Question about GPS
My 2003 Polo 1.6 has developed a strange problem. The left side park lights front and rear as well as the aircon stopped working. I have checked the fuses and they are all fine. Aircon compressor and gas pressure check out fine. What can it be?
  • 561 Answers
The only thing i can think of is some power mangement issue. check that the two are on the same circuit. e.g. are secured with the same fuse, this may indicate bad connection of the fuse ensure the fuse connections are clean maybe spray some WD40 or equivelent contact spray on the contacts.
i know that you can put your side light on one side of you leave you indicator on when you switch off and remove the key, as a park light, depends on which side is left on for left or right side.
It maybe related to the trafficator/indicator sytem.
if not, then there seems to be a short circuit somewhere or perhaps a cable break.
has your vehicle been in a traffic accident in the past where the cabling has been repaired?
this repair may have broken. or a cable socket may have disconnected. check all cables in the engine compartment especially to the lights.
the next would be to take the car to a dealer and have them check it over as there maybe more than one problem.
I hope this was helpful.
Posted on May 23, 2011
My left side tail light doesn't work after changing the lamp. Jeep 2007 - Commander
it worked before the change out?
there are 3 things that are first. on advance electronics, cars. like this. 2007 is 1st year, of wild complexity.
  1. check fuses first. MIP fuse #8,9,10 (8 is left) check that?
  2. check action of park relay
  3. check for trailer wiring hacks (do you have factory hitch option?)
  4. and scan the PCM , do you see any park fail DTCs'
DTCs are system errors.
that is first.
next if not solved, we look in the FSM for that chapter, and the schematics, to see how its is structured. (varies by year, car)
FSM JEEP XK 2007 (book)
factory service manual.
left side rear tail (park) (tail is old name , car has many park lamps now , not just 1 or 2 tails like in the old days.
so it park and the relay of same name.
there are front parking lights too... do those all work>?
my guess, is you didnt check fuses first.
am i right?
fuse 8 is blown?
but that takes out front left park
and left side marker (park ) lamps too.
so did you look at all left park lights first>?
i bet not, if im wrong then you do have wiring errors.
or the new lamp from china is shorted inside, (common)
try one more lamp , like from GE or Philips.
Feb 24, 2015 | Jeep Cars & Trucks
The turn light dont work
1. replace bulbs, front left and rear left. 2. clean bulb sockets and connectors. 3. check for damaged or loose connectors.
Nov 24, 2013 | 2003 Kia Sedona
Front passenger and rear drivers side parking lights not working on 2003 Ford Focus. What could be the reason?
check bulbs. if bulbs are good check bulb sockets. I would suspect one or the other are bad.
Apr 13, 2013 | 2003 Ford Focus
I have a 2003 vw polo 1.4 (hatch) - round lights in front. Teh problem is that when i trun the lights on, the 1st turn is teh park lights which work, then the 2nd one is for the main lights, then nothing...
your polo is not getting the power which it need to gliow your head lamp instantly so i advice to took help from the link given and you can get help to solve it http://toolsnyou.com/
Aug 13, 2017 | Volkswagen Cars & Trucks
03 chevy venture rt.front parking light&turn light don't work replace bulb&socket
The rapid flashing occurs because of the light problem. If the 20A PARK LP fuse in the underhood fuse block is OK, the front marker lamps and the park lights should turn on when you set the headlamp switch to PARK. If the 10A T/SIG fuse in the instrument panel fuse block is OK, and the ignition switch is on, moving the turn signal multi-function switch to signal a right or left turn should cause the turn signals to flash. If this doesn't happen, check for a missing ground connection to the socket you replaced and check to be sure the replacement lamp was not forced into the socket backwards (it happens).
Sep 17, 2012 | 2003 Chevrolet Venture Passanger
Need to know on a 2003 Jaguar X Type what fuse goes to the Fuel pump? The fuse box cover only lists the fuses by number.
The fuse box in the passenger compartment has the fuse you want, it is the F81 Mini 20 Yellow Fuel pump control module other fuses in that compartment are.
F60 Mini 20 Yellow Power windows left-hand.
F61 Mini 20 Yellow Power windows right-hand.
F62 Mini 7.5 Brown Rear fog lights.
F63 Mini 7.5 Brown Right-hand - front side light, side markers, rear lights
F64 Mini 7.5 Brown Left-hand - front side light, side markers, rear tail lights.
F65 Mini Not used.
