Question about Canon PIXMA MX350 Wireless All-in-One Inkjet Printer
How do I disconnect the counter for MX 350 printer? I tried the procedure of turning it on while holding the ON button and then pressing STOP twice and releasing the ON button. No display and only the copy light was on.
  • Canon Master
  • 825 Answers
I dont understand your reference to counter? if you are referring to the machines internal page counter which records the number of pages it has printed from day 1 then the simple answer is YOU CANT. This can only be done by changing the SCNT board (main board that is) for it is stored in the eeprom and this cannot be fully erazed. You cant even do an eeprom reset or update to reset the counter as this is not touched during the update/initialization proceedure. Anyway you cannot access the eeprom as only Canon engineers have the software to do this. You have to be a trained and registered engineer with canon before you can get the software to do it.It is uniquely customised to the engineer. Srri but give up on this one mate.
Posted on May 23, 2011
How do I fix error code 5b02 in Canon mx397?
When you clean the print heads, the ink has to go somewhere. This error code is, "waste pads are full". This is typically something that you take your printer to a service center for.
I did find some instructions for you, though:
How to Replace the Ink Absorber on Canon Printer eHow
Apr 03, 2015 | Canon Office Equipment & Supplies
How to set ink level on canon mx-320 after refill?
Apparently the problem is that you are choosing to install (according to Canon), cheap, aftermarket ink cartridges rather than Canon ones. Therefore the machine is not recognizing them. Try this procedure, found on another forum, that was supplied by one of the cheapo ink companies. Who better to know how to fool the machines than them. If they want to sell these ink carts, they better know who to make them work!
U051 Error Correction procedure.
1- Switch off the Canon MX300 and disconnect the power cable.
2- While press and hold the power button, Connect the power cable to electric socket.
3- While pressing the power button, press the "Cancel/Stop" button (red button). (press TWICE che "stop\cancel" button)
4- Now release the power button and the printer turns into a kind of factory mode. Wait for 10 seconds until it says "idle".
5- Press ">" (next button) once "Shipping Mode 3? then Press the "OK" button. Press "OK" again for "without cleaning". A test page will print.
6- Open the cover, like you are about to change the cartridges.
7- Disconnect the power cable again without switch off the printer.
8- Take out the both cartridges.
9- Close the cover.
10- Connect the power cable and turn on the printer.
11- Now just put the cartridges back and the ink level in the canon Pixma MX300 have full again.
Jan 14, 2015 | Canon Black Pixma Mx 320 High Quality...
Both of my ink cartridges went out at the same time and i only replaced the black. now it has an error saying it will not print because i need to replace the color ink cartridge. but i'm trying to...
It depends on the model that you have. You can try one of the following to reset the ink counter and the printer will show a full color cartridge.
This is the procedure I used for an MP470. It is basically a modified version of that previously posted for the MP460.
1. Disconnect the power cable.
2. Hold down "On/Off" button.
3. Reconnect the power cable.
4. With the power button still down, press the "Stop/Reset" button twice.
5. Release the "On/Off" button.
6. The printer is now in "factory mode".
- wait until "idle" is displayed.
7. Press the right arrow button (next to the "OK" button) repeatedly until "Shipping Mode 3" is displayed.
8. Press the "OK" Button
9. Wait until "Without Cleaning" is displayed and then presss the "Stop/Reset" button once. (I pressed the ok button after Stop/Reset button on my MP470).
10. A test page should print.
11. Open the cover.
- the cartridges should position themselves at the far left - the cartridge removal location.
12. Disconnect the power cable.
13. Remove both cartridges.
14. Close the cover.
15. Reconnect the power cable.
16. Press the "On/Off" button once.
17. Wait until a "Replace Cartridges" message is displayed.
- insert cartridges.
18. Wait until the printer is operating in its normal mode. The display shows the normal start menu (ie: Copy).
The ink levels have been reset.
- check by going to printer>properties>maintenance>view printer status
this is what i had to do to get it to work with canon mp460
2. Hold down power button
4. With the power button still down, press twice the "Cancel/Stop" red button
5. Release the power button
6. The printer is now in factory mode...(wait about 30 seconds until it says "idle")
7. Press the down arrow (next to the "OK" button) until it says "Shipping Mode 1"
9. Now with it displaying "Without Cleaning" press the power button
11. Now open cover
12. Disconnect the power again
13. Take both cartridges out like normal
14. Close cover
15. Reconnect power cable
16. Press power button
17. Replace cartridges
MP-160 is different from MX300 so I tried my best with it...
