Question about Panasonic KX-T7630 Corded Phone
Hi what are the Pin connections for the 7630 Panasonic handset back to the PBX please
  • Panasonic Master
  • 2,460 Answers
The handset plugs into the handset jack on the underside of the phone base. Now, if you're asking how the phone connects to the system, there's another jack that says to system or something similar. It uses the outer pair of a 4 conductor cable (black and yellow by color) and connects to the modular jack on the system cabinet or the paired connection on an 8 or 16 port digital card.
You can also plug a phone into the DXDP port of another phone to have 2 digital phones on the same line.
Carl
Posted on May 23, 2011
How do I change the time on my KX-T7630. thanks
You need to set the time on the PBX the phone is connected to. Please refer to the documentation for the PBX.
If you require further assistance then please add a comment to this question and specify the PBX.
Oct 07, 2014 | Panasonic Lands Phones
How to block outgoing call via PBX panasonic KX-TD1232 DBX
You have this posted in the wrong product category. Please select another category appropriate to the problem.
Aug 29, 2012 | Cars & Trucks
I have a Plantronic headset. I have moved to another location (and phone jack) in my office. The Plantronic headset plugged into the Panasonic KX-T7633 does not get a dial tone. When I go back to my...
If you are using this phone on a Panasonic KX-TDA 30/100/200/600 system. With the handset on the cradle/hook press Program 61 and ENTER. Press SEL or AUTO ANS / MUTE to change the setting to On. Press AUTO DIAL / STORE to save your changes. Lift the handset and put it down to exit program mode.
PLEASE rate/vote this answer if it was helpfull.
THANK YOU
Oct 29, 2009 | Panasonic KX-T7633 Corded Phone
We want to transfer a call to a phone number (external party). System programming is required. Can you help me? Thanks, Gina
Panasonic KX t7730 call forwarding function to external party:
If you are using the Kx-TA624 pbx (TES 824 models) system, program your phone unit (t7730) as follows: lifet handset, press FWD/DND button, press 3, then the outside line access code, then phone number, then #, then return handset.
If you are using the kx-ta1232 (higher models) of pbx system (usually with 9 or more CO lines cabable, use the following command:
lift handset, press FWD/DND button, press 6, then the outside line access code, then telehone number, then # then return handset to cradle.
Jun 11, 2009 | Panasonic KX-T7730 Corded Phone
How to change a name on kx-7630
Without picking up the handset, press program *# 1234. 004 + enter. Then enter the extension no. whose name has to be changed. then change the name. After you finish entering the name press autodial.
Apr 17, 2009 | Panasonic KX-T7630 Corded Phone
Pick up receiver and get a dial tone for outgoing w/o pressing 9
I beleive you are referring to a phone which is part of a PBX system or Key-system (sounds more like a Panasonic PBX system). If so, this is a system program that has gone "bonkers". You may need to re-program the automatic outside line dial tone on the system for the specific phone you are referring to.
Jan 28, 2009 | Panasonic KX-T7030 Corded Phone
Connect kx7630 to dhlc8
A DHLC card is pinned the same as a Panasonic 123211 and TD-1232 system for compatibility. That means that there are 3 pairs for every extension and 3X8=24. In your triple set, the first pair is T&R, which is the ANALOG voice pair. It's used as 1/2 the connection for an Analong Panasonic phone (APITS) or a single line set. The second pair is D1&D2, used for a DIGITAL phone. In theory, if you're only setting a 76xx phone, a single pair from this pair to the second pair of the RJ-11 jack (orange pair of the cable or black/yellow wires) would make the digital phone work. We use 2-pair jumper just as a marker to know it's a DHLC block. The 3rd pair is used for OHVA on a 7130(!) and any other analog phone that had that feature. Which means, it's obsolete today, but you could take that TD-1232 system cable, plug it inot a TDA/TDE DHLC-8 card and move on to the next job.
On the back of the 7630 phone there's another jack marked TO TEL. Just for fun, plug your 7630 into another 7630. HAH! That's what a DXDP port does.
Carl
Oct 07, 2008 | Panasonic KX-T7630 Corded Phone
Registration of ps in pbx
i have a problem in panasonic pbx TDA 620 which tells all extensions are buzy when hhave been called and the stat of the card nothing neither red nor green solve this problem for me please thanks as always for your help
Sep 16, 2008 | Panasonic (KX-TDA200)
Panasonic KX-T7630 Corded Phone Logo
Top Panasonic Lands Phones Experts
guyvstewart
george  peters
george peters
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