F66 Mini 30 Green Left-hand power seat switches, heater module, lumbar pump.
F67 Mini 5 Tan Battery back-up sounder, transit relay, HID/dip relay, automatic transmission control module.
F68 Mini 15 Blue Cigar lighter.
F69 Mini 7.5 Brown Telematics display, In-car entertainment head unit, antenna module, navigation module, VICS (Japan), parking aid, amplifier premium 1 system, phone handset, phone power supply module, instrument cluster, PATS module.
F70 Mini 30 Green Right-hand power seat switches, heater module, lumbar pump.
F71 Mini 15 Blue VICS (Japan), telephone transceiver, telephone handset.
F72 Mini 15 Blue Radio head unit, CD player, navigation electronic control module, diagnostic connector/OBDII connector.
F73 Mini 15 Blue Sunroof unit/module.
F74 Mini 15 Blue Instrument cluster, Premium ICE amplifier unit.
F75 Mini 7.5 Brown Mirror fold back module, battery back-up sounder, air conditioning ECU.
F76 Mini Not used.
F77 Mini 7.5 Brown Left-hand and right-hand heated seats modules.
F78 Mini 5 Tan Phone power supply.
F79 Mini 10 Red Automatic transmission only: Reverse lights, reverse light switch, reverse park aid, electrochromic mirror, instrument cluster.
F80 Mini 7.5 Brown Park interlock, heater switch, OBDII, blower relay.
F81 Mini 20 Yellow Fuel pump control module.
F82 Mini 10 Red Variable power steering, alternator.
Manual transmission only: Reverse lights, reverse light switch reverse park aid, electrochromic mirror, instrument cluster.
F83 Mini 15 Blue Not used.
F84 Mini 5 Tan Instrument cluster, passenger airbag fascia light, seat weight sensor.
F85 Mini 7.5 Brown Right-hand high beam light.
F86 Mini 7.5 Brown Left-hand high beam light.
F87 Mini 15 Blue Front Fogs master light switch.
F88 Mini Not used.
F89 Mini Not used.
F90 Mini 7.5 Brown Stop lights, cruise control.
F91 Mini 10 Red Sunroof, electrochromic mirror, power windows, power mirrors.
F92 Mini 10 Red Manual transmission cruise control clutch switch, ignition coils, automatic transmission rotary switch.
F93 Mini 30 Green Windscreen wipers.
F94 Mini 20 Yellow HID module.
F95 Mini 10 Red Airbag restraints module.
F96 Mini 7.5 Brown ABS module.
F97 Mini 7.5 Brown Glove compartment light, instrument cluster lights, licence plate lights.
F98 Mini 10 Red Mirror heaters.
F99 Mini 10 Red Luggage compartment light, footwell lights, puddle lights, vanity mirror lights, interior lights, aircon control unit, roof console unit
Jan 07, 2011 | 2003 Jaguar X-Type
A pulled fuse panel for a 2003 Jeep Liberty, there are 39 fuses inside a vehicle. I need to know what these fuses are and what they go to.
The fuse box diagram is a sticker placed on the inside of the fuse box cover. This cover is located on the left end of the instrument panel (driver side). The sticker just uses numbers to indicate the fuses. I will match the fuse number with its purpose:
1. Power Outlet, Front
2. Rear Fog Lights
3. Horns
4. Headlight, Low Beam, Right
5. Headlight, Low Beam, Left
6. Body Control Module / Power Door Locks
7. Spare
8. Spare
9. Right Park Light / Right Tail Light / Trailer Tow Lights / Cluster
10. Spare
11. Flasher
12. Stop Lights
13. Body Control Module / CMTC / Cluster
14. Spare
15. PDC Fuel Pump and Auto Shut Down Relays / SKIS
16. Power Outlet Rear
17. Rear Wiper
18. Radio Choke
Jun 19, 2010 | 2003 Jeep Liberty
My air con ,rear wiper and fog lights have stopped working on a vw polo 2.0 hatch 2005
Consult your Car Owner manual to locate where the Fuse Box is located: Check the appropriate fuse(s) for the appliances in your car that are not working - I suspect that the AirCon, RearWiper and Fog lights are sharing the same fuse as it would be extremely unusual to have 3 separates fuses blown at the same time. ps. The Polo usually has some spare fuses in/near the Fuse Box.
Dec 20, 2009 | 2005 Volkswagen Golf
GPS Logo
Top GPS Experts
Are you a GPS Expert? Answer questions, earn points and help others
