Question about Cell Phones
My LG GU290f doesn't ring on incoming call (just displays nameand #). I notice that the "Silent All profile in use" is set on - but I can't see how to turn it off?
abhishek33
  • 1239 Answers
SOURCE: ring problem with nokia 6131
HI SIR.  please cheak whether the profile in the general mode.. and keep it in the ring mode.. if also it does't work mean's. u need to restore the factory setting's..   step for setting's..   1. menu>tool>setings>phone>general>restore factor settings>it ask's for thr passward. general passward is 12345 or ur security code..what have u given.. it will restart .. and u will seen it will be ringing . if any doubt assist me.. i am there .. thank u..   please rate it.
Posted on Sep 09, 2008
rg_nardz
  • 66 Answers
SOURCE: on normal nor silent profile no alert coming for incoming calls only
Try restoring the factory settings of your phone!
Go to : SETTINGS then FACTORY SETTINGS.. security code: just type 12345.
If still there is no tone alert, then im sure there is a problem with your phone's buzzer, or it might need to clean the contact of the buzzer insice the board. Just try this....
Kindly rate this up! thank you
Posted on Oct 16, 2008
SOURCE: Can't get my LG Tracfone off of silent mode
Hold the * button!
Posted on Apr 08, 2009
  • 20 Answers
SOURCE: changing user profile
test test 18:30
test test test 18:31s rthsr thsty 897654
Posted on Jul 07, 2009
  • 1456 Answers
SOURCE: LG GC900 stuck on silent
Hi
Since you have done all the necessary checks and the phone still stays on silent, then the problem is from the speaker which is where ring tones come out from when you receive a call or text message
The solution is to have the speaker replaced because it is no longer working. A repairer can help you replace it if you cant do it yourself.
Cheers
Posted on Mar 11, 2010
Got a telstra easy touch dicovery 3. Cant turn silent mode off
Hi Shannon,
TELSTRA EASYTOUCH
DISCOVERY 3
SYMPTOM = No incoming ring or alarm tone
RESOLUTION:
- Check the ring tone and ring volume settings under
Profiles
- Check the handset is not muted (Long press the #
key
Apr 30, 2014 | Cell Phones
Phone sound is silent. Can't hear anything when the phone is ringing. Profile is set to vibrate and ring but there is no sound.
under settings go to tones open it, in that open incoming call alert open it and select ringing
Sep 23, 2011 | Cell Phones
My iphone 3g does not ring, i can hear the ring if i have on ear phones or an ear piece. the signal seems to be okay. the settings seem to be correct.
Dear Dburnett412.
If you can't hear the ringer when there is an incoming call to your iPhone 3G, you may have overlooked whether or not the ring/silent switch is set to silence the ringer. The ring/silent switch is above the volume switch. If you can see orange on this switch, it's set to vibrate. Switch it to ring and you should be all good.
If this doesn't help, you may want to consider resetting the iPhone.
Jun 30, 2011 | Cell Phones
Why my nokia C3 doesnt ring accordingly although i set the ring tone already?its only vibrate.i'm not using silent mode.
I can imagine it how annoying it would be to you to see your cell vibrating instead of playing your favorite ring tone. Most probably it could be because of incorrect Profile configuration. It is possible to make your phone vibrate in almost every profile so we will assume that it is the reason for your problem too. Do the following and check some parameters as described.
1. Go to Menu > Settings > Profiles
2. Select Profile and then Select General.
3. After selecting General you will be given 3 options (Activate, Personalize, Timed)
4. Select Personalize.
5. In the Incoming Call Alert field, select Ringing.
6. In the Ringing Tone field, select your favorite ring tone.
7. Scroll down, (push down button) the next field would be Ringing Volume. For now select the max.
8. Scroll down to the Vibrating Alert field and set it to Off.
9. Scroll further down thill the very last field where it says Alert For, select All Calls for this field.
10. Save your modifications.
11. Activate the profile and see if it works now.
Only and only If it doesn't work, it may be due to software corruption.
In that case reset your phone to the factory default settings by going to:
Menu > Settings > Press UP button.
Select Restore Factory Sett. give your Security Code (default = 12345) and viola.
(Make backup of your messages ad contacts before attempting this)
Jun 04, 2011 | Nokia C3 Cell Phone
My Nokia 6131 has stopped ringing - it just vibrates when there is a call/text. I haven't done anything different. It's not on silent and I've tried resetting to factory defaults. Any suggestions?
its like the user profile has changed to silent
All you have to do is....
go to the settings on your mobile phone, scroll to profile and select it, click on general or loud, select personalize,check the incoming alert mode and see if it is set to ringing,scroll down and select a tone for the alert then save. after which activate the edited profile as the profile in use..
hope this helps
Jan 25, 2011 | Nokia 6131 Cellular Phone
Phone will not ring
HI,
Check the settings whether your incoming call alert is on or silent or on virbration.
Change the profile settings.
Thank you
Nov 04, 2010 | LG enV VX9900 Cellular Phone
Voice command on Gu290f mobile phone
I have a LG GU290f mobile phone but my display screen is white and I can't see anything but the phone vibrates and rings when I get my messages and calls I can speak and hear the call properly only my display is white.
Sep 12, 2010 | LG Rumor LX260 Cellular Phone
How do i put phone on silent
User profiles
This is used to set up the different ways of incoming call prompts in various situations. Use
the up/down key to choose this option and click the left functional key to enter. There are
many modes of setting available and the default setting is the general mode.
To switch to a new user profile, use the direction key to select the target mode and click
“OK” to enter. Then select “activate” and click “OK” to confirm. Your phone will give an
“activated” prompt, indicating that the user profile is active. The “headset” mode does not
require activation; your phone will automatically switch to the “headset” mode if a headset
is connected to your phone, and back to the previous mode when unplugged.
You can also customize each user profile setting for your preference, the following
operations are available:
(1) Ring tone settings:
Incoming calls: Enter “user profile”, select “personal setting”, and set up the ring tone.
Power on: set up the music for power on.
Power off: set up the music for power off.
Message: set up the message ring tone when a new message arrives.
You can also download ring tones online.
(2) Volume
This allows you to set up the volume for ring tones and keypad tones. There are 7 grades
available. Enter this function and use the up/down key for testing and adjusting.
(3) Alert type
This is used to set up the alert type for incoming calls. Please select the suitable alert
types in different situations.
Mar 25, 2010 | Cell Phones
Ringer not working my phone is not ringing i have a LG pRADA
I think u must go on settings then user profile and check that your incoming call alert is on or silent or on virbration.
Dec 31, 2008 | Audio Players & Recorders
Can't disengage SILENT mode
...Or try switching to another profile, eg: "Outdoor"...
menu>settings>profiles>outdoor>activate
Press: power button(short time)>outdoor
Dec 30, 2008 | Nokia 6070 Cellular Phone
Cell Phones Logo
158 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
