Question about Hoover Fusion Plus Cyclonic Upright Vacuum Vacuum
I have one of these types how do you put the handle down
At the base of the handle there is a button push it and the handle at the same time
Posted on Nov 29, 2011
My dyson hose sucks good but, when i put handle down, it won't **** but brush does turn
I just had the same problem....suction from wand, but no suction from soleplate, the brush bar spins. Did all the troubleshooting steps on dyson.com but they didn't work...dyson.com says need to take to repairman, being a diyer I went to search engine. I didn't find a fix, however I found one myself....it appears the vac can get stuck in floor mode or in between modes....the dial on top on dc07 ....selector of floor or carpet..try pushing it back and forth to see if that puts it in carpet mode...check for suction or try vacuuming...if that doesn't work, looking at vac from behind vac on the right hand side is the selector dial..on top of bottom portion of vac.....with vac in upright position, recline it as if about to vacuumn floor...look down at selector area ...you should be able to see a rectangular type button exposed ..push this to reset position...you may have to push it a few times...then try vacuumniing.....I finally had suction from soleplate!! Another tipoff to this problem is my selector dial would not stay in place would pop I to carpet by itself, but only halfway....fro a long time my vac would work but not very well...had to go over same area.4-5 times..What a workout! The first time I contacted dyson via tele the rep had me remove some stuff and I was able to look at area below selector...what I saw was two holes, one hole was only over the other hole half way...hence at that time I had only part suction since holes were not aligning properly....I read somewhere as a further tip to get suction to engage, while vac is reclined step on front edge of vac head it said you'll get more suction that way, I haven't tried that, but thought it may help someone
Feb 16, 2013 | Dyson DC07 Animal Bagless Upright Cyclonic...
My dyson sucks good untill i put handle down
Try moving the floor/carpet selector dial on base of vac back and forth, from floor to carpet repeatedly, at least 5-6 times....it may be stuck
Wear do you put the water
Inside the main tank is another container for clean water.
To fill it, lay machine all the way down. Lift handle and remove container. Take to sink, turn handle, and remove lid. Fill with hot, clean water. Replace and lock the lid. Place container back into tank and put handle down.
Sep 29, 2010 | Bissell 1699 ProHeat Clear View Upright...
Assembling a steam vac handle part
when the machine comes new the way it is installed is to put the upper handle on the lower handle, install the bolts & nuts (tighten) and then to pull the trigger and press the surge button (if this model has one). you will feel them snap together. the clips on the rods should be at 90 degree's from each other. one will be a u type channel and the other a v type and will connect.
Jan 07, 2009 | Hoover F5810 SteamVac Upright Vacuum
Motor loud
when you put the handle down it turns on the brush roll. you may need to clean the brush roll or replce it if the bearings are bad.also clutch and 2 belts are started when putting handle down for brush operation.
Jun 14, 2008 | Dyson DC17 Animal Bagless Upright Cyclonic...
Received hoover powermax fusion vac today and the handle will not go down as indicated in diagram.
What is your model number? A Savvy and Powermax are differntent models. The Savvy the handle slides on and there are 4 screws to hold it in place. The Powermax has 2 screws to hold it in place. have you removed them before trying to put the handle on. If you have, you just have to work so it will slide down then put in the screws to secure it.
Apr 22, 2008 | Vacuums
Dyson dc07
You can take the clear part off pretty easily, but the upper cylcone section is held on by three star screws on the upper -handle end. After taking those off, the handle comes off and it has a long stick that runs down the center of the cylinder. There are now 8 cyclones facing you. Clean them however you want, but I couldn't get it broken down any further. There are three more star head screws down the center, but after taking them out, I couldn't get the purple upper piece apart from the lower, grey piece. So, I just kept it all dry, pounded on it with a rubber hammer to break the crust off everything, ran a screw driver into each of the cylclones to clear them, and put it back together. Make sure you put your hand down at the bottom when you're trying to line up that stick to put the handle portion back on the whole assembly. If it doesn't make it back in it's little home, it won't empty correctly.
I hope this helps.
Joe
Apr 13, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Vaccum Bag
Slide the plastic piece off the cloth bag and open the top. Looking down into the cloth bag, you will see the old bag. It is secured to the machine near the top. You will find the cardboard collar about a third of the way down. Remove it carefull. Now, stand BEHIND the machine and put your knee against the back of the handle and taking the new bag, open the hole in the cardboard collar and insert the bag into the cloth bag and put the cardboard collar onto the handle fitting. It helps to put the lower part of the hole on first and then press the top of the collar onto the handle fitting. The idea of standing behind with your knee against the handle is so that as you attach the bag, you will be pushing against your knee which will steady the machine and allow you to use the required force to complete the action. Once completed, fold the top of the paper bag down, so that when you replace the top slider, the paper bag is NOT clamped between the cloth bag and the slider.
Jan 25, 2008 | Hoover Soft Light U4266-940 Bagged Upright...
Hoover Fusion Plus Cyclonic Upright Vacuum Vacuum Logo
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
