Eveytme i use my dt comp. it is gounded. - Computers & Internet
Hi I have a 1974 dt 360s that needs a new RH front fork and as the DT 175 runs the same size 21 inch front wheel as the dt 175s does that mean the front forks are interchangeable ? I have only been able to...
no not really,the diameter of the fork tubes are probably different,maybe a dt 400 would be closer,replace them in pairs,dont replace only 1,the spring rate & dampening is different,try junk yards in your area,get a complete front end from a dt 400,it should fit.
May 13, 2014 | 1974 Yamaha DT 360
2 of 3 brake light bulbs dont light up when brake pressed only when lights are on do all 3 bulbs light up, only on the right side, left bulbs turn on, I changed fuses and bulbs no luck
Chek the light harness ground connection, for each "faulty" bulb. l suspect the brake lights are detecting the gound from the running lights, which is the only time they all function.
Regards, DT
Mar 14, 2011 | 2004 Chrysler 300M
I need to change the plug in my dryer and i dont know how to attach my new 4 wire plug. my last plug was a 3 wire plug. i have a new kenmore dryer and my old house allowed me to use a 3 wire but my new...
You'll have to lengthen the wire. You should be able to lengthen it by cutting the terminal off the end of the wire and stripping it. Then attach a piece of wire to it with a wire nut. If you use solid wire you shouldn't need a terminal -- just bend it into a circle.
Nov 17, 2009 | Kenmore Elite HE4 Electric Dryer
HL-DT-ST DVD +-RW GSA-H21N ATA Device is not working gives a code 10....tried for new drivers was all updated..tried to uninstall and reboot then reinstall nada. This is a acer comp.
Right click on “Computer” or “My Computer” in XP. Select Manage and then on the right side select device manager. On the left if you see a yellow exclamation mark next to your drive and were getting any of the above error codes then we have a simple fix.
Go ahead and right click on the CD or DVD drive that has a yellow exclamation mark next to it and select delete or remove.
try to search:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control
\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
Now that you are at the {4D36E965-E325-11CE-BFC1-08002BE10318} Folder on the right side you will see several entries. right Click and delete the Upperfilters and Lowerfilters. These will be remade once you reboot.
This will try to look for the drivers again..
Jul 12, 2009 | Acer Computers & Internet
After i reformatted my desktop pc,i lost the audio on my comp
Install the audio driver using your motherboard CD.
This will remove your problem.
Apr 16, 2009 | Microsoft Windows XP Home Edition
F 250 is dead
Check for the Gounding Lug on the engine Block being loose or dirty,most Fords have a central location for all their Gounds to be going to. Also Check that Fuse pael has not come loose and seperated as they are bolted together
Aug 06, 2008 | 1989 Ford F 250
Carrier 48TMD006 RTU DT ONLY 15 DEG ADJUSTED FAN FREON LEVEL SUC 85 HEAD 298 95 OSA SUC TEMP 62 EVAP DROP IS 79 RET 65 SUPPLY RECP COMP JUST DONT KNOW
what's the problem?With a 79 return humidity is prolly very high.Are you shutting this off at night or letting it maintain comfort levels?
Aug 03, 2008 | Carrier Heating & Cooling
MSI Star Cam 370i
Throw it away..that cam is a big ****...almost everyone has some probs with it..the most with colors..u can give it back to the store but when they will give u another one there's a big chance something will be wrong there too...
Apr 28, 2008 | MSI Starcam 370i Webcam
HL-DT-ST- DVD-RAM GSA-H22N
I Have A : HL-DT-ST- DVD-RAM GSA-H22N DVD Burner That Works Fine With (CD Burning/ Reading) & (Data Burning/ Reading) But I Have A Very WIERD Problem With The DVD : Here I Go, When I Use Any Program To Burn DVD Like Nero, DVD Shrink Etc.. (It Appears That) The Movie Is Burning Well, Because In The Burning Process It Doesn't Says Something Like:Bad Disc, Not Succefully Burned Or Any Sign That The DVD Burner Is Damaged , Also When It Finish Recording You Can See The Data Burned In The Disc By The Lines It Forms BUT !! I Don't Know WHY The Fu$%@@ , When You Test The Movie In Any DVD Player , Comp OR Whatever THE MOVIE DOESN'T WORK.
Aug 01, 2007 | LG GSA-H22N DVD±RW Dual Layer Burner
Computers & Internet Logo
81 people viewed this question
David Payne
David Payne
