Question about BenQ FP931 19" LCD Monitor
Hi Dear Would you pls help me providing tips/tech? BenQ 19" monitor, changes it's display mode per 1 or 2 seconds or more. I'd turned off- next morning found- it can not switch on by it's power switch, so no display, I checked all switches-ok, re soldered psu unit and connector bases, now it turned on but same problem( mode:movie; dynamic; photo... etc on it's osd menu >Md. Younus Ali, Dhaka,Bangladesh,Engr- BanglaCAT, +8801713148409
3 Suggested Answers
  • 788 Answers
SOURCE: connected power but hardly see the image all dark
Sorry about your Monitor problems.
I have worked on several of these monitors and yours sounds like the BackLight has gone for a walk. ( NG ).
If you are experienced in the disassembly and the electronic component repair, let me know, and I will walk you thru the repair steps.
The backLight for your unit, can be ordered on EBay or direct from Samsung.
Posted on Jul 08, 2009
SOURCE: benq q5t4 monitor. power on "BENQ" display is
i want data for benq q5t4 moniter eprom 24c04 ic my moniter is not working properly
Posted on Sep 05, 2011
SAMSUNG SYNCMASTER 226BW WHEN TURNING ON MONITOR, IT SHOWS BLACK AND WHITE LINES THEN IT SHOWES A BOX THAT SAYS "NOT OPTIMUM MODE, RECOMMENDED MODE 1680 x1050 60HZ " AND IT IS STUCK ON THIS...
hi dear
start your computer on safe mode and go to the display property change to as per mentioned rresolution on your screen.
best of luck
regards
raj
Sep 06, 2011 | Samsung Computers & Internet
Tip
How to Troubleshoot CF-19 The Panasonic Toughbook CF-19, commonly known as...
How to Troubleshoot CF-19<br /><span style="font-style: italic;">The Panasonic Toughbook CF-19, commonly known as simply the Toughbook 19, is a laptop computer geared towards people who work on location, such as field workers or military personnel, who require a sturdy and resilient device. Unique features of the model include its screen which can display clearly in bright sunlight, its touchscreen function and its backlit keyboard. If you experience errors or malfunctions with the CF-19, troubleshoot it to diagnose and solve the problem before replacing the device or seeking professional repair.</span><br style="font-style: italic;" /><br /><span>Instructions</span><br /><br /><span>Device Turning On</span><br /> <ol> <li> <span style="font-style: italic;">Check that the AC adapter is connected properly. One end should be plugged into the laptop and the other end should be plugged into a working AC outlet. If the adapter is disconnected at either end, connect it.</span></li> <li style="font-style: italic;"> Disconnect any device connected to the laptop's USB port or ExpressCard slot. A malfunctioning device may cause the laptop to malfunction and not turn on.</li> <li style="font-style: italic;"> Press the "Fn" and "F8" at the same time to turn off "Concealed Mode." This mode disables the power functions of the device.</li></ol><span>"Remove disks or other media. Press any key to restart" Error Message</span><br /> <ol> <li><span style="font-style: italic;"> Remove the floppy disk or CD-ROM from the device and press any key. This message indicates that the disk does not contain system startup information and cannot run on the device.</span></li> <li><span style="font-style: italic;">Disconnect any device connected to the laptop's USB port or ExpressCard slot as problems with these device's may also cause this message to appear.</span></li> <li><span style="font-style: italic;"> Contact Panasonic Technical Support if this problem persists after attempting Steps 1 and 2 as this may be a sign of a problem with the laptop's hard disk and it may need repairing or replacing.</span></li></ol><span> No Display/Screen is Blank</span><br /> <ol> <li style="font-style: italic;"> Press the "Fn" and "F3" keys simultaneously to switch to "Internal Display" mode as the device may have been set on "External Display."</li> <li style="font-style: italic;">Check if the device is in "Power-Saving" or "Sleep" mode by pressing any key on the keyboard. The screen should come on if the device was simply in "Power Saving" or "Sleep" mode.</li> <li><span style="font-style: italic;"> Turn on the display screen or monitor of the connected device if you have the laptop set on "External Display" and want the display to come up on that device.</span><br /></li></ol><span style="font-style: italic;"><span>Hopefully this can help<br /><br />regards<br />multilinkent</span></span><span><span><span style="text-decoration: underline;"><span style="font-style: italic;"><span style="font-weight: bold;"><br /></span></span></span></span></span>
on Jul 08, 2011 | Computers & Internet
My 19" monitor has the
Turn off the monitor, then while holding the 'menu' button, turn the monitor back on
May 29, 2011 | Acer AL1916W 19" LCD Monitor
Benq FP92G Display couple of seconds then blank. LED still green.
budged electrolytic capacitor nearby high voltage transformer. 220microcarad/25Volts. apply fresh solder and re-connect lamps.
Jun 01, 2009 | BenQ FP92G+S (Black,Sylver) (Silver,...
When i connect an external tv card to my lcd monitor it immediately reads "OUT OF RANGE" can anybody help
ok
it is screen resolution problem.
when u power up the computer press F key then enter in enable vga mode then change screeen resolution to 1024*768 in display property.
May 11, 2009 | BenQ FP931 19" LCD Monitor
BENQ FP737S Monitor shows "No Signal Detected" on startup
first problem could be the hdmi cable you are using is loose or broken.second, the display mode you selected was wrong, try to go to desktop and right click and choose nvdia control panel and choose the nview display mode to use,select the only use one display(single)and apply.
Jan 27, 2009 | BenQ FP71E 17" LCD Monitor
BenQ FP91G+ Problem
Hi...there,
Dies on 1 seconds usually caused by busted backlight inverter or AC Adapter if you got one on your monitor.
Nov 21, 2008 | BenQ FP91G+ 19" LCD Monitor
BenQ fp737 monitor
Disconnect the signal cable from CPU and power on.You should get a BenQ Blue screen.
If no Display,Problem is definitely monitor related ie monitor has a hardware defect most probably the power/invertor board has a few blown components.
If you are technically able,you can dismantle monitor and check components on the Invertor board which you may find on my other posts.
Please reply if you need more help.Please rate this solution.
Thanks.
Samir
Aug 25, 2008 | BenQ FP737S-D 17" LCD Monitor
Fp91e
Problem with Inverter circuit.
Check with BenQ They offer a 3 year warranty.
Samir
Jan 19, 2008 | BenQ FP91ESIL (Black) (Silver, Black) 19"...
Malfunctioning monitor (BenQ)
hi, first run the system in safe mode, if that works than u will have to look in for driver problems/settings, sometimes uninstalling the monitor & display driver then reinstalling it back will change the settings to default, try it, let me know
Dec 30, 2007 | BenQ FP72G+ 17" LCD Monitor
BenQ FP931 19" LCD Monitor Logo
Top BenQ Computers & Internet Experts
JP Services
JP Services
Tony
Tommmix
Level 1 Expert
Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
