Computers & Internet Logo
Posted on May 23, 2011
I do not know where the wirless switch is on my laptop Elitbook 2530p ???
Anonymous
Level 1:
New Friend:
  • Contributor 30 Answers
  • Posted on May 23, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
30
Questions
Helped
7925
Points
81
You can find it just below your computer screen. Right side of the Power Button and above the F5 key.
HP EliteBook 2530p Notebook keyboard not working
Not working...means zero in troubleshooting. What keyboard, obviously what os-> that's where your problem is. NOT the keyboard. NOT the laptop.
1helpful
To reset the compaq 2530p bios password
I'm not 100% sure this will work but you might have to take apart the laptop to reSEAT the bios battery. Unplug it from the motherboard then plug it back in. Usually once those pre-windows passwords are locked in they're locked in for good.
1helpful
Hp elitebook 2530p keyboard does not work
What version of Windows are you using? You can open an on-screen keyboard and use the mouse to type in the password.
HP Elitebook 2530p switches on but no display
Hello!
Just a quick one or two at the moment. Have to locate the problem then figure the fix sooooo..
1. Please refer to the photo: Note the 'hands', one at the top right and the other at the bottom right of the screen. With the power on and the computer in the normal ready to use mode....
What I suggest you do is hold the bottom right corner firmly, keeping it relatively immovable while, at the same time, GENTLY, and NOT completely, SLOWLY start bringing the top left corner down toward the bottom right corner, actually moving the top barely an eighth of an inch, flexing just a tiny bit...
If the display flickers then, hopefully, it is a loose display cable, usually a flat one that lies under the keyboard and need only be adjusted. a tedious but very inexpensive solution.
Another quick, albeit unlikely fault to check is your battery. I know, I know, it's so obvious but I have to ask: Have you tried using the computer from a DIFFERENT wall outlet, better still, at a buds house?
Let's get these two out of the way before moving on? Let me know! I'll look into recalls, frequent problems, etc....
Jimm
How to turn on wireless radio for hp 2530
There is wifi switch on laptop first turned it on. Make sure wireless network adapter driver installed and enable you can check it in device manager. Press Fn+ F5 key turn the wifi on. Then you can view available wifi networks. Let me know if you need further assistance. Thanks for using FixYa.
7helpful
There is no physical switch on the Elitebook 2530p, and I can't figure out how to turn the wireless back on...
The HP2530p buttons are "touch sensitive" and are located at the along the strip that the power switch is, touch the orange light and it will change to blue (on) this is the same for the volume screen etc, blue is on, orange is off, Just touch and play
Tpot
The touch-sensitive volume control on my EliteBook 2530p is impossible to control. There is a major delay between when you move your finger and when the volume changes, and volume jumps from minimum to...
Hello there!
I dont think it should be working like that, although you could read some forums about that type of laptop and see other people experiences. Try to clear sensors from dust just a bit, to fast a motion. Also do you use any drivers for that software under xp? there should be drivers for that hardware.
Sincerely
Aleksandar Adzic
1helpful
HP Elitebook 2530p power lights stays on after
are you switching off, or just closing the lid? On most laptops, closing the lid just hibernates and constantly uses power, it can be changed in the control panel power options.
Hello. I am trying to project a powerpoint talk
Usually one of the key (like F4) will say LCD or CRT under the F8. It will be in a different color. The FN key (or some other key) will also be this color.
Hold the Function key and then press F4 to toggle through the different display combinations.
Grand Canyon Tech
Grand Canyon Tech
