Question about HP LaserJet 3050 All-In-One Printer
When i send print appears in a printer press v to use availble media manual feed plain A4
  • HP Master
  • 1,915 Answers
The print job you are sending is in A4 format. If you are using Adobe Acrobat you will sometimes find that documents created in places such as Europe will be A4 not letter size. Check the settings when you send the print job as Acrobat gives you the option to resize and print to available media. You can also check your printer settings as there may be the option to automatically print A4 to letter.
Posted on May 23, 2011
Canon Inkjet, Not Printing?
Hi Rosa,
There was a paper jam and you cleared the jam, however you missed out to do one other thing. Cleaning the Rollers.
If the Paper Feed Roller is dirty or paper powder is attached to it, paper may not be fed properly.
In this case, clean the Paper Feed Roller. Cleaning will wear out the Paper Feed Roller, so perform this only when necessary.
You need to prepare: three sheets of A4 or Letter-sized plain paper
1.Make sure that the power is turned on, and remove any paper from the Rear Tray.
2.Open the Paper Output Tray gently, and open the Output Tray Extension.
3.Clean the Paper Feed Roller without paper.
(1) Press the g0081065_tcm14-774017.jpg (Maintenance) button repeatedly until b appears.
(2) Press the Black or Color button.
The Paper Feed Roller will rotate as it is cleaned.
4.Clean the Paper Feed Roller with paper.
(1) Make sure that the Paper Feed Roller has stopped rotating, and load three sheets of A4 or Letter-sized plain paper in the Rear Tray.
(2) Make sure that b appears on the LED, then press the Black or Color button.
The machine starts cleaning. The cleaning will be completed after the paper is ejected.
This should fix the issue
Regards,Suhail
Nov 03, 2011 | Canon PIXMA MP495 InkJet Printer
When we send any file to print it is giving load manual feeder error
In most cases if the printer is asking for an unexpected manual feed it is because the paper tray is not set to the right paper size or type. To set the paper size to the most common size and type (letter size plain paper) use the following instructions.
1. Press the Menu button.
2. Press the right arrow key until Paper Menu then press Check Mark.
3. Press the right arrow key until Size/Type then press Check Mark.
4. Press the right arrow key until Tray 1 then press Check Mark.
5. Press the right or left arrow key until Letter then press Check Mark.
6. Press the right or left arrow key until Plain then press Check Mark.
7. Press the back button until Ready is displayed.
This will set up your printer for plain letter paper and should relieve the manual feed error unless your computer is sending other paper size/type settings.
Aug 09, 2010 | Lexmark X364dn All-In-One Laser Printer
Auto head alignment
#1 of 2
Carryout a Manual Print Head Alignment If Possible.
If the results of Automatic Print Head Alignment are not satisfactory, follow the procedure below to perform Manual Print
Head Alignment.
1 Make sure that the machine is turned on, and then load three sheets of A4 or Letter-sized plain paper in the Auto Sheet Feeder or the Cassette.
Important. You cannot print the print head alignment pattern if paper of size other than A4 or Letter is loaded. Be sure to use A4 or Letter-sized plain paper.
2 Open the Paper Output Tray, and then open the Output Tray Extension.
(1) Put your finger in the rounded indent of the Paper Output Tray and open it gently.
(2) Open the Output Tray Extension.
3 Press the Paper Feed Switch to select the paper source where you have loaded paper.
4 Select Settings on the HOME screen.
5 Select Maintenance, then press the OK button.
The Maintenance screen is displayed.
6 Select Manual head align, then press the OK button.
The confirmation screen is displayed.
Note. If you select Head alignment print, the machine exits the process after printing the current head position adjustment values.
7 Select Yes, then press the OK button.
8 When the Print Head alignment pattern is printed, select Yes, then press the OK button.
9 Look at the printout. From the patterns, select the most even, least irregular patterns for each column and input their numbers. Press the OK button.
(1) Select a column to input the pattern number.
(2) Use the or button to input the number of the pattern.
(3) Repeat the steps (1) and (2) until you finish inputting all pattern numbers, press the OK button.
Oct 08, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Doesnt print faxes or copies because the paper isnt picked up from the tray
1. Remove any paper from the Auto Sheet Feeder and Cassette.
2. Select the paper source with [Feed Switch].
3. Press [Menu] repeatedly until 3.MAINTENANCE> appears.
4. Use [<] or [>] to select <ROLLER CLEANING>.
5. Press [OK].
6. When cleaning has finished, repeat steps 3 to 5 for a total of three times.
7. Load A4- or letter-size plain paper in the selected paper source and repeat steps 3 to 5 additional three times.
Oct 01, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Hp laserjet p3005dn tray1 manual feed problem
you can choose mp first in "paper handing" printer menu or print tray1 is A4 default in properties of printer software.
Jul 25, 2009 | HP LaserJet P3005n Printer
Printer does not recognize that there is paper in the tray
Using the printer panel; you need to change tray paper size from a4 to letter or the size you are using to print on.
  1. Press the MENU button.
  2. Press the down arrow until Tray Settings appears and press the return%20arrow%203100cn.jpg button.
  3. Press the down arrow until Paper Size appears and press the return%20arrow%203100cn.jpg button.
  4. Press the down arrow until the specific paper tray (Tray 1, Tray 2, or Multipurpose Feeder) appears and press the return%20arrow%203100cn.jpg button.
  5. Press the down arrow to select the specific paper size, and press the return%20arrow%203100cn.jpg button.
  6. Press the MENU button.
An astrick will appear to the right of the size paper that the printer currently has selected.
Apr 03, 2009 | Dell 3000cn Laser Printer
HP P3005 Will not pull from Tray 1
Click File > Print > Properties to check your settings.
To verify that tray 1 is working, put paper in tray 1. Press green check until you see Information Menu. Scroll using arrows until you see Print Menu Map then press green check. If it prints from tray 1, your problem is not with the printer, but with the PC settings.
i has follow this step, but need to press green check button to resume print menu map.
tray 1 manual feed set to A4 paper plain size
manual feed is on.
there is paper on tray 1
ps setting tray1 manual feed is A4 plain size paper.
send print to tray1 manual feed even there is paper at tray 1
i still need go to the printer and press green check button to resume print
Sep 23, 2008 | HP LaserJet P3005n Printer
Problem While printing
Hi there it seems to me that you have the printer driver set incorrectly.
First on the computer click on
Start
Then Control panel
Printers and Faxes
once in there right hand click on the pinter and select printing preferences.
Select the tray you wish to use as your default. Ok and exit that.
On the printer press the green tick button move the up or down arrow until paper handling is displayed. Select which feed either cassette or MP then sizes for this tray. Once that is complete select what media type the paper is i.e. plain preprinted or others.
(You may have to do that in the printing preferences within the driver as well)
That all going well you should now be able to press the print button and the page will come out from where you asked it from and with out pressing any buttons.
Hope this was of some help.
J
Dec 26, 2007 | HP LaserJet 2420 Printer
HP LaserJet 3050 All-In-One Printer Logo
100 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
