I dont understand how to remove items from player ie tunes or recordings etc
  • 32,281 Answers
Connect the supplied USB cable to your MP3 player and then plug the other end of the USB cable into the USP port of a working computer.
This computer will detect the MP3 player as an external storage device.
From My Computer, double click on the MP3 device and you will see the various folders, music, photos etc. Click on these folders to open the folder and then click to highlight the item you want to delete and then press the Delete key.
Just treat this device as you would with your hard disk to delete or copy files to the MP3 player.
Posted on May 23, 2011
Dvd recordings from tv
You need to connect your incoming signal to the DVD recorder first. So either put your aerial lead (or cable as the case may be), into the aerial input socket at the rear of the DVD. Then you will need to go into the tuning mode on the DVD & tune in your stations. If you are on cable with a scart, then just connect the scart from the cable box to the DVD & select the input source (ie AV1), this will allow you to record
Jan 04, 2010 | GoVideo DV1130 DVD Player/VCR
I have just bought a digital tv and can't tune the video in
If you are talking about an older VHS or Beta recorder, the tuning for recording is done by the player itself. If you are using an outdoor antenna to recieve your local stations to record, most likely you will need a digital TV adaptor to convert the over the air digital signals to an analog signal the tape player can understand.
Nov 03, 2009 | Televison & Video
The mic won't record because it says there is an insuffic memory space
Use the easyRip Player Library module to see what media you have on your device and remove items until you have enough free space to record.
Use Windows Explorer to manually navigate to the files and remove items until you have enough free space to record.
Oct 06, 2009 | RCA TH1611 MP3 Player
Samsung DVD HR735 doesn't recognise DVDs
It sounds like the laser in the DVD player is getting weak or has alignment problems. If the DVD that did not play in the samsung but played in others. I would tend to think its not alignment since you mentioned that it's been repaired before. Chances are the laser is weak but still within spec in order to prevent replacement. When My dvd players start to go they will generally stop recognizing burned media and thats your clue to replace it. They are very inexpensive to replace nowadays and have almost become disposable items. Probably not what you wanted to hear but it sounds like's like this player wasnt made very well.
Jul 13, 2009 | Samsung DVD-HR735 DVD Recorder/HDD...
Can the Magnavox Dvd player/VCP DV200MW8 record shows onto VHS's
unfortunately the machine is not a recording machine IE: it is a player only. However in todays day and age you can pick up a good used one at the goodwill for around 10-20 bucks that can record. hook up is easy, one cable in one out and presto you can record on a blank tape. just remember the begining of a blank tape always has a few seconds of nothing on it so dont hit rec just as you are watching it start the machine about ten seconds early.
hope this was helpfull.
Dec 27, 2008 | Philips Magnavox DVD/VCR Dual Player
Problems tuning TV and SLV-900
the video recorder has it's own tuner you do not actually record from the tv... think of the vcr as like a tv but without a screen... connect to your tv via a scart lead and while you are on the vcr's 'channel' (so you could see a tape playing on your tv) and access the menu on you vcr (not the tv's menu) choos auto tune if the vcr supports it or manual tune if it has no auto tune and tune in the required channels on your vcr... it is simply then a matter of selecting on your vcr which channel you wish to record
Oct 13, 2008 | Sony SLV-D900 DVD Player / VCR Combo
Ihave a hdr1600t i want some help to record one chanel and at the same time how to record the 2nd chanel. please send us easy to understand information thank you
1. Just tune to the 2nd channel you like and press red (record) button. You'll see rec sign on top left.
Do not move to other channel.
2. Press List and scroll up and down to select the record in the list and press OK.
Aug 01, 2008 | Televison & Video
Grundig TV - Tuning DVD & VCR
Hi there!
If the DVD recorder has an RF out then you should be able to tune it on UHF bandwidth. The cable should run from the RF Out on the recorder to RF on the TV. Switch the recorder on, put in a DVD and press play before tuning. Some DVD's require a disc before a Menu appears. Good Luck, Regards, JUS004
Mar 23, 2008 | Grundig GF70-600 TV
Record
sorry I dont understand what your asking please refrase.
Dec 26, 2005 | BenQ Joybee 130 MP3 Player
32 people viewed this question
 Grubhead
Grubhead
