My Acoustic Solutions TV switches itself off after two hours. Why?
  • 998 Answers
That problem is caused by excessive heat, try to change the location of your tv or put something that can ventilate your tv if still no effect, you have a faulty power supply. Faulty power supply commonly cause by swollen or leaky capacitor it is easy to distinguish when you see an oil mark under the capacitor or the top of the capacitor is slightly embossed try to replace it be sure to remember the marking or polarity of the capacitor.
Posted on May 23, 2011
5 Suggested Answers
WebTeligent
  • 42 Answers
SOURCE: Acoustic Solutions TV
Try: http://www.viewpia.nl/html/downloads/viewpia_multilanguage_LCDmanual.pdf
Posted on Nov 09, 2007
mace1mace
  • 1138 Answers
SOURCE: Acoustic solutions LCD37NK750HDF TV sound ok but no picture.
If there is no picture, just black screen.. then the cold cathode (backlight) on your monitor is busted. Or its ballast transformer is burnt out. Replace it to work again.
Posted on May 17, 2010
SOURCE: Acoustic Solutions LCD26761HDF TV turned
i have the same problem, have you had any joy yet?
Posted on Oct 06, 2010
budmrtn
  • 11361 Answers
SOURCE: my acoustic solutions tv turns
It may be detecting shorted circuits in the power supply, backlight inverter boards, main board. You need to troubleshoot the problem starting at the power supply module first.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Please post back what you find.
Posted on Dec 10, 2010
Tv keeps turning off
This is probably due to failing PSU capacitors. It is fixable.
May 19, 2014 | Televison & Video
Acoustic Solutions LCD26761HDF TV turned itself off & standby light started flashing. TV wont respond to remote or on set buttons
The solution to Acoustic Solutions problems, such as intermittant power off and flashing blue light is very simple: dump it in the trash. This product has lots of problems which are associated with memory and timing. There is no software update available, its just cheap Chinese ****.
Sep 25, 2010 | Daewoo DLP3212 32 in. LCD Television
Acoustic solutions lcd tv astv15id last used 2 months ago perfect ,switched on today perfect picture but no sound
Hi I know this was posted months ago but the answer may help others, I found the capacitor C852 1000Uf ,35v was bulging at the top which is on the power supply board the number C852 is for the acoustic solutions model lcd42762f1080p tv (but this info would apply to most acoustic tvs: WHEN TESTED THE CAPACITOR ON THE ESR METER READ OK, but cos it was bulging at the top I knew it was faulty, it seems that it was breaking down under load hope this help regards celestica
May 18, 2010 | Televison & Video
Acoustic solutions lcdw22dvd95f. tuner problem
Without the DTV digital converter box.Ur tv tuner have statics video come out to the signal at all?Yes it the converter box not the tv.
Mar 17, 2010 | Televison & Video
Lcd26805hd manual FOR A ACOUSTIC SOLUTIONS LCD TV
My acoustic solutions lcd26805hd tv has started flickering really badly every time I switch it on. The flickering goes on for about 30 minutes before it calms down. I have checked all the connections at the back of the tv - all ok. This happens whether I watch cable or a dvd.
Jan 10, 2010 | Televison & Video
Nov 26, 2009 | iLO LCT32HA36 Television
I cant rig up my surround sound to my tv
Run a phono cable from the tv output to a input on your system,select this input and you should have sound,if not go to tv menu for sound set up as some tv,s need the output turned up or even to be switched on.
hope this helps.
CABLE GUY.
Jun 30, 2008 | Audio Players & Recorders
Acoustic Solutions ASTV 3619WS After about and hour and a half of use. T.V overheats and turns itself off. T.V takes ten minutes to cool down, and another half an hour to cool down fully.
Your television is going to require internal repair. if you are comfortable making internal repairs yourself then please use our premium service for assistance. If you do not feel comfortable with making the internal repair yourself, please use the Repair Service search engine on this site to help you find a local repair service.
Thanks,
Jun 28, 2008 | Televison & Video
Televison & Video Logo
96 people viewed this question
Top Televison & Video Experts
Electro Med Services...
