Question about Dayton (1UM44) Fan
I have a Dayton Model 1UM40 and I am unsure how to turn it on. I know it sounds funny but I have plugged it in and can not find an on or off switch. Please help me.
Need fan motor for model 2E440
Try Grainger
dayton 2e440 heater Questions & Answers - Fixya
www.fixya.com > Forum > Tags
... a Dayton Model 2YU40 electric heater Need manual for Dayton. ... looking for a replacement fan and fan motor for a Dayton model 2E454B electric wall heater.
Dayton rheostat fan motor Heaters Questions & Answers ...
www.fixya.com > Forum > Tags > rheostat fan motor > Heaters
Dayton heaters rheostat fan motor related questions and answers. ... UP BUT FAN WONT KICK ON Could be one of several problems dependant on the model you have.... The motors are noisy in 2 Dayton 2e440 heaters. I ... I'm looking for a replacement fan and fan motor for a Dayton model 2E454B electric wall heater.
DAYTON Electric Wall Heater, Recessed or Surface ...
www.grainger.com/.../DAYTON-Electric-Wall-Heater-3...
W. W. GraingerShop DAYTON Electric Wall Heater, Recessed or Surface, Voltage 208/240, Watts ...Item # 3UG56; Mfr. Model # 3UG56; UNSPSC # 40101814; Catalog Page # 4277; Shipping Weight 20.65 lbs. ... Additional features include a built-in thermal cutout andfan delay switch for added safety ... Need Help Finding Repair Parts?
Jan 09, 2016 | Dayton Electric Heater
Is the button NC or NO? I have it currently wired this way but still it does not work and I'm using a switch not a button. Any suggestion?
The switch is OFF or NO normally open
See wiring diagram at following link
http://waterheatertimer.org/How-to-wire-Dayton-Off-Delay-Timer.html
The way the timer works is this::
You click switch ON
When you turn switch OFF, the Dayton begins the timing sequence
The Dayton turns on the circuit going to load for 1/2 second => 5 minutes depending on model of Dayton timer
Grainger sells 120V push buttons if you don't want to turn the switch on-and-off each time
http://www.grainger.com/Grainger/wwg/search.shtml?searchQuery=push+button+switch&op=search&Ntt=push+button+switch&N=0&sst=subset
http://www.grainger.com/Grainger/IDEAL-Push-Button-1XWT9?Pid=search
Oct 12, 2010 | Amperite Dayton Solid State Timer On Delay...
Have 30,000 btu Dayton heater m#3e3665 when reaches temp. fan
Hi blow heater out with air line flame sensor could be dirty check out pressure switch jump this out see if it lights
Feb 09, 2010 | Dayton (3E379) Heater
My dayton NG heater fan will not shut off properly
Sounds like a bad fan switch. The switch is located on the heat exchanger and is 110 volt bi-metal switch. Follow the wires from the blower going back to the heatexchanger. Graingers can get you a new switch if you give them your model number. www.grainger.com.
Dec 12, 2009 | Dayton Heating & Cooling
Constant clogging of nozzles, live in arizona, paint is drying and clogging up nozzles air and paint rapidly
Clean the Nozzle.
If Doesn't work, see below.
For any kind of nozzle related problem, you first must go through the steps below:
1. Completely Turn Off your printer & the switch to which power plug is plugged.
2. Press the Power button on the printer & keep it pressed. While pressed, turn on the switch for the power plug. Now release the power button on the printer.
3. Turn off the power button on the printer & then turn on.
4. Clean the nozzle & try printing.
Hope it solves the problem as it did in my case.
Jun 29, 2009 | Dayton Audio Dayton 3XY38 Nozzle, Turbo,...
Heater wont work
Dayton heaters. com?
14 years old? dayton still exist?
Stop trying to blow self up--go buy new one
Jan 21, 2008 | Dayton (3E379) Heater
Dayton (1UM44) Fan Logo
110 people viewed this question
Top Dayton Dryers Experts
Jay Finke
Jay Finke
AZBen
AZBen
Are you a Dayton Dryer Expert? Answer questions, earn points and help others
