Question about Kenmore 19233 Computerized Sewing Machine
Thread is getting stuck
Kenmore model number 19233. The thread is getting stuck between the stopper and the knob as soon as I start sewing. I have cleaned the hook race and feed dog but nothing is helping. Can you?
    New Friend:
  • 46 Answers
Be sure you have the top threaded correctly, from the first thread guide down to two, up to three (silver hook at three) then straight down tot he left of the needle. Through the needle form front to back.
Try to always remember to thread the machine with the presser foot up, this way the thread will surley pass through the tension disks.
I hope I understand this right... what stopper and what knob in case I got it wrong.
Bonnie
Posted on Sep 29, 2008
When I start sewing the back of thread is all overlap and tangled what can I do?
A more detailed description would be helpful, but my guess is that you have lost all of your upper tension.
Unthread the machine. Raise the presser foot. Turn the handwheel until the take-up lever is at it's highest position. Set the upper tension dial/knob to 5. Thread the machine.
With the presser foot up, the upper thread should pull through easily and then grab when the presser foot is lowered.
Test sew.
The upper tension pulls the stitches up and the lower tension pulls the stitches down. When they pull properly, the stitch is even.
Oct 29, 2010 | Kenmore 19233 Computerized Sewing Machine
Will not hook the thread in bobbin area
Go back and re-thread the whold machine making sure you have properly threaded machine
Aug 10, 2010 | Kenmore 19233 Computerized Sewing Machine
What steps do I need to take to do free motion stitching on my Kenmore 19233
Hi. You'll need to lower the feed dogs and use a darning foot. Use a straight stitch and set the stitch length to 0. Depending on what thread you use, you may need to adjust the tension. Keep the fabric taut (or use a hoop) and experiment on scraps to get the results you want.
Jul 19, 2010 | Kenmore 19233 Computerized Sewing Machine
Our kenmore model 385.18221 machine just sews for a couple of stitches and then just balls up the thread on the bottom of the material. If you run it through manually the thread appears to be hanging up on...
I've had similar problems with my Kenmore 385 and have found that a really, really good cleaning and oiling solves them. That's what I'd recommend you do first. If that doesn't solve the problem, take out the bobbin assembly and look for any nicks or scratches where the thread could be getting caught. (I'm not sure what you mean by 'stopper'--but check it for spurs, nicks, etc, that could be hanging the thread up.)
Nearly all sewing machine problems (including this one) can be solved by:
1. a really good cleaning
2. a new needle
3. rethreading
Hope this helps!
Robbie
Jan 26, 2010 | Kenmore Drop-In Bobbin 505S-21BH...
Kenmore 19233 computerized sewing machine
On my machine I find that my bottom and top free motion stitches are more uniform when I set my needle thread tension at 8 or 9. Also, you might want to use a top stitch needle.
Good luck,
SewReady
Nov 07, 2008 | Kenmore 19233 Computerized Sewing Machine
Setting stitches on my 19233 Kenmore
Just as soon as you can. Electronics have a shorter warranty period than mechanical problems.
sewman7
Mar 31, 2008 | Kenmore 19233 Computerized Sewing Machine
How do I thread it
Follow the thread from the spool through the first thread guide at #1 straight down to #2 and up to #3 (make sure that the thread is through the take-up lever (silver hook) at #3 from three you will bring the thread straight down to the thread guide that is to the left of the needle. Thread the needle from front to back.
Mar 11, 2008 | Kenmore 19233 Computerized Sewing Machine
Beep sound on Kenmore 19233 sewing machine
I had the same problem. Through trial and error, I found the problem was with the thread tension. Usually the thread became wrapped around the spool holder as it was coming off the spool. As you continue to press the pedal, tension is created. When you release the pedal, some slack develop in the threading process and you are able to sew a few more stitches before the beeping starts again.If the thread is caught on the spool holder, simple re-thread the machine.That generally works for me. If it continues to happen, place you thread in a cup behind the machine and thread as usual. You can also purchase an inexpensive thread holder. I made one out of a wood block and other odds and ends found around the house.
Nov 05, 2007 | Kenmore 19233 Computerized Sewing Machine
Bobbin
It doesn't turn. Make sure you threaded the bobbin correctly (see manual)and try using the needle up-down button
Jun 08, 2007 | Kenmore 19233 Computerized Sewing Machine
Kenmore 19233 Computerized Sewing Machine Logo
88 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
