Question about Morphy Richards 43691 Cordless Electric Kettle
How do you clean the inside of your metal kettles
    Habit-Forming:
    Scholar:
  • 130 Answers
You can simple clean it using vinegar solution. Fill 1 part vinegar and 2 parts water and put this solution overnight.
Then remove the whole solution and fill with hot water for some time. And wash it properly.
Visit GroomNStyle.com for best electric tea kettle reviews.
Posted on Jul 29, 2015
  • 561 Answers
If you wish to remove limescale, then you can use limescale remover either liquid or powder.
follow directions on the product of choice.
alterativly use vinager, just pour undiluted vinegar into the kettle and let it rest for a while until it no longer produces bubbles. then rince well.
if there is still limescale then repeat the process.
Note
do not let the kettle boil with vinegar or limescale remover in it. they may cause a fault and some
very bad smells.
I hope this was useful..
Posted on May 23, 2011
How do i clean the inside of illuma kettle
You can use Lime-Away (at Home Depot) or Apple Cider vinegar. It seems to work much better then regular vinegar. In either case let it boil if it has no element inside the water compartment, put a small clean rag inside and use a wooden spoon to clean the heavier areas. Boil it a few times, then dump it, and boil and clean with clean water twice, then put it back in service.
Feb 26, 2015 | Morphy Richards Illuma 43121 Cordless...
Tip
Leakage problem at the bottom? Toastess International Kettle Model: TJK-103...
Leakage problem at the bottom…
Model: TJK-103 120V, 60 Hz, 1500 W
She was complaining that our kettle was leaking a bit at the bottom.
Warranty is over.
Here is what I did to fix the problem.
Unplug the kettle and empty it completely.
Remove excess residual water inside.
Remove the bottom cover by removing the screws holding it.
Gently remove the plastic ring screwed in place.
Now you will be able to put your hand inside the kettle and push the bottom out, toward the outside of the unit.
Take out the rubber seal and clean it. Ours was full of fine residue…
Gently dry it out and lube it with tiny bit of silicon.
Clean the inside part of the kettle before putting everything back together.
Make sure that you don’t squeeze any wires inside.
With a lot of patience, put everything back in place.
Make sure that the seal is perfectly installed. You can see it looking trough the plastic.
Kettle is now fixed and she is happy! ;-)
on Jan 23, 2008 | Toastess The Storm Electric Kettle
Russell hobbs problems
Hi Naomi,
please check the manual.and see if it is has a small hole or opening in kettle to go to outside of steam.
your one must be blocked .
regards.
nuwan
Jan 13, 2014 | Toastess Cordless Electric Glass Kettle...
I boiled the kettle dry and it now has brown spots on it. Can I restore it to its beautiful finish
It must have been badly over heated. Check at the local hardware store for cleaners that can clean over heated metal surfaces.
Jerry G.
Jun 10, 2012 | Alessi 9093 Kettle with Bird Whistle
I turned on the cordless electric kettle without water! the metal rod inside the kettle turned black? was it burnt? i tried boiling water again and it worked. but is the metal rod toxic or not? can i still...
Yes, if your worried, use a fine emory paper to clean off the tarnish from the heat scorch. You may have shortened the life a little on the element but it is fine as long as it is not spalling, of flaking.
Mar 24, 2011 | Microwave Ovens
I have checked ground wire/ kettle conections/no bare wires, what
u have a live wire making cntact with kettle inside of unit, unplug, open and check connections
May 22, 2010 | Kitchen Appliances - Others
New kettle leaves a metalic tast to water after boiling.
Try different water. If you use tap water normally, buy a jug of water at the store. The pH may be wrong (particularly if it is too low) and leeching metal from the kettle. Good luck.
Jan 05, 2010 | Microwave Ovens
Can glass kettle be used on glass hot top stove?
No you should not use a glass kettle or glass type pots on a ceran top stove. Always use metal flat bottom kettle and pots. When buying a metal kettle make sure that there is no gap between the bottom of the kettle and the surface of the ceran top. Some metal kettles have an indentation on the bottom. This does not work well on the ceran top.
Hope this helps.
Dec 30, 2009 | Kitchen Ranges
Can kettle be cleaned and continue to be used.
I use a solution of vinegar and water (1:1) and boil it in the kettle, to remove mineral deposits from the metal heating surface (We do the same with the percolating coffee maker and run it through several times)... It seems to take any residual tastes out of the unit and possibly also cleans the plastic parts that it touches (I believe it does).
By the way... WHO thought it was a good idea to heat apple cider in an electric kettle. Sorry but WOW
Feb 24, 2009 | General (102105011) Electric Kettle
Electric cordless kettle
This can happen on new mettalic kettles, the aftertaste may dissapear after a while with use as it did with mine.
Oct 25, 2008 | Faberware FCP512S Cordless Electric Kettle
Morphy Richards 43691 Cordless Electric Kettle Logo
411 people viewed this question
Top Morphy Richards Kitchen Appliances - Others Experts
Mike
Are you a Morphy Richards Kitchen Appliances - Other Expert? Answer questions, earn points and help others
