Question about Ovens
Simpson La Scala.Good Day, Have an oven light bulb supplied by NZ support retailer (25 Watt) that always blows within fifteen minutes.No internal structural changes or alterations have been made.Operation of the unit is totally normal.Mystery !Can you advise . Regards, Dennis W Gale.
2 Suggested Answers
  • 561 Answers
SOURCE: Correct wattage bulb in Simpson
if you are refering to the light inside the oven, I dont think there is a problem with wattage as the oven is rates to high wattage
and it is also inside the oven, so in an area that can cope with heat.
if possible check remove the old bulb and check the wattage on the glass or on the side of the fitting.
I personally would recommend that a 40W should be suitable.
I hope this was useful
Posted on May 23, 2011
I want to remove the oven door for cleaning but not sure how.
Try opening the door about 6" (15 cm) and pull straight up.
May 08, 2017 | Ovens
Bottom oven lights keep burning out.
The oven bulb is different from an appliance bulb. The glass and base are specific for the high temperature application that is seen in a oven
The link from sears shows a sample of an oven bulb and the price represents the special characteristics.
I have seen where some bulbs are rated at 130 volts?
Range Oven Light Bulb Part Number 316538901 SAME DAY SHIP GUARANTEE from...
This link from Amazon relays some of the one star reviews of the appliance light used in the oven application. All ovens are maybe not equal where the heat may be more significant in one make over another.
Amazon com Customer Reviews GE Appliance 21188 40 Watt 415 Lumen A15 Light...
Another set of reviews that again show problems in some applications for bulb life.
40 Watt Incandescent A15 Clear Appliance Light Bulb 416768 The Home Depot
Not many reviews on this bulb. The 130 volt rating is an indicator of longer life? Of the choices I wood choose the following.
Sorry I couldn't help you more. Disappointing that no bulb stands out as the very best.
Bulbrite B40A15C 130V 40 Watt Incandescent A15 Appliance Bulb Clear Amazon...
Jan 09, 2016 | Ovens
How do I change the bulb inside the cooker of the B5741 cooker
Oven Lighting
Warning: There is a danger of electric shock! Prior to changing
the oven light bulb:
  • Switch off the oven!
  • Disconnect from the electricity supply.
Place a cloth on the oven floor to protect the oven light and glass cover.
Replacing the oven light bulb/cleaning the glass cover
  1. Remove the glass cover by turning it anticlockwise and then clean it.
  2. If necessary:
Replace bulb with a 40 watt, 230 V, 300 °C heat-resistant
oven light bulb.
3. Refit the glass cover.
Dado
Apr 15, 2015 | AEG Ovens
HOW TO REPLACE THE LIGHT BULB IN MY OVEN
Oven Lighting
Warning: Risk of electric shock! Prior to changing the oven light bulb:
- Switch off the oven!
- Disconnect from the electricity supply.
Changing the oven light bulb/cleaning the glass cover
1.Remove the glass cover by turning it anti-clockwise and then clean it.
2.If necessary: replace with 25 watt, 230 V, 300 °C heat-resistant oven lighting.
3.Refit the glass cover.
24472822-skr3uzd4ii43xzwyhmpsswym-3-0.jpg Dado
May 21, 2014 | Electrolux EOB5665G Ultrafan Electric...
Replace bulb
oven bulbs are special bulbs only available from an oven service agent
although the ratings are the same , the glass used is actually pyrex glass as ordinary glass will not handle the oven temperatures
Dec 24, 2017 | Viking Professional VESO130 Dual Single...
Simpson Oven Manual
http://www.simpson.co.nz/ProductManualsBrochures
May 16, 2013 | Ovens
Correct wattage bulb in Simpson La Scala electric oven.
May 23, 2011 | Ovens
Cant remove glass cover to replace bulb on Simpson La Stella Atlas series oven
I have a Simpson Atlas Mira. Was having a hard time getting the glass cover off too so looked on the net for a solution. Couldn't find one so I persevered and sorted it...
The glass cover has a screw-off thread (like a glass jar) which unscrews anti-clockwise (lefty loosey). I had to give it a good few wiggles and pulls before it would start unscrewing. I also had to use a damp towel to get a proper grip - it's a slippery little bugger - but I got it in the end!
Hope this helps someone - good luck!
JD Hamilton, NZ
Aug 23, 2010 | Ovens
I don't know what wattage I need for the bulb
You can fit a 15 or 25 watt bulb, as long it it is the correct thread, and it is able to withstand 300 degree temperature.
This is very important, otherwise it will blow with the heat.
Hope this helps.
Jan 20, 2010 | Zanussi ZBS963X Electric Single Oven
Can not set clock on Simpson La Stella oven
How do i set the time on a Simpson La Scala wal oven
Jun 30, 2009 | Electrolux Ovens
Ovens Logo
73 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
