦ 1 x audio line-out ( RCA phono x 2 ) Power Power Device: Power supply - internal Power Consumption Operational: 240 Watt General Product Type: 42" LCD TV TV Tuner: 1x analog, 1x digital Width: 41.3 in Depth: 10.2 in Height: 29.7 in Weight: 55.1 lbs HDCP Compatible: Yes Digital Television Certification: HDTV Digital TV Tuner Digital TV Tuner: ATSC, QAM Additional Specifications HDMI: Y More Information Model No.: DP42848 Shipping Weight (in pounds): 67.0 Product in Inches (L x W x H): 41.3 x 10.2 x 29.7 Assembled in Country of Origin: USA and/or Imported Origin of Components: USA and/or Imported Walmart No.: 000503420
hope this will be helpfull to you.
GoodLuck
Feb 02, 2011 | Sanyo 42 in. LCD TV
Rosemount system 3 RS3 spare parts
We have one 01984-1547-0001 in inventory. We have some other RS3 Hardware also. Contact information can be found at http://www.haygor.com
Thanks,
Bob
Jan 23, 2009 | ValuSoft Let's Ride! The Rosemond Hill...
Insignia NS-DXA1 APT remote control doesn't work
Set your TV input to match the input your have your Insigna connected to. Then run the Insignia setup. You are getting a distorted screen because you probably have the Insignia connected to channel 3 and the TV on channel 4.
Dec 30, 2008 | Insignia Digital-to-Analog Converter for...
Difference between 16 & 12 bit analog signal
In audio 12 bit selection, you can add audio (audio dub) without deleting or damaging original sound track. Like narrating some introduction in your voice and keeping background / original sound as well. 4 bit difference is used to add additional sound in same sound file without deleting previous audio data.
16 bit audio selection will not give you this option and audio-dub option will be disabled. If you want to add more audio, you have to over write complete sound track in movie file.
I'm not sure that I conveyed it to you correctly. Need further info, let me know.
Dec 18, 2008 | Canon DM-XM2 Mini DV Digital Camcorder
Tuning to pick up sky feed
Sounds like from discription the sky feed is set up for analog channel 6. With my TV-HVR-1600 card, there is an option in the wintv application when you click the menu button in the application that says channel suite. If you select this option, you should find and option for analog source. Select analog source in this screen and you should be able to manually add channel 6 in the box at the top of the analog souce screen. Also if you have the sky feed connected and you you click the scan button on this screen, it should detect automatically is the sky feed is on.
Aug 20, 2008 | Hauppauge WinTV HVR-1600 - ATSC HDTV...
Computers & Internet Logo
868 people viewed this question
David Payne
David Payne
