Question about Datacard SP55 Plus Plastic ID Card Printer - P/N 573579-099 Network Adaptor
THE PRINT RIBBON IS BROKEN PR 01724 fix the ribbon BUT THE RIBBON IS NOT BROKEN DATA CARD SP 55 PLUS
3 Suggested Answers
  • 6 Answers
SOURCE: Datacard SP35 + giving broken ribbon error
You have to clean the roller under the printerhead.
The big black one..
I suggest you install Diagnostics.
Go to motor test, and take the transport fast reverse. 300 sec.
Now you can clean the roller easy.
Posted on Feb 03, 2009
  • 1116 Answers
SOURCE: Good afternoon, I am
PR-01724 Ribbon Break
The print ribbon is broken.
Possible Cause 1: The print ribbon has broken or is not installed.
Solution 1: Trim the broken ribbon evenly and tape the cut end of the ribbon to the ribbon on the take-up spool. Install the ribbon cartridge.
NOTE: Do not switch take-up spools when fixing.
Possible Cause 2: If the ribbon type is K or KT, the print ribbon is at the end of the roll.
Solution 2: Load a new roll of monochrome print ribbon.
Technical issues:
•If you have recently changed edge-to-edge settings using the SmartDriver, printing might be too close to the edge of the card. Change edge to edge settings.
•You might have moved the print ribbon while the printer power was off. The next card will print correctly. The printer is designed to allow you to fix problems while the printer power is on.
•If the print ribbon is stuck to the card, the Intensity setting might be so high that printing causes the ribbon to stick to the card. Lower the Intensity or power setting.
•The card design might be longer than the card size. Change the card design to be less than or equal to the card size in the long direction (3.37 inches or 85.60 mm).
•Printing might not be positioned properly on the card. Change the "Left/Right" position of printing (using the SmartDriver) so the printing begins and ends on the card.
Posted on Jun 20, 2011
I got a color print ribbon and it won't install
Please post the configuration for the printer which is on the left side under the cover (white sticker) and your ribbon part number. If you are sure both are correct you may have a defective print ribbon or your printer will need service.
Feb 24, 2014 | Datacard SP35 Plus Printer
Datacard CP40 Plus printer with an error. Put a new ribbon in it and it does give us a error message: Error: PR-01739 Ribbon Error Please Help!
Sounds like you are using an incompatible ribbon. Please post the configuration for the printer which is on the left side under the cover (white sticker) and your ribbon part number. If you are sure both are correct you may have a defective print ribbon or your printer will need service.
Contact TulsaBiz.net for more info
Jul 22, 2011 | Datacard SP55 Plus Printer
Good afternoon, I am having problems getting my printer to print a complete card without telling me that the ribbon is broken. The error code I am receiving is PR-01724 The Printer I am using is the...
Technical issues:
Jun 20, 2011 | Datacard SP55 Plus Printer
Datacard sp55 printer won't recognize ribbon
PR-01726 Ribbon Out
Out of print ribbon.
Possible Cause 1 : The print ribbon Cartridge is empty.
Solution 1 : Reload the print cartridge. Change the cleaning sleeve and replace the cartridge in the printer. Run a cleaning card as soon as printing is completed.
Possible Cause 2 : The printer ribbon is not loaded correctly.
Soultion 2 :Load the printer ribbon correctly and then close the cover.
Possible Cause 3 : This ribbon has been completely used.
Solution 3 : Use a new roll of ribbon.
Tips for Success
* When this message appears, replace the old ribbon with the new ribbon of the same type. The printer has already prepared the card data for this ribbon type. You can change the colors of monochrome ribbon (such as from dark blue to gold).
* If you must change the type of ribbon (such as (YMCKT to KT) when this message appears, install the new ribbon, cancel any cards waiting to print, and change the ribbon type settings. Finally, return to the card creation program to send the card data to print.
* If the ribbon was repaired, the wrong take-up spool was used. Repair the ribbon again, using the correct take-up spool.
If you cannot fix the problem contact your service provider for assistance.
FTB
Nov 23, 2009 | Datacard Group SP55 Card Printer
SP55 Datacard
The printer does not know the the model of the ribbon installed and thinks it is a monochrome (single color) Print ribbon. You can verify this in the Driver toolbox under the supply tab, or in the advanced printing options.
The Datacard SP series printers use an RFID Radio freq. tag in the take up spool end of the ribbon. This identify s the ribbon model and supply use settings for the printer.
Make sure you have the most recent driver and firmware from Datacard, There is a firmware Update Available to help reading "weak" RFID tag's
Next try removing the RFID tag from another (old) ribbon and see if it that fixes the problem)
Aside from that you:
May have a counterfeit (non-Datacard) ribbon
A bad RFID tag
Someone removed your RFID tag
You need a firmware update (weak RFID tag)
A bad RFID reviver in the printer, which is a fairly cheap repair.
Basically try a new print ribbon if that does not correct the issue, have the printer serviced.
www.TulsaBiz.net
Apr 07, 2009 | Datacard SP55 Plus Printer
P430i - Ribbon Broken / Out of Ribbon error
ribbon cut again and again after put 2 or 3 cards pls give instruction how to solve the problem.
Mar 03, 2009 | Zebra P330i Thermal Card Printer
THE RIBBON BROKE ON MY DATACARD SP25 PLUS.
to fix the problem that is causing the ribbons to brake or the broken ribbon it self?
1. check edge to edge settings in printer toolbox
2. to fix broken ribbon re wrap it straight over the take up spool and use a piece of tape to hold in-place.
Dec 31, 2008 | Datacard SP25 Printer
The big black one..
Nov 25, 2008 | Datacard SP35 Printer
Broken ribbon message for my zebra card printer
It could mean that the ribbon sensor on the printer is broken. Sounds like you need to send back to zebra for repair. This is free if printer is still under warranty. check out zebra's website for info on how to return printers for service.
Sep 11, 2008 | Zebra Eltron P330i Card Printer
PR 01724
same error msg with model datacard sp55 plus
Jun 25, 2008 | Office Equipment & Supplies
Datacard SP55 Plus Plastic ID Card Printer - P/N 573579-099 Network Adaptor Logo
198 people viewed this question
Top Datacard Office Equipment & Supplies Experts
Safe-Card ID...
Level 1 Expert
james laughton
james laughton
Are you a Datacard Office Equipment and Supply Expert? Answer questions, earn points and help others
