Question about Fossil Watch Style # JR9760 Watch for Women
I bought a brand new Women's fossil watch the JR 9760 analog dial watch. I can't get it working for the first time. I've followed all the instructions on how to set the time and date closely but it is not working. What should I do. Also is it normal for the watch not to have a second hand? and how does the watch work properly without a battery? Please help me to get my watch working. I really like the style - it's a birthday present! I bought it on Amazon.com Thank you. The watch only has an hour and minute hand and the date is indicated in the middle at the bottom of the face. That's it!
SOURCE: Instruction Manual for Fossil Watch
go to fossil .com and click on customer service that is where all manuals are hope this helps
Posted on May 14, 2008
  • 6 Answers
SOURCE: Help! I need instruction manual for Fossil watch
If you go to www.fossil.com you can find the manuals for most of their watches.
Posted on May 13, 2009
SOURCE: Time change Fossil JR 9120
i already found one link with all Fossil manuals.
Thank´s for your support.
Posted on Feb 09, 2010
escapement
  • 2334 Answers
SOURCE: fossil JR-8748
Click on my profile (escapement), then click on Tips and Tricks. There you will find links to all watch manuals. Rate me, please .
Posted on Apr 14, 2010
gemineye61
  • 831 Answers
SOURCE: i just bought the fossil
You can order replacement bands directly from their site!! For your convienience, I am giving you the link. Best wishes!!
http://www.fossil.com/en_US/shop/customer_care/static/fossil-warrantyRepairs.html
Posted on Aug 13, 2010
How do I set the time on the Stella Tort Glitz watch (ES2795)? I've checked the Fossil website and tried their instructions and they don't work. I have tried moving the hands for the time set in...
Try turning the knob cc and cw a number of times; then pull the knob out hard all the way to pos. 3 and see if this helps. Sometimes it takes a number of times to get it to engage.
Jan 09, 2018 | Fossil Stella Clear Multifunction Watch...
I haven't worn my fossil watch (FS 4337 model) for some time & decide to wear it & shook it, adjust it, & it dosn't work. Usually when I don't wear it for about 2 weeks, I shake it...
If you have a Fossil FS4337 Chronograph, shaking the watch shouldn't be doing anything other than exercising your muscles; the movement is a battery-driven quartz movement whose movement is controlled only by whether the stem has been pulled out (stopping the movement and saving power) or whether the battery still has enough power to activate the stepping motors that move the watch hands. Based on the symptoms that you've described, I would suggest that it's probably time to change your watch battery.
Often, when a watch battery is running low but isn't completely dead, pulling the stem into time-setting mode will stop the movement and permit the battery to "rest," giving it (briefly) a bit more reserve amperage to put out when you push the stem back in. That's how you can sometimes get a quartz watch to run for a few minutes after the battery appears to be dead. That may also be why your watch has started running again after you've set the time and date.
Fossil analog quartz watches tend to use silver oxide (usually #377 or #379) batteries instead of longer-lasting lithium batteries. In ordinary use, I would expect a silver oxide battery to provide between 1 and 2 years of service before it needs to be replaced. I can't remember if Fossil chronographs (which also use quartz movements) use a silver oxide or lithium battery. Lithium batteries often provide an additional year or two of service in analog watches, compared to silver oxide cells; digital watches using them supposedly may last as long as 10 years with a lithium battery, assuming you don't use the backlight or audible alarm functions. Note, however, that these batteries are different sizes and different voltages, so you can't substitute one for the other.
Finally, none of this advice applies if you have a Fossil watch with a true mechanical movement in it. In that case, gently shaking the watch may spin the winding rotor enough to start the watch back up again. However, an even faster way of winding those watches is to use the winding / time set crown to wind the mainspring directly instead of relying on the geared-down action of the winding rotor. Automatic watches can bind up if they are not used for a period of time; the lubricating oil used in some of the pivots can harden--or at least provide enough resistance that the movement may require more initial force to start running than to continue running. That behavior usually indicates that it's time to have the mechanical movement cleaned and re-lubricated.
May 31, 2011 | Fossil Brushed Brown Dial Chronograph...
What type of battery does the Fossil Ch2473 use? I called Fossil and they could not help me, instead they insisted I pay them $15 to replace the battery and wait 2-4 weeks for shipping. However, I...