The main solution is to reset the entire printer:
2. Connect it while holding down the power button
3. With the power button still down, press twice the "Cancel/Stop" red button
4. Release the power button
5. The printes turns into a kind of factory mode...(wait for about 10 seconds, utils it says "Idle")
6. Press the ">" (next to the "OK" button) once."Shipping Mode 3"
7. Press the "OK" button.
8. Press "OK" again for "Without cleaning"
9. A test page will print..
10. Open the cover, like you are about to change the cartridges.
11. Disconnect the power cable again.
12. Take out both cartridges.
13. Close the cover.
14. Connect the power cable once again.
15. Turn the printer on.
16. Now just put the cartridges back...
1. Press & hold stop/reset button, and then press & hold [ON/OFF] button.
2. When Green power lit, leave stop/reset button & press twice stop/reset (see orange indicator).
3. Leave On/Off button. Printer in actually service mode.
4. Press stop/reset 4 times (see orange indicator) if not blink restart above process from top.
5. After press stop/reset 4 times successful press On/Off button 3 times. printer will off.
6. Press On/Off button
Aug 30, 2011 | Office Equipment & Supplies
Waste ink absorber full
Hi
Do you need to reset the counter in MP150?
Anyways remember that you need to repalce the absorbers also later. Follow the below procedure and you can start using the printer again.
PROCEDURE I. Enter Service Mode:
  • Plug in power cable
  • Hold down STOP/RESET button
  • Hold down POWER button
  • Release STOP/RESET
  • Press STOP/RESET twice in a row
II.Execute Waste Ink Counter Reset Operation:
  • Press STOP/RESET button 4 times (Indicator lamp will blink alternately Orange/Green each time the button is pressed)
  • Turn off the printer by pressing POWER button (wait until the printer is completely OFF)
When you turn on the printer,waste ink absorber full error is cleared and the printer work normally.
Original source: http://www.printerclinic.com/reset-waste-ink-counter-canon-pixma-mp150/#ixzz1SaAjTfWu
Jul 19, 2011 | Canon PIXMA MP150 All-In-One InkJet...
How to solve E-2-7 on a canon pixma mp150 all-in-one printer?
Try this ~
1. Start with printer OFF
2. Hold down RESUME and then hold down POWER
3. Release RESUME
4. press RESUME twice, then release POWER
5. let green light blink until printhead has finished moving.
6. Press resume
If still cannot, try this ~
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding
the Stop/ Reset button.
2) When the Power LED is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a
service mode. (Waiting formenu selection)
4) When the LED lights in green, press the Stop/Reset button the specified number of time(s) according to the
function listed in the table below.(Each time the Stop/Reset button is pressed, the LED
lights alternately in
orange and green, starting with orange.)
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset See waste ink counter reset
procedures below.
5 times Orange Destination setting See Destination setting
procedures below.
6 times Green Print head deep cleaning
11 times Orange Button / LCD checking
12 or more times Returns to a menu selection
Hope it helps. Good luck =)
May 02, 2011 | Canon PIXMA MP150 All-In-One InkJet...
Why my printers show alarm U051
Hi, khaircarrier
That error has something to do with the page counter and the ink system. You'll need to reset your printer to clear the ink counters, after resetting it'll not display the error code again. Follow this procedure to reset the printer:
  1. Power off the printer.
  2. Holding the stop/reset button, press and hold power button also. Hold both buttons together for 5 secs.
  3. Still holding the power button, release the stop/reset buton, then press the stop/reset button twice.
  4. Release power button (the screen should now say 'Service Mode').
  5. Wait until the power button lights steady green, then press the stop/reset button three times with a 3 sec space between each press. On the 3rd press the indicator should turn steady orange.
  6. Press the power button once, (the orange light should go off).
  7. Open the printer and remove both cartridges. Wait for 10 seconds. Replace the cartridges and close printer. Wait for 30 seconds.
  8. Press the power button, and wait until printer has shut down.
  9. Press power button to power up. The printer will feed one piece of paper, then ask you to set the language.
The page counter should now be reset. That should solve your issue.
Mar 07, 2011 | Canon Office Equipment & Supplies
IS IT TRUE THAT THE CANON MX 320 IS THE WORST PRINTER IN THE MARKET? BECAUSES THE 5200 ERROR?
Not really!!
You can try two different procedures to clear the error.
1. Turn off your printer
2. Press and hold the STOP/RESET button
3. Press and hold Power ON button
4. While holding the Power ON button, release the STOP/RESET button
5. While holding still the Power ON button, press twice the STOP/RESET button
6. Release the Power ON button
7. Wait until it display an "idle" message. It will take about a minute.
8. When "idle" appear, open the top cover to expose the cartridges.
9. Lift up the cover for cartridge holder and take out both the black and color cartridges
10. Return the cover of cartridge holder and turn off the printer
11. Return the top cover and turn on the printer again
12. After the printer initialize, return the cartridges.
The next procedure is also the key for making the old cartridge reusable after getting reffiled
1. Press and Hold the STOP/RESET button and wait until it self restart.
2. Release the STOP/RESET button the the printer is restarting.
3. Wait for a few seconds
If you bumped in to a different error codes See My
Helpful Tips for this Printer Pixma MX320 and MX328.
If this solve your problem please give some good ratings too as this will help me too. Thanks.
