NEC Washing Machine NW-891 has error code LE showing. What does this mean?
ghost4548
  • 776 Answers
SOURCE: nec nw-891 washing machine will not complete the programmed cycle
Apparent malfunction in the timer circuits. Specific Component replacement not available.
Posted on Jun 30, 2009
SOURCE: the NW - 891 NEC
Our nec washing machine nw 891 leaks water into drum when finished , I think it needs new washers, is this hard to do?
Posted on Jan 17, 2010
Sebin
  • 712 Answers
SOURCE: NEC washing machine model NW-891 can't get past
It is the problem of the board, which can be fixed, by a specialized mechanic. Contact a nearby mechanic with sufficient tools. Sometimes you will have to replace your board which will be expensive. In that case, if your unit is an old one, try to get an exchange.
Posted on Jul 05, 2010
blueextc3221
  • 15935 Answers
SOURCE: Hot and cold water inlet valve was replaced but no
If you suspect you have a defective Water Inlet valve (also known as a FILL valve or MIXING valve) it can easily be diagnosed by performing the following steps:
- First, make sure the water taps are turned on all the way, and the fill hoses are not kinked in anyway. If everything checks okay, proceed to the next step.
- Now, turn the water taps off, disconnect the fill hoses from the back of the washer and place them in the wash tub. Turn the taps back on and make sure you have proper and forceful water flow (minimum water pressure should be 10-25PSI).
- Check the sediment screens on the Water Inlet valve on the back of the washer. Sometimes these screens will clog with rust or sediment and prevent water flow. Cleaning with some distilled vinegar works well.
If you’ve attempted all the steps above, but still have no luck, more than likely the inlet valve is bad and requires replacement. Please, read all instructions thoroughly BEFORE attempting. This is a simple repair that any “Do-It-Yourselfer” can accomplish. Follow the steps provided:
1. Unplug washing machine.
2. Remove console. This can be accomplished in one of two ways depending on which type of console you have.
a. If the console has removable end caps, the caps lift off by prying on the top from the back of the washer. The cap will pull off towards you as you are facing the unit from the front of the washer. There will be a screw under each end cap that you will need to remove.
b. If the console does not have removable end caps, you will need to slide a putty knife under the front corner of each side and push in while lifting up. There is a retaining clip under each side that has to be released.
3. Once the console has been released it will lift up and fold back over the back of the washer in its resting position. Use care not to stress the small plastic hinges that hold it on. They can break easily.
4. Under the console will be two large brass colored clips. Take a large flat blade screwdriver and place it in the groove of the clip on the washer top. With the screwdriver firmly in the groove, push away from you towards the back of the washer. This will release the clips.
5. Disconnect the lid switch connector plug. This is the white colored plug on the washer top under the console.
6. Remove the washer casing. Open the lid of the washer. Using one hand, grip under the front rim of the washer opening. Do not grab the wash tub, just the casing. Tilt the washer case from the back first towards you, slide forward slightly, and then lift up. The entire case comes off exposing the wash tub and components.
7. The inlet valve is located on the back panel with two or more sets of electrical connectors attached to it. The connectors are usually color-coded to indicate which valve is HOT and which valve is COLD (In the case of a Mixing Valve, you may have additional electrical connectors). Remove the connectors and check the contacts for corrosion. Sometimes a good cleaning can restore a valve solenoid to working order. (You may want to label the connectors, if necessary, to ensure you know how they go back on).
8. Disconnect the small rubber water hose(s) attached to valve with a pair of pliers to release the hose clamps. Inspect the hose(s) for any evidence of cracking.
9. With the water hose(s) removed, loosen the mounting screw(s) and the inlet valve comes off.
10. Re-install new inlet valve following these steps in reverse order. Pay careful attention to make sure you correctly connect the HOT & COLD electrical connections (RED is usually the HOT water side). Make sure all hoses are fitted back in place and the hose clamps are snug.
11. Re-install washer case. With the lid of the washer open, place grasp case under front rim and place it on the washer frame. While looking down through the washer lid opening, make sure the front lip of the case is placed UNDER the washer frame and rocked back onto the frame to ensure that the small cleats on the frame fit into the slotted grooves on the washer case base. If you do not get the case seated correctly it will rattle and vibrate while the washer is in operation.
12. Make the back of the washer fits into the washer casing on each side and reinsert the brass clips. Place the clip into the slot on the back of the washer first, and then forcefully push it into the opening on top of the washer. It will snap back into to place.
13. REINSTALL LID SWITCH CONNECTOR. It is easy to forget. If you do not reconnect it, the washer will not work correctly.
14. Reinstall console.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 14, 2010
SOURCE: I am Looking for the
According to what's written in the manual...
'LE' will light up if the machine is unbalanced or the lid is open. This can be corrected by following operation: WATER SUPPLYfi RINSEfi DRAIN. However if the unbalanced condition is unchanged despite repeating the above operation, the lamp 'UE' will light up, and the buzzer will sound to indicate a problem.
Posted on Jan 21, 2011
I have a nec nw-691, when you put it on spin cycle it brings error message --lid open??? plz help
Yuo might try making sure it is still level but I'd just try using a lower spin speed. How have to use "gentle spin" when I wash towels or my washing machine has errors and stops. If still too damp just use a gentle spin only cycle once more to finish the job.
Apr 16, 2015 | Washing Machines
I have a daewoo washing machine dwd-g20dl showing error code LE
LE Washing machine door opening error
The washing machine or washer dryer door has been detected as open or unlocked.
·Close the door!
·Check the door lock switch
·Check the door latch
·Check PCB
Jul 09, 2014 | Daewoo Washing Machines
Washing machine not spinning, stops & the letters LE flash, washing machine is a NEC NW-892 Millenium
It sounds like your lid switch is not working correctly, look to see if there is supposed to be a finger that protrudes from the bottom of the lid and enters a hole in the top of the washer, this is a safety switch to ensure the lid is closed, it is possible the actuator finger is broken or missing, If this is the case, I have heard of people manually actuating the switch to finish the load, I am not suggesting that because there is a safety issue, but it has been done. Your washer might not have an exposed actuator,it could be hidden under the washer top, but the LE error code indicates the lid is open.
Nov 10, 2012 | Washing Machines
I am having a problem with my NEC NW752 Washing Machine. It runs through the cycle but will not drain the water. There were no kinks in the hose and when we hooked another washing machine it worked fine....
chances are that your daiwood / nec unit has a bad drain pump or perhaps the unit is not level or the drain hose is to high for the pump to pump out the water lastly
if you remove the front of the unit where the pump is located as you will see in the link I sent you there is a trap that may need to be cleaned out it has a hand screw cap that you can open and clean try that first before replacing the pump i sent you in the link NEC WASHING MACHINE WATER DRAIN PUMP NW752 NW891 NW652 NW 891 NW 81R eBay
Mar 04, 2018 | Washing Machines
I am Looking for the meaning to eror code LE on my washing machine it is an nec model No NW 452
Jan 13, 2011 | Washing Machines
NEC washing machine model NW-891 can't get past the rinse cycle it just keeps on rinsing, emptying and rinsing again and again
Jul 05, 2010 | Washing Machines
No response after starting cycle
could be the door interlocking device
Aug 26, 2009 | Washing Machines
Nec nw-891 washing machine will not complete the programmed cycle
Jun 30, 2009 | Washing Machines
The NW - 891 NEC washing machine does not finish the third cycle or drain?
Aug 06, 2008 | Washing Machines
Washing Machines Logo
69 people viewed this question
Top Washing Machines Experts
