Question about Ovens
Correct wattage bulb in Simpson La Scala electric oven.
  • Anonymous Mar 19, 2014
    Does the la scala oven have an oven light
    Where is the light control switch, if there is one.
  • 561 Answers
If you are refering to the light inside the oven, I dont think there is a problem with wattage as the oven is rates to high wattage
and it is also inside the oven, so in an area that can cope with heat.
if possible check remove the old bulb and check the wattage on the glass or on the side of the fitting.
I personally would recommend that a 40W should be suitable.
I hope this was useful
Posted on May 23, 2011
What is the power requirement for installing a Simpson 2001 66-647 thermaflow freestanding oven?
For Electric Range - 220 - 240 volt, 60 hertz, properly grounded circuit with 40 amp breaker or fuse protection with #8 gauge wire. With a 50 amp breaker, # 6 gauge wire is required.
The owner's manual below mentions the wattage. (download the document, hit CTRL-F on your keyboard, type in wattage.) You might contact the manufacturer or for that matter the electric company servicing you.
https://john.daltons.info/appliances/Simpson_2001_models_68-642_and_68-646.pdf
Jun 11, 2017 | Ovens
I want to remove the oven door for cleaning but not sure how.
Try opening the door about 6" (15 cm) and pull straight up.
May 08, 2017 | Ovens
In the last 4mths I have had to replace my large oven bulb 5 times.
I assume you are fittimg the correct wattage bulb, and most importtantly fitting one that is able withstand at least 300c , if you are not, then this could be the reason for high bulb failure rate, also make sure that the bulb holder contacts are clean
Dec 07, 2010 | Tecnik TKC8085 Electric Double Oven
What bulb is it in the oven
The bulbs are small wattage ones aroung 10-15 watts.It will be better to look for the same configiration of size and shape.
So remove and take the buld as a sample to show this to the persons around you for advice.. same pin type should be seen
Sep 11, 2010 | Whirlpool RBS245PDS Electric Single Oven
Cant remove glass cover to replace bulb on Simpson La Stella Atlas series oven
I have a Simpson Atlas Mira. Was having a hard time getting the glass cover off too so looked on the net for a solution. Couldn't find one so I persevered and sorted it...
The glass cover has a screw-off thread (like a glass jar) which unscrews anti-clockwise (lefty loosey). I had to give it a good few wiggles and pulls before it would start unscrewing. I also had to use a damp towel to get a proper grip - it's a slippery little bugger - but I got it in the end!
Hope this helps someone - good luck!
JD Hamilton, NZ
Aug 23, 2010 | Ovens
Replace light bulb
Hello. Unscrew the bad bulb. It unscrews in a counter clockwise fashion. Get a new oven bulb, of the same wattage at home depot or most hardware stores. J.
Jun 26, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
I don't know what wattage I need for the bulb
You can fit a 15 or 25 watt bulb, as long it it is the correct thread, and it is able to withstand 300 degree temperature.
This is very important, otherwise it will blow with the heat.
Hope this helps.
Jan 20, 2010 | Zanussi ZBS963X Electric Single Oven
Can not set clock on Simpson La Stella oven
How do i set the time on a Simpson La Scala wal oven
Jun 30, 2009 | Electrolux Ovens
Kenmore oven model # 79071053400
Check for a loose bulb or faulty door switch. Sometimes a bulb can fail and the filament can reconnect to work at a higher wattage before failing completely.
Jun 08, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Oven lights
i don't know your brand but ive read service bulletins on bad light sockets in ranges id try another bulb first then replace the socket
Feb 13, 2008 | KitchenAid KEBC107 Electric Single Oven
Ovens Logo
252 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
