Question about ASUS M2N-MX Motherboard
USB Device not recognized. Pl - ASUS M2N-MX Motherboard
  • ASUS Master
  • 32,281 Answers
If your computer or laptop has a problem detecting a USBhard drive or a USB device, and another computer can detect it, then theproblem could be a RF interference problem. Try using an USB cable that is a shielded USB cable (ie. AnUSB cable that has a clear plastic covering and you can see a metallic weavewhich covers the wires) OR a USB cable that has a Ferrite core attached to theUSB cable (the ferrite core is a cylindrical object approximately 30mm long X15mm diameter and it is attached to the USB cable near the connector).
Posted on May 23, 2011
Purchased this mob before two months but on connected with pc shows ' USB DEVICE ODES NOT RECOGNIZED. pl. do some thing'
it may not be compatable or you need to get software installed for the item you are using..
Nov 19, 2013 | Intex Pool & Spa
My wevcam on VGN-CR510E is not detected? please help!
First check whether the built in Camera is recognized in the Device Manager window under Imaging Devices or USB Controller.
Windows + R Key, type devmgmt.msc to access Device Manager.
If the Built in web cam is detected in Device Manager, then uninstall the Camera Device by right clickin on the device and selecting Uninstall option.
Once you uninstall the Driver, you can download and install the Camera Driver from the following link:
http://esupport.sony.com/US/perl/swu-download.pl?mdl=VGNCR510E&upd_id=3586&os_id=28
Download and install the Driver in your Computer. Then reinstall the ArcSoft WebCam Companion from the following link:
http://esupport.sony.com/US/perl/swu-download.pl?mdl=VGNCR510E&upd_id=3596&os_id=28
Then restart the Computer and use the Camera.
If the Built in Camera is not detected in the Device Manager, it means Hardware issue and service would be necessary.
However, you can use a USB Camera and use it with the USB Port in your Computer.
Jun 29, 2010 | Sony VAIO VGN-CR510E/L Laptop
The external HD function only in the back USB port
Pl check for the serviceability and also whether the front ports are enabled or not from the device manager option using right click manage option on My Computer icon on desktop.If these are disabled , please enable them.
May 23, 2010 | Verbatim SmartDisk Firelite Portable USB...
When I try to capture a video into the imagemixer software, it says it does not recognize the camcorder.
lets see if it's a software issue or not.try to use windows moviemaker as your video capturing software instead of imagemixer. if issue is with imagemixer alone, you may want to uninstall and reinstall and update the software.check website for update: http://support.d-imaging.sony.co.jp/www/disoft/int/pixela/imx/dl/index.html and download the free update for imagemixer ver.1.5 for sony.
if still it's not recognize we can isolate the issue with the camera or connection. if your using usb,make sure you have the usb driver installed properly.you can download the device driver at this website: http://esupport.sony.com/US/perl/swu-list.pl?mdl=DCRTRV350 and make sure you don't have the camcorder connected during the installation.also have the usb stream setting (under setup menu) set to on (see:p.221 of your manual). after that the camcorder should be recognized. if your link connection (ieee1394 or dv) it should be a plug-and-play connection. better check computer connections and connected device in device manager screen to see if the cam is listed as an unknown device.if it does, you can be sure nothing is wrong with the usb cable. it can be a connection.issue.try diff ports if available (usb back port at the back is recommended for use, that is directly connected to the motherboard) and check. if the cam doesn't show or you don't have any indication that it's connected.try using a diff usb cable.if still doesn't try using a diff compatible PC.use same procedure.if' it's still the same, unit may require service.hope this helps.thanks:)
Apr 15, 2010 | Sony Handycam DCR-TRV350 Digital Camcorder
My web cam is not found in vista and USB device not recognized
For whatever reason, I could not find your model in the list on Sony's website.
However, I can provide you with a link that will let you use the website's auto detection to find your drivers:
http://esupport.sony.com/US/perl/select-system.pl?DIRECTOR=DRIVER&PRODTYPE=24
Hope this helps :)
Nov 28, 2009 | Office Equipment & Supplies
IPOD MP4- USB DRIVER NOT RECOGNIZED BY XP
Hello!!!
Try connecting to different USB slot!! and try changing the cable too!!
Oct 26, 2008 | Apple iPod nano
Mass storage device not working
transend pendrive not recognized
Feb 28, 2008 | Electronics - Others
USB Connection Not Recognized
check the ports thr' control panel-if driver for usb port is missing pl. reload usb driver.check with pen drive whether the usb port recognizes the pendrive as it flashes the light on the pendrive.
Dec 21, 2007 | JVC 20GB Everio GSeries HDD Digital...
ASUS M2N-MX Motherboard Logo
104 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
