Question about KEIO PS2 Optical Scroll Mouse
I am not getting any sound evenfro i have set it to sound on
Sound Appeal sound bar set up. Not getting sound from tv except tv's speakers. Help!
You have to check the sound setting of your tv. In most of the lcd tv there are two option that you can select. Internal speaker of the tv and external speakers while using sound bars or other amplification devices. Fist of all Check that setting. Check the link bellow to understand How to setup a sound bar to your tv.
http://electro-medical.blogspot.com/
https://www.youtube.com/watch?v=QQ3zFnnsiMs
Dec 27, 2015 | LG Televison & Video
Im using innodv smarttv i only get clear pictures but sound problem,i cant get sound i only hear sound like a radio without signal,i get problem when i use tv.help me,i cant get sound when using tv
Check the system setting. That is, if your country adopts PAL system, and you have set the TV to NTSC or SECAM system, this kind of fault can occur. Set the system settings to "Auto". This will solve the problem. Refer its user manual for details.
Aug 19, 2015 | Televison & Video
I've tried everything, can't get sounds for in coming texts
go to your settings. click on sound. here you should find a notification option and set which ringtone you would like. make sure that you go back to your sound settings or caller settings to make sure the volume is actually turned on for incoming text messages. the reason you might not be getting them is because you have it default in your phone to keep them silent. just browse your setting options for sound or calls where you will find a "volume" option. select that and slide your notification sound over to whatever level you like! hope you found this helpful!
Dec 29, 2012 | ZTE Warp
Have lost all sound on my Hitachi 55VS69A
Let verify first to narrow down to where the problem can be. First, check the on screen sound set up menu to make sure the speakers are not set to OFF. If the setting is OK, then attach the powered PC speakers to the Audio Line out RCA jacks to see if you can get the sound there, if you do, then the problem can be in the power amp circuits, if you do not get the sound at RCA jacks, then the problem can be in the sound processor circuit. To get the sound repair, it can be from $150 and up, so if you can put up with using the good set of Powered PC speakers which actually give better sound than the tiny speakers inside the TV, I would keep using it that way, you may want to find out if the on screen sound setup will allow you to set the audio line out to be VARIABLE which means the sound output feeding the PC speakers can be varied using the TV remote control, then all you have to do is to set the PC volume to about half way up and set the TV volume to what ever you want.
I hope this will help in solving the problem....
Jul 03, 2011 | Hitachi 55VS69 55" Projection HDTV
No sound
i hope this help out
Jul 01, 2011 | Protron PLTV-32 Television
The sound completely fades during commercials on some channels. And on other channels, the sound is just gone!!!
Let verify first to narrow down to where the problem can be. First, check the on screen sound set up menu to make sure the speakers are not set to OFF. If the setting is OK, then attach the powered PC speakers to the Audio Line out RCA jacks to see if you can get the sound there, if you do, then the problem can be in the power amp circuits, if you do not get the sound at RCA jacks, then the problem can be in the sound processor circuit. To get the sound repair, it can be from $150 and up, so if you can put up with using the good set of Powered PC speakers which actually give better sound than the tiny speakers inside the TV, I would keep using it that way, you may want to find out if the on screen sound setup will allow you to set the audio line out to be VARIABLE which means the sound output feeding the PC speakers can be varied using the TV remote control, then all you have to do is to set the PC volume to about half way up and set the TV volume to what ever you want..
I hope that this will help solve the problem.....
Jun 28, 2011 | Samsung LE32R41BD 32 in. HD-Ready LCD...
I have just set up my onkyo 5305 i only have sound to front speakers have checked connection but im lost now in the settings
Onkyo are known for having 2 seperate connections for the rear speakers. 1 set for a surround sound, channel "A", and 1 set for seperate set a speakers, channel "B". check for the second set of connections. Also, your only gonna get sound out of the rear speakers thru surround sound mode when the unit actually sends singal. The sound is determined buy what setting you have the receiver set to.
Mar 06, 2011 | Onkyo HTP-102 System
Rear speakers no sound
you have to have it set to one of the sound settings to get surround sound , and if what you have hooked up does not have a digital connection ( optical or coax) you can not get dolby digital surround either
if it is the stereo your listening to then set a sound to get virtual surround sound ( unless you have a digital tuner that supports digital signal input
Oct 26, 2008 | Audio Players & Recorders
NO SOUND FROM DVD
Try different sound settings in the dvd menu.
Oct 15, 2008 | Sansui HDLCD-2600 26 in. LCD Television
Ps3 Surround sound
ttttttttttttttttttttttttttttttt
Nov 22, 2007 | Sony Playstation 3 (PS3) Console
KEIO PS2 Optical Scroll Mouse Logo
16 people viewed this question
Top KEIO Computers & Internet Experts
David Payne
David Payne
Are you a KEIO Computer and Internet Expert? Answer questions, earn points and help others
