Kodak ESP Printer error code 203-1021 when trying to install new firmware. Printer display says install new black ink cartridge.
  • 24244 May 23, 2011
    Seems unlikely. Makes this site seem like ripoff central.
RPFinney
  • 385 Answers
SOURCE: Kodak ESP-5 AiO says "0%" ink even after I install new cartridges
Let's clean and align.
Make sure that there are 5 - 10 sheets of plain paper loaded in the paper tray.
2 Press menu to display the main menu.
3 Press down arrow until Maintenance is selected.
4 As needed, press down arrow until the desired option is selected.
5 Press OK.
6 Follow the prompts in the display screen to initiate or cancel the task.
These available maintenance options are shown below:
Check Ink Levels
Nozzle Check
Printhead Alignment
Clean Printhead
Print Demo Sheet
Print Test Page
From windows, : Open the Home Center Help panel by clicking Help on the Home Center window, as needed. Click Maintenance, and then click
Nozzle Check or Printhead Alignment.
Macintosh: Open the Home Center window and click Maintenance, and then click Nozzle Correction or Printhead Alignment.
Should be good now.
Regards
Richard.
Posted on Apr 24, 2009
  • 326 Answers
SOURCE: new ink cartridge but not printing green on esp 5 kodak all inone
you need to use the head cleaning tool in the printer properties, youll need to keep running it untill it runs clear and it uses alot of your ink while it does it.
youll find the cleaning option if you go to your
start/settings/printers and faxes, right click on your printer and go to printer preferences then maintinence
Posted on May 08, 2009
  • 240 Answers
SOURCE: kodak printer esp 3 black ink not printing good
try lexmark printers because it easy to fix it, encase there's a trouble ..
Posted on May 19, 2009
  • 295 Answers
SOURCE: reset chip kodak esp 7 ink cartridge
Kodak printer works with genuine Kodak cartridges and that too brand new not refilled cartridges. The brand new cartridges have a certain code that is recognised by the Printer.Kindly buy genuine cartridges as the printer may be damaged by Non comaptible cartridges.
Posted on Sep 21, 2009
  • 15 Answers
SOURCE: My Kodak ESP 3 all-in-one printer will not print
you may try to clean the printhead and recalibrate the printer. if this will not correct the problem, you need to replace the printhead. I suggest contacting Kodak technical support to have a replacement printhead.
Posted on Apr 17, 2010
Advent resetting ink levels
Hi There
Your all-in-one printer is designed to stop printing before quality is compromised. Make sure you always use KODAK Ink Cartridges. Kodak is not responsible for the compatibility or performance of non-Kodak brand ink cartridges or refilled ink cartridges. To purchase KODAK Ink Cartridges, go to the KODAK Store.
To resolve the error, replace the black ink cartridge with a new cartridge:
  1. Turn on your printer.
  2. Open the access door. For printers with LCDs, follow the instructions on the LCD screen.
    NOTE: For ESP 3250 and ESP 5250 all-in-one printers, if the ink cartridges don't move to the center when you follow the instructions on the LCD screen, see Printhead and ink cartridges do not move to center with access door open.
  3. When the printhead stops moving, pinch the latch on the black ink cartridge and lift it out of the printhead.
  4. Remove the new black ink cartridge from its bag.
  5. Remove the protective cap from the black ink cartridge.
    CAUTION: Insert the ink cartridge immediately to prevent the printhead from drying out.
  6. Insert the black ink cartridge into the printhead.
  7. Press down on the tab until you hear a click.
  8. Close the access door. For printers with LCDs, follow the instructions on the LCD screen.
    NOTE: For more information on installing ink cartridges, see the Extended User Guide for your printer. Review Maintaining Your Printer - Replacing ink cartridges.
If the error continues, upgrade the firmware for your printer:
  1. Press the Cancel button on your printer to clear the error message. (If the error does not clear, contact us.)
  2. Upgrade the firmware for your printer:
    1. Locate and select the firmware download for your printer.
    2. Follow the instructions to install the firmware.
  3. If the error continues, contact us.
Support Link :
Mar 29, 2012 | Office Equipment & Supplies
Error code 3508 after installing a new cartridge
As Kodak suggests in these cases - upgrade the firmware for your printer.
  1. Upgrade the firmware for your printer:
If the error continues, try to contact Kodak
Oct 03, 2011 | Kodak Esp 3250 Allinone Multifunction ( ...
Colour ink cartridge not reconise. replace colour ink cartridge.cod 3603
To resolve the issue:
  1. Make sure you install the correct type of KODAK Ink Cartridge for your printer. Currently we offer two types of ink cartridges (10 Series and 30 Series). Installing the wrong type of ink cartridge may result in this error. You will need to install a new, correct type of KODAK Ink Cartridge.
    NOTE: For more information, see Which ink cartridges to buy for all-in-one printer.
