Question about Dishwashers
I have an electrolux dishwasher dx302wj*03 model. The fault code 50 is showing. Does this mean the control panel is faulty or the pump needs replaced? We have been able to fix other problems our selfs from the past and we have avery good store to get all the electrolux parts.
SOURCE: Whirlpool ADP5966 fault code F8
just choose another prog setting and hold the start button in for a few seconds.
Posted on Sep 30, 2007
SOURCE: Diplomat Dishwasher ADP8352 Will not complete wash Cycle
My Diplomat ADP8352 when running a cycle it will run for ages, doesn't seem to get hot. If i switch off the m/c then switch it on again it dumps the water left in the m/c?
any ideas?
Posted on Aug 18, 2009
SOURCE: I have an electrolux edw5505eps dishwasher. The
check out my thread on a similar issue. If your power button doesn't light and delay button does not light? Is the LCD screen display anything? check out my post several really good check lists.
Posted on Nov 26, 2009
  • 4 Answers
SOURCE: F9 problem code Fisher and Paykel Dishwasher - Soft Touch
That's an electronics failure code. Bad news.
http://www.advantagesupplyfl.com/FisherPaykelDishwasherFaultCodes.html
Posted on Jan 21, 2010
SOURCE: Electrolux ewdw6505gs model dishwasher commd panel does not power
Read publication 5995509477 of Electrolux name factory Parts Catalog. You will see the POS NO 12 Part no 7154671401 name Latch Assembly, door w/shield. This relay stay open. a little bit of WD-40 and he working correctly.
Posted on Oct 28, 2010
We are having the error code 0 3 on are Electrolux dishwasher and on this forum I keep seeing check for suds in the tub but nobody ever says what that would mean or what to do about it.
Hey Kelly, I understand that you have received an error code"03" on your Electrolux Dishwasher. Typically "E03" indicates a possible short in the wash pump. This can sometimes be reset by unplugging or turning the household power breaker off to the appliance for five to ten minutes. If the problem is not corrected, consider contacting a professional service provider to assess the dishwasher completely. Hope this helps! -JK
Oct 06, 2015 | Electrolux Dishwashers
Model EIDW6305GSI error code 03 comes on after about an hour after cycle starts could anybody tell me why this happens thanks
Good Morning steven hutchings, thanks for your inquiry!
I understand that your Electrolux dishwasher is displaying an error code 03. Normally, error code 03 means an issue with the wash motor, wash motor hall sensor, or control panel. I would suggest performing a reset on your dishwasher that could help clear any false error codes. You can reset your dishwasher by flipping the household circuit breaker in the off position for ten minutes. If you continue to have an issue with your dishwasher displaying an error code 03, I would recommend having a professional technician come out and properly diagnosis your dishwasher. This will help to avoid any unnecessary part purchases. Hope this is helpful. -Matt
Dec 04, 2014 | Electrolux Dishwashers
How do i replace a wash pump in electrolux dishwasher ewdw6505g80
Hello friend, thanks for your post!
I understand that your want to replace the pump inside of your Electrolux dishwasher. From my understanding an "E3" error code is an issue with your wash motor. It could be a problem with the wash motor, wash motor hall sensor, or control panel. In any case these intricate parts do require precision and patience, therefore when replacing the exchange of electrical components or removing them from your appliance, I always suggest seeking professional assistance. One must be very careful as these replacements can lead to potential harm. -Chris
Sep 21, 2014 | Electrolux 24" Built-In Dishwasher...
What additional parts may fix error code 11 on electrolux EDW7505HPS0A
Good Afternoon Friend, thank you for your post!
If you are receiving an error code E11 on your Electrolux dishwasher (EDW7505HPS0A), it usually means that you are experiencing a problem with the drain valve. If you have already replaced the vale and pump, at this point, I would recommend reaching out to a professional or alternatively, visit the manufacturer website for a comprehensive listing of appliance techs in your area that can ensure the wiring between the main control and the drain valve was correctly installed. Best regards! - Z
May 20, 2014 | Electrolux Frigidaire Professional Series...
My Electrolux DX403SJ stops during cycle and flashes .50 What does this mean?
It is possible that the machine does not start off the cycle because there are errors or feedback from the inputs. For the program to start up the main program controller must initiate the INLET/PUMP MOTOR/DRAIN to work when it is commanded .If this does not happen then the voltage at these points must be checked or the fault relates to no voltage/drive from the controller. This means the controller is a suspect.
Check how to remove the control panel: http://www.espares.co.uk/advice/dishwashers/a/3/1287/how-to-replace-a-hotpoint-dishwasher-fascia-p.html
If the water flows then the flow should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor. The water pressure must be good and the spraying must be seen to be good. If there is low pumping or pressure then the spray arms will not turn around to inject with pressure. If so the pump must be checked for clogging.
To replace check this link:
http://www.espares.co.uk/advice/dishwashers/a/3/1293/how-to-replace-the-spraying-system-on-a-dishw.html
Finally after the wash the drain valve will be activated, the water is allowed to come in to rinse and then finally the drain valve/pump activated so as to drain off all the water.
Make sure that a fault in any of the cycle will relate to the specified action, so check the command from the program module and then the executing device be it the valve or motor or pump.
Please check the link below:
Jan 22, 2013 | Electrolux 24 in. ESI6220X Free-standing...
Control demo
Hello - If the unit was in demo mode it would not produce any water or rinse actions. So if you have water entering the unit, I doubt it is at all in demo mode. Error E01 for Electrolux models means the unit has detected a water leak. This will need to be checked and a repair performed by a technician since they will need to repair the leak and retest unit.
Oct 13, 2012 | Electrolux 24 in. EDW5505EPS Stainless...
Dishwashers Logo
71 people viewed this question
Top Dishwashers Experts
