I am getting a 122-10 service fuser error message on a Lexmark C782 printer. Is there anyway of clearing this, seems to be because I had to remove and replace the fuser cart to move the machine.
  • Office Equip... Master
  • 821 Answers
I presume you have not replaced the fuser due to a fault but merely removed it to make the machine lighter when moving it. Did you turn the machine off when you removed the fuser or was it still on. If it was on then not surprised you have the error. I would remove the fuser again and carefully refit it.Make sure it clicks back into place with no real effort. Turn it on again and see if it clears. You can reset the counter manually although this would not clear an error like this. If still no good then must presume you have damaged the fuser and will have to replace it with a new one.
srri but thats the best i can do for you.
Posted on May 23, 2011
  • boilerbill May 23, 2011
    Thanks for such a quick reply.
    The machine was off and disconnected before moving, the fuser has been refitted several times with no effect
  • Victorman
    Victorman May 23, 2011
    I have had a look in service manual and the error 122-10 indeed refers to the fuser not warming up. I suspect you blew the lamp when you placed the fuser down after removing it. to confirm this you will need a digital volt meter set to resistance and check the continuity of the lamp. Its probably open circuit. You cannot get the lamp only a complete fuser. Srri but it looks like you need a new fuser.
    Its happended to me a few times and its just rotten luck. srri.
149.05 c782 error
Not a very fast job if you end up having to replace the motor itself. But thats the fuser motor PN = 40X1661. You can pull the fuser out look to the right side and see a white gear find. A lot of time that gear or the ones around it are worn out. Every now and then its just the fuser itself has broken gears or something is stuck in the gear.
Jul 15, 2014 | Lexmark C772dn Laser Printer
I have a Lexmark c540n printer that has the fuser error of 122.03 service fuser error how do i clear it on my machine I don't have tick btn any help would be great
you can reseat the fuser, and see if the message goes away. Or you will need to replace the actual fuser assembly. unfortunately you can't just remove/clear the error. see picture attached as this is what the fuser looks like
after you replace it let me know if you still receive the error.
Oct 15, 2010 | Lexmark T632 Laser Printer
I have an x543 Lexmark printer and there is an error message, I have not been able to clear; 122.05 Service - Fuser Error Any help?
i have an x543dn has a fuser error of 122.03 service fuser error, i just reset the factory defaults in the config menu and it cleared that error, to get to the config menu press and hold the tick button and the right arrow next to it then power up the machine and continue holding these until the menu is displayed then scroll through menu until you get to factory defaults select this then select reset base, hope this helps. Kev
Jan 08, 2010 | Lexmark T632 Laser Printer
120.07 Service Fuser Error
Service Fuser Error appears when the fuser does not warm to the required temperature. For this error on this Lexmark model C530dn, the manual states you should power off the printer and power it back on, and if it is not plugged into a wall power point, change it to a power point mounted directly on the wall. Personally, I never got a Lexmark printer to work doing this, but this is in the manual. If this won't help, and the printer is under warranty, you should log it in with the servicing company.
If the printer is out of warranty, your next option is to change the fuser which costs around $350, so I think you would be better off getting a new printer unless you find a second hand one on Ebay.
Jan 04, 2010 | Lexmark C530dn Laser Printer
Printer is hungup on self test
920.08—POST (power on self test) error service check (Sub Code .08 (Exit sensor not connected.))
Check the Exit Sensor for Damage or dust.
Check DC auto-connects on both the fuser and the printer for damage.
If connector is damaged on fuser, replace fuser. If the cable connectors is damaged, replace the JFUSER1 cable.
Check resistance of the fuser, lamp, thermofuse, thermistor
Most Cases you will need to replace the Fuser.
Mar 17, 2009 | Office Equipment & Supplies
Fuser Error
bought a new HP printer!
Nov 04, 2008 | Lexmark T520 Laser Printer
Lexmark E342n Laser Printer Fuser Error
920 Fuser Error
Indicates that the fuser is below temperature when printing
Do a Fuser Service Check
Jun 26, 2008 | Lexmark E342n Laser Printer
202 pam jam
usually it means that a sensor in your fuser is bad. If you have a P.M. Kit replaced the fuser and clean the printer.
but before you do, make sure that you have cleared all jams, including in the fuser.
Its probably time for a Preventive Maintanence
Jun 13, 2008 | Lexmark T630 Laser Printer
406 people viewed this question
jasbo
jasbo