The vast majority of Fossil analog wristwatches take either a #377 or #379 watch battery. The #379, being slightly smaller, is somewhat more commonly found in women's watches than in men's watches, but I have seen both types used in men's and women's watches alike. However, the Fossil CH2473 includes chronograph functions, which means that you can have multiple motors inside the watch running simultaneously. As a result, it's possible that this watch will require a different / bigger bigger. However, if it's not one of these batteries, or even if it takes a 3-volt lithium battery instead of a 1.5 volt watch battery, it will still be something pretty mundane.
In general, common batteries like the type I expect you'll find inside your watch are commonly found at many drug stores, jewelry store counters at places like Walmart and Target, and even at some dollar stores. Be aware that cheap dollar store batteries are usually alkaline, not silver oxide, versions of the same size battery. Alkaline batteries may work perfectly well in many watches, but they have a somewhat different energy performance curve over time, and, in general, they won't last quite as long as a comparable silver oxide battery. In addition, for reasons I've never been able to figure out, some of the Fossil watches that I've serviced would not function with an alkaline battery--but would work fine when I put in a silver oxide battery of the same size and voltage. I have not been able to see a pattern to predict when this will and will not occur. Lithium batteries, whether "brand name" or generic, should have the same performance curve.
If you do open up your watch to change the battery and don't recognize the battery type/code on your battery, don't give up. Watch batteries have different numbering schemes, depending on the manufacturer. Here's a link to a cross-reference chart that will help you "translate" one code into another. I would suggest starting by looking at the #377 line to see if one of those cross-reference codes matches what you have. However, you may need to look around the chart to get an exact match:
http://www.watchbatteries.com/custom.aspx,,id,,75
As a final thought, the backs of some Fossil watches are very snugly fitted to their cases. You can generally get them off without too much of a problem, but there's a good chance you may need a jeweler's press to get them to snap back on properly. I've noticed this most with round watch backs; I generally haven't needed a press to close oblong or tonneau-shaped Fossil watches (or some round watches, too). A jeweler's press spreads the pressure evenly around the edges of the watch back and watch case, preventing damaging pressure on the watch crystal, watch movement, and watch back. Clamping the watch in a regular vise to try to press on the back runs a high risk of damaging your watch, and I do not recommend trying that, no matter how frustrated you get. It's much safer (and cheaper, overall) to tip someone with a vise a couple of dollars to close up your watch for you.
May 15, 2011 | Fossil CH2473 Watch for Men
I am needing to find out what kind or size battery The Fossil Blue AM-3574 takes and where I can purchase them.
These batteries are commonly found at many drug stores, jewelry store counters at places like Walmart and Target, and even at some dollar stores. Be aware that cheap dollar store batteries are usually alkaline, not silver oxide, versions of the same size battery. Alkaline batteries may work perfectly well in many watches, but they have a somewhat different energy performance curve over time, and, in general, they won't last quite as long as a comparable silver oxide battery. In addition, for reasons I've never been able to figure out, some of the Fossil watches that I've serviced would not function with an alkaline battery--but would work fine when I put in a silver oxide battery of the same size and voltage. I have not been able to see a pattern to predict when this will and will not occur.
May 12, 2011 | Fossil Blue watch #AM3574 Watch for Men
I have a Fossil AM-3719 watch. I bought it in October and it just stopped working. Shouldn't the battery last longer than that? Where can I get another battery? I'm located in London, Ontario, Canada.
Before you take any action which may invalidate your warranty, have a word with Fossil costumer service (go to http://www.fossil.com/en_US/shop/customer_care/static/fossil-customercare.html).
All the watches that I have owned ran for more than a year and Fossil may sort it out for you.
Apr 11, 2011 | Fossil Casual Metal Dial AM3719 Watch for...
How do you clean the crystals?
mcdevito75 here, Ebay sells a very good p[olish for your crystal, sign onto eaby and type in search Novus Polish, It"s a 3 step polish for your crystal.
Jun 27, 2010 | Fossil Analog Dial AM4175 Watch for Women
-> Go to fossil.com
-> Customer Care
-> Product Info / Watch Instructions
-> Do a mouseover on the various headlines to see the design of your watch.
-> Download desired PDF file
Problem solved. Thank you!
Aug 29, 2007 | Fossil CH2331 Wrist Watch
Fossil Watch Style # JR9760 Watch for Women Logo
Top Fossil Watches Experts
Ansel Alberto
Ansel Alberto
Lyle Siemens
Lyle Siemens
Are you a Fossil Watch Expert? Answer questions, earn points and help others