Aug 14, 2010 | Canon PIXMA MX320 Color USB InkJet Printer
I have conon mx 868 but i have got error message 6502 and 150 how can i solve the problem?
Here are instructions:
The MPTool is designed for service works with the printer Canon MP-Series
when in Low-Level mode. This is NOT the same as "service mode"
Currently supported for
MP150, MP160, MP170, MP180, MP450, MP460. MP150, MP160, MP170, MP180, MP450, MP460.
BEFORE activating MPTool...you need to
To activate LOW LEVEL mode:
1. Unplug the power cord to the printer for a moment.
2. Then, hold down the on/off button while plugging in the power cord. Keep holding the on/off button down.
3. Right away the green power light (in the button) will turn on solid. Keep holding the on/off button down.
4. Press and release the Stop/Reset button.
(the button w a red triangle in a red circle)
5. Now you can release the on/off putton.
The green power light will go off and the yellow Alarm light will stay on.
Now you can run MPTOOL and resetting the ink counters will work.
Your printer will show up as "another" Cannon printer.
When you finish you must again unplug the power cord for a moment and then just plug it back in. After you do this, you'll see both printers listed in Printers (controll panel) and one will show as offline. You can then rename this offline printer as "Low Mode Canon"
or whatever works for you so you don't mix it up with other functions.
2) When the Power is lit, press the Stop/Reset button two times while pressing and holding the Power button.
service mode. (Waiting for menu selection)
4) When the on/off lights in green, press the Stop/Reset button the specified number of time(s) according to the
function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in
orange and green, starting with orange.)note: press 4 times for waste ink counter reset.
button pressing
5) Turn off the printer.( it must be turn off)
then turn it on again. this works. thanks.
For
1, With the printer unplug, remove the ink cart to the right ,
2,Plug in the printer ,Press the POWER button, Do not release the POWER button ,and then press the RESUME button twice in succession .Now release the POWER button ,press the RESUME button 4 times .
3,The beeper may sound once ,Then With the printer unplug ,after that reset the printer electronics ,open the printer and this process is finished.
Reset manual "Ink Absorber Full"
Steps by steps how to reset :
1. Turn off the printer but still connected to a power source
2. Press stop/reset button, and then press power button to restart
3. Press power again and then press twice the stop/reset button.
4. Press power & Stop/reset button together, to enter
the repair status and power lights will be green,
5. Press stop/reset button
6. Turn off the printer
7. Unplug the power cable.
8. Plug the power cable and then turn it on again
Canon MPC INKTank FULL
button pressing
Sometimes the Canon printers which use PG-5BK/CL-8 colour cartridges with chips will give error mesaages like 6502 or other types of error meaasge to do with the cartridges, which has the orange light flashing and the printer will not work. Follow this procedure which quite often resets the printer and allows it to resume printing.
When error is indicated, turn power switch off so green light is extinguished.
First hold down resume button and then hold down power button so both are held down at same time
When green light comes on, continue holding down power button and let resume button go, then press resume button twice. Then let power button go.
Then press resume button four times, power button should be releasedbefore doing this.
Wait until printer settles down, if power is off, turn on. If power will not come on, remove power cord from back of printer, then wait 15 seconds before plugging back in again and turn power on. This normally solves the error problem - if not go through same procedure again.
Incidentally, you may find that if the chips had previously been disabled,the low ink warnings are showing againand they will have to be disabled once more. This would indicate that the above procedure clears the firmware memory of the disabling of the chips, this may be usefull if you need some warranty work done on you printer after the chips had been disabled. Canon does warn that disabling the chips may result in the printer's warranty being voided
Apr 08, 2010 | Canon PIXMA MX860 OFFICE AIO-2.5IN LCD...
How to reset low ink warning in mp145
Following is the procedure to reset waste ink counter Canon Pixma MP145 :
  • Connected Printer to a Power source, Turn off the printer if printer on
  • With the Printer power off, press the Power button while press and hold Stop/Reset button.
  • When the Power led is light, press Stop/Reset button two times while pressing and holding the Power button.
  • When releasing the Power button and the Stop/Reset button (regardless of order), the printer will move into a service mode. (Waiting for menu selection)
  • When the on/off lights in green, press the Stop/Reset button four times to reset wase ink counter. For other specified number pressed function listed in the table below. (Each time the Stop/Reset button is pressed, the LED lights alternately in orange and green, starting with orange).
  • Unplug cable power from a power source.
The number of the Reset button pressing LED Function Remarks 0 time Green Power off 1 time Orange Service pattern print 2 times Green EEPROM print 3 times Orange EEPROM reset 4 times Green Waste ink counter reset
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Dec 20, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Canon pixma mp145
mas saya mau download canon pixma mp145 ko susah banget ci please saya lagi butuh banget..!
Oct 31, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Canon PIXMA MX350 Wireless All-in-One Inkjet Printer Logo
139 people viewed this question
old marine
old marine
