Question about Graco Nasalclear Aspirator - 1750335
Loss of suction battery is new sound works o ring and black stopper in place
How to adjust flow keeper
that is usually an indication that there is suction loss or the diaphragm is again damaged. good water chemistry will lengthen the life of this part.
Aug 07, 2014 | Zodiac BARRACUDA G3 IN-GRND CLEANER
Holden (Opel) 98 model Barina
No lights on the dash means circuit breaker or fuse able link blown,check for loss of power with a test light,if battery is good and charged up.
Jul 24, 2014 | Central Power Door Locking System
Lg 300B no suction through hose
If you have a loss of suction overall, that generally means one of two things, either you have a clog somewhere near the motor or the motor is fried and will never turn fast enough to make proper vac.
Nov 09, 2013 | LG LUV300B Bagless Upright Vacuum
Cannot open the battery compartment on my suunto x6 without breaking it....any ideas?
  • Turn the Suunto over to view the backside. Insert the quarter in the coin slot located on the battery compartment cover. Turn the coin counterclockwise to the "Open" position marked on the back of the case.
  • Remove the battery compartment cover. Remove the old battery from the battery compartment. Make sure the o-ring and all surfaces are clean, dry and not damaged. Do not stretch the o-ring!
  • Place the new battery into the battery compartment (negative side down, positive side up). Make sure the o-ring is in its place, as to keep the Suunto waterproof. Place the battery compartment cover back onto the backside of the watch.
  • Insert the quarter back into the coin slot and turn the coin clockwise to the "Close" position marked on the back of the case.
  • If this doesnt work take to a jeweler who has tools.
    Jewel
    Aug 31, 2010 | Suunto X6 (black) Wrist Watch
    Drain stopper in the bathtub has come off how do you reinstall when the stopper turns with a knob on the tub
    the stopper just sits in the hole. When you turn the knob the cable operates the piece that raises and lowers the drain plug. The weight of it and the suction of the water is what seals it....provided the o-ring is good on the plug.
    Oct 12, 2009 | Home
    Leaking rusty water
    Ensure the black "duckbill" gasket is mounted on the bottom of the dirty water tank. This gasket is removeable, and resembles a duck bill.
    When i purchased mine at Target, new - it was missing the gasket, causing loss of suction. Interestingly it worked for a week or 2 then started leaking. Now, with the gasket in place, it works like a charm.
    Gasket is about 2 bucks available from Bissell.
    Aug 14, 2009 | Bissell SpotBot Robotic Wet/Dry Vacuum
    Dyson suction loss
    make sure the filters in the bottom are clean, then remove the canister and you will need to clean it thouroughly, pay close attention to the upper section inside where the "cones" come togetheri have read that they are prone to clog up here and lose suction, google dyson suction loss or how to clean a dyson ect...pay attention to getting the rod that releases the bottom to dump back in the correct place or it will not work right. a few write ups tell about this!
    Jan 31, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
    Unsure how to mount tomtom on car windshield
    I was perplexed by the lack of instruction as well. However, I took the unit to my car and realized that the black disk is not needed for mounting the unit to the windshield. If you look carefully at the bumpy plastic ring just above the suction area, there are two little pictures on the back of a lock; one open and one closed. With the ring in the open position, push it against the windshield and turn it to the closed position. It then sticks to the glass very well. I now just snap the unit in and out of the mounting ring that I leave stuck to the glass. I hope this helps. I assume that the presence of the black disk is to bring people closer together with digital communication.
    Dec 14, 2008 | Tomtom One XL GPS Receiver
    Suction loss?
    hi samdan... have you checked all the hose attachment vents .. ie Under the vacuum as well... How long is it since you replaced the filters?
    Try giving the Yellow cone inside a blow out. these tend to become clogged from time to time!
    Regards Faggly
    Mar 21, 2008 | Dyson DCO3 Absolute Bagless Upright...
    Graco Nasalclear Aspirator - 1750335 Logo
    814 people viewed this question
    Top Graco Baby Care Experts
    ray gallant
    Valeriy Bacherikov
    Level 1 Expert
    ReGina Lewis
    Level 1 Expert
    Are you a Graco Baby Care Expert? Answer questions, earn points and help others