  2. If you are using the correct type of KODAK Ink Cartridge, reinstall the color ink cartridge.
    1. Open the printer access door.
      NOTE: If the ink cartridges don't move to the center, see Printhead and ink cartridges don't move to center with access door open.
    2. Wait until the printhead is idle and silent, then pinch the latch on the color ink cartridge with your thumb and forefinger and lift it out of the printhead.
    3. Install the color ink cartridge back into the printer, making sure to press down on the thumb tab until it clicks into place.
    4. Close the printer access door. For printers with LCDs, follow the instructions on the LCD screen.
  3. If the error continues, restart your printer:
    1. Turn off the printer by pressing the power button.
    2. Wait five seconds.
    3. Turn on the printer.
  4. If the error continues, and you have extra, new KODAK Ink Cartridges on-hand, try to install a new ink cartridge (or a set of new ink cartridges).
  5. If the error continues, contact us.
When the issue is resolved, we highly recommend that you upgrade the firmware for your printer for optimum performance:
  1. Locate and select the firmware for your printer.
Source: http://support.en.kodak.co.uk/app/answers/detail/a_id/39315/selected/true
Jun 07, 2011 | Office Equipment & Supplies
I ran out of black ink and I really needed to print something so I had some ink and refilled the cartridge and it is showing me error code 3507. Do I have to buy a new cartridge even though this one has...
As per KODAK's recommendations,
  1. Press the Cancel button on your printer to clear the error message. (If the error does not clear, contact KODAK.)
  3. If the error continues, contact KODAK.
These steps are part of KODAK's Error: "Black ink cartridge needs replacing" (3507) page.
I hope this works for you. Kindly reply for further assistance. Good Luck!
Thanks for using Fixya!
Mongkey
DELL Tech ID #456563
TIPS: Is your computer slow? This might help
http://www.fixya.com/support/r8158906-diy_manual_pc_tune_up
(for Windows only)
Mar 14, 2011 | Kodak ESP 3 Multifunction Printer/ Copier/...
How to remove the ink cartilidge
How do I install a new printhead in my all-in-one printer? To replace the printhead in your all-in-one printer:
  1. Make sure the printer is on.
  2. Lift the printer access door and wait for the carriage to move to the access position.
    NOTE: For ESP 3250 and ESP 5250 all-in-one printers:
    • On the printer control panel, press Home.
    • Select Maintenance, then press OK.
    • Select Install Ink Cartridges, then press OK.
      If "Install Ink Cartridges" is not an available selection, upgrade the firmware.
  3. Remove any paper that may be loaded in the printer.
  4. Remove the black and color ink cartridges and set them aside.
  5. Remove the existing printhead:
    • For ESP Series Printers, unlatch the printhead by lifting the latch in the center of the carriage.
    • For 5000 Series Printers, unlatch the printhead by pressing the button in the upper-left corner of the carriage.
  6. Lift the printhead out of the carriage.
  7. Remove the new printhead from its bag.
    CAUTION: Do not touch the copper contacts on the printhead, as this may damage it.
  8. Remove the plastic protective shields.
  9. Place the new printhead into the carriage.
  10. Push firmly against the target label of the printhead until you hear a loud snap.
  11. Insert the color ink cartridge into the printhead and press down until you hear it click into place.
  12. Insert the black ink cartridge into the printhead and press down until you hear it click into place.
  13. Close the printer access door.
    The printer detects the new printhead. Follow the instructions on the LCD to calibrate your printer.
    NOTE: ESP 3 all-in-one printers do not require calibration.
IMPORTANT: Be sure to use KODAK Ink Cartridges. Your KODAK All-in-One Printer is designed to work with KODAK Ink Cartridges. Kodak is not responsible for the compatibility or performance of either non-Kodak brand ink cartridges or refilled ink cartridges. You can purchase KODAK Ink Cartridges from the KODAK Store.
Feb 09, 2011 | Kodak ESP5 AllInOne InkJet Printer
Purchased Kodak ESP 3250 yesterday. Not printing photographs.
Yes sounds to me like one of your ink cartridge is empty. Replace and try again.
Jul 26, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
MY KODAK ESP 5 WILL ONLY USE THE COLOR CARTIRDGE
take out both cartridges from ur printer,install them again. ry to print again.kodak printers works on the mechanism that even if ur printing black and white documents, it will take ink out of colour cartridge as well . try to upgrade the firmware of ur printer by going to www.kodak.com/go/downloads and downloading latest firmware from there on ur desktop,connect ur printer to computer and run that file. restart ur printer,ur issue will be resolved.
Aug 22, 2009 | Kodak 5300 All-in-One InkJet Printer
My kodak Esp 5 All in one when scanning or printing displays a horizontal 2 inch black line
go to kodak.com/go/itg and diagnose ur issue. upgrade firmware of the printer and u have to clean printhead after taking out ink cartridges and printhead .issue will be resolved
Jul 24, 2009 | Kodak ESP 5 Printer
76 people viewed this question
jasbo
jasbo
