My panasonic heat pump model cu-e15gkr has a fault of F99, what do i do
I have a panasonic inverter air con. Model CU-E18LKR. it's not cooling properly. Seems to be blowing cold air out on th outside rather than inside.need instructions on troubleshooting
This is a reverse cycle (heating and cooling) model. It sounds like you have it in heating mode. Check the Panasonic website for an owners manual.
Jan 30, 2017 | Panasonic Heating & Cooling
Model CS-E12NKR. What does error code F99 indicate?
Outdoor Direct Current (DC) peak detection
7 times occurrence continuously
Check: • Outdoor PCB
• IPM (Power transistor)
• Compressor
Chances are that the outdoor board has gone. You need a megger to check the compressor first before buying a new board.
Nov 13, 2015 | Panasonic Heating & Cooling
How do I fix error code F99 on a panasonic air conditioner
F99 Fault: Outdoor Direct Current (DC) peak detection
Causes: • Outdoor PCB (replace);
• IPM (Power transistor) (replace - normally part of the controller PCB above);
• Compressor (replace);
Jan 18, 2015 | Panasonic Heating & Cooling
Panasonic fault codes
h14 is indoor intake air temperature sensor
try turning power off for over 1 min, and restarting
Jul 12, 2014 | Panasonic Heating & Cooling
F99 code
your machine is draining too slowly. When it initiates a drain cycle, the water level switch is sensing the water level is still too high after 60 seconds so the computer stops and generates this fault code.
Here are the things to check;
* Check the drain hose and make sure it is not plugged or inked.
* Check Wire Harness connectors to the Drain Pump, Pressure Switch, and Central Control Unit (CCU)
* Check/Clean Drain Pump Filter of foreign objects
* Check for Drain Pump Failure
* Check the Inlet Valve for proper shut off
* Check the Pressure switch for proper operation
Nov 18, 2012 | Whirlpool Duet GHW9150P Front Load Washer
Panasonic heat pump timer light flashes
check if it is poor contact .or current is too small.
wall light
May 20, 2012 | Panasonic CU-E18JKK-1/CS-E18JKKW-1 Wall...
I have a panasonic reverse cycle ducted air conditioner Panasonic model cu 71c 5 2hp. The word "check" is flashing on the display - when I press the check button, error code " F00"...
F00 fault is a short circuit or grounding out in the low voltage (safety) circuitry. Check in your thermostat (Y1). Hope it's helpful?
Jan 05, 2011 | Panasonic Heating & Cooling
Panasonic Inverter CS-E12EKU timer indicator blink. The unit not work at all, I follow the manual instructions using the remote control but the instructions are not clear. Using other similar Panasonic...
Today I install a new unit Panasonic CS-S13KKP also have a same problem timer blink and the outdoor unit wont start. Error code is 11. after checking the problem, can not using a 3 cable cord, solve the problem using 4 Cable cord and its run !
Victor
Aug 21, 2009 | Panasonic Heating & Cooling
New airconditioner (installed 5 days ago) not working. Turned it on for first time (after installers's demo)yesterday, left the room after it had been running about 30 min. Returned within 10 min to find...
do nothing on a brand new unit but let the installer or service tech fix it for free, if you go messing with it you may camoflouge the real problem and when the repair tech arrives he wont be able to observe the actual cause or fault and it will do it again after hes gone and you'll be back to square one. please don't touch a thing till the tech arrives and gets the chance to see it broken and use his tools to determine the problem. good luck.
Dec 05, 2008 | Panasonic Heating & Cooling
Heating & Cooling Logo
112 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
